oanding oanding is offline
Car: 535i E60
Default Register new AGM Battery - 12-04-2018, 12:02 AM
Hi everyone, I've really already used the search function but unfortunately can't find my answer. Can I register a new AGM Battery with the reset Battery Adaption or is this only necessary for standard batteries?
Grettings from Germany.
Default 12-04-2018, 12:01 PM
You should be able to register via MHD.
THE BEAST's Avatar
Car: 2008 E93
Default 12-04-2018, 06:13 PM
Does that work ? Jb4 also has it. Seems like a simple reset. Not like the actual registration process of amperage, type of batt, cca, etc.or does it somehow read the battery perhaps ??
Ron Vogel Ron Vogel is offline
Car: E61 535Xi
Default 12-04-2018, 07:01 PM
You can register in either, however the car has to be coded for AGM if it's not already.
najin23's Avatar
najin23 najin23 is offline
Car: 335i CDV
Default 12-07-2018, 02:30 PM
I have coded it to AGM.
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
MHD BMS hybrid E85 BEF,
3.5 bar,
E45,
Fuel-it! Stage 2 standard,
FBO,
Synchrotech(MFactory),
Bimmerlife R8 coils,
N20 plugs(0.020")
Car: 535i E60
Default 12-08-2018, 01:11 AM
I think it's registered to AGM. What does the JB4 do when resetting the battery adaptation? Thank You
Car: 535i E60
Default 12-10-2018, 06:27 AM
I'll change the battery next Saturday. It would be great if someone could explain what reset Battery Adaption in menu 1/7.
Thank You
08 335Ci's Avatar
08 335Ci 08 335Ci is offline
Car: 08 335Ci
Default 12-10-2018, 08:46 AM
Registering a battery in a BMW is a 2 step process.
The battery type and capacity is written to the CAS module. IF the same type and size battery is used, this step can be skipped.
The DME uses this information, and the recorded detailed history of the battery's age, state of charge, charging cycles and at rest discharge to control the alternator's output. This history must be cleared when a new battery is installed, the 2nd step.
Because the JB4 only interfaces with the DME, I would imagine using the reset feature in the JB4 would clear the charging history stored in the DME. If it resets the date, I have no idea. Resetting the date is important because the age of the battery is part of the charging equation.
'10 E92 335 M Sport, JB-4 G5 ISO, 3" CPE Charge pipe, WMI w/dual CM 5 nozzles, 3.5 Tmap, ARM Relocated Inlets (don't do it), VSRF Outlet, BEF, Front Strut Brace, SS brake lines, Drilled and Slotted Rotors, Anti-lag, OCC. Escort Max 360
Totaled by a careless driver:
'08 E92 335, M sport option
