mike5215 mike5215 is offline
Car: 2018 430i Manual Coupe
Default New Install, Does This Log Make Sense? - 09-30-2018, 12:00 PM
Just want to confirm everything is connected correctly. Should be Map 2. Car is a 2018 430i Coupe, manual transmission. Thanks!
Default 10-01-2018, 07:24 AM
Need more consistent logs.
Get me a log on map 1 and map 2. From 3rd gear 2krpm till redline if you can.
Default 10-01-2018, 05:36 PM
I kind of forgot the assignment once I was in the car. Here are two runs, on Map 1 and Map 2, a rolling start from 2nd and WOT up into 3rd. On Map 2 something kicked in and shut stuff down in 3rd. I'll try to get what you actually asked me for tomorrow.
The unit seems to be working as it should, no complaints. I just wanted to make sure I had it installed and configured properly. Thanks.
