n55pioneer n55pioneer is offline
Car: '11 135i Coupe
Default whats going on in these logs? - 09-28-2018, 09:17 AM
On WOT, see drop in boost overshoot as dme adjusts and throttle closes? Then can't really get to target. Any settings to try?
https://imgur.com/a/mqvAWSG
In this one, and I could feel it stock too, why do revs raise on this car after I lift throttle? This log look solid?
https://imgur.com/a/CYHPKB2
Default 09-29-2018, 09:18 AM
Looks all normal to me. Boost2 is manifold pressure. Throttle is used to control boost to target so if target changes throttle will help ramp boost down as needed. It's a control system.
As to why the ECU randomly changes it's target sometimes, better contact BMW for help on that, it's a mystery to us.
Car: '11 135i Coupe
Default 10-01-2018, 11:45 AM
Thanks T! Yeah, car feels strong. I know how you feel but I'm really enjoying the MPPSK with a p1pe, and the 11test map6 is smooth! Who knows maybe that will change once we hit freezing temps.
I noticed FF raises from default on its own on test 11 map6, absolute 17 psi? Last I looked FF was at 149? Is cool? Here is a log.
