Tony@VargasTurboTech's Avatar
Tony@VargasTurboTech Tony@VargasTurboTech is offline
Car: Anything with a Turbo
Default No Excuses Drag Set-up - 01-08-2016, 02:52 PM
Finally got everything together on my drag tire, and wheel combo. It cost a pretty penny, and I wasted money on front wheels that didnt fit the first go around. This is as much meat you as can possibly fit in these cars. I need to raise the car up a bit the front is too close, but everything fits, and clears just barely. There is zero excuses for not being able to put down a solid 60 ft with these in the rear. Having another phantom motor issue with a junk yard motor I bought. Found a ton of metal in the pan, before the issue started. I honestly need to stop buying these things. I had track day planned tomorrow. Putting if off now.
Set up is:
Front:
M&H RaceMaster Front runner skinnies 28 x 4.50-18
http://www.summitracing.com/parts/MNH-MSS025
Weld Racing Wheel, RT-S S71, Aluminum, Matte Black, 18 in. x 4.5 High pad
http://www.summitracing.com/parts/wld-71hb8045n16a
Rear:
Hoosier Tire, Drag Slick, 28.00 x 10.00-17, Bias-Ply, Solid White Letters, D06 Compound
http://www.summitracing.com/parts/hoo-18157
Kosei K1's 17X8.5"
Vargas Turbocharger Technologies
Tony@Vargasturbo.com
www.Vargasturbo.com
Making the world happier one turbocharger at a time
Default 01-08-2016, 03:16 PM
Must love corners with that setup.
N54 | Build Thread
Default 01-08-2016, 03:20 PM
All it needs is a parachute in the trunk. Total dragster!
dotCEO's Avatar
dotCEO dotCEO is offline
Car: 08' BMW 135iM
Default 01-08-2016, 03:22 PM
Now we're talking! Can't wait...
7DCT 2013 LeMans Blue BMW ///335is (Pending Inspection)
6AT | 135i ///M Sport - CRASHED (TOTALLED)
bmwheath's Avatar
bmwheath bmwheath is offline
Car: 07'' 335i coupe
Default 01-08-2016, 03:30 PM
Bias Ply tyre? Are you auto or manual box?? Nice snug fit, looks good
JB4 ISO - ***** less Dump ***** - BMS DCI - VRSF 7" intercooler - BMW PE exhaust - Charge pipe & Raceport BOV - Stage 2 fuel pump - BMS E85 Flash/E55 mix, running map7 - BMS Catchcan - Quaife LSD - 19'' Beyern wheels - Msport suspension - Aero front lip - Lux V5's - Mid kick rear spoiler - Dark tint - Msport steering wheel with M3 paddles & trim
ThaCuda's Avatar
ThaCuda ThaCuda is offline
Car: 2007 335i
Default 01-08-2016, 03:31 PM
anyone produce an adjustable solid-ish shock for the rear? and something adjusted close to a 90/10 for the front? If so, can't wait to watch this!
2007 335i 4dr JB4, Hexon RR600, Inlets, 4Bar, Index 12, Boost Concept Pump, DCI, FMIC, ** and full exhaust, Burger Meth, MHD BEF. Auto.
Peter @ Pure's Avatar
Car: F20 M135i
Default 01-08-2016, 03:38 PM
Since fitment is close, no chance on touching due to weight transfer?
F21 M140i - 100-200: 6.95
Audi TTRS - 100-200: 4.47 60-130: 5.16
F80 M3 - 100-200: 4.45, 60-130: 5.1
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
acegp1 acegp1 is offline
Car: 2008 BMW 335i
Default 01-08-2016, 03:49 PM
The setup looks good tony; what are the chances you let me borrow those real quick?
Default 01-08-2016, 03:57 PM
100% will need ride height adjustment to ensure no rubbing, prob a little inner fender massaging as well. This was the initial test fit to make sure I didn't waste $2500 on a set up that didn't fit. Its damn close but they do fit like a glove. Raising the height on the coil overs about an inch should fix all the possible rubbing issues. As for suspension, it could be better. Eibach pro street coilovers on all four corners, Eibach sway bars, I did replace every single rear arm, with either billet, and rod bearing, or M3. This should help get rid of that deflection we see on launching.
www.Vargasturbo.com
ThaCuda's Avatar
Car: 2007 335i
Default 01-08-2016, 04:51 PM
Leave that front swaybar at home!
natedog7700's Avatar
natedog7700 natedog7700 is offline
Car: 2007 bmw 335i e90 auto
Default 01-08-2016, 05:22 PM
Yeah I'm sure it stops and turns really well!
BMW 335i
RB's 550whp
2000 Camry
2000 LS1 T56 Camaro
Koenigsegg Agera R - SOLD
Lamborghini Huracan - SOLD
2014 Bugatti Veyron - SOLD
2012 Ferrari 458 Italia - SOLD
ross22 ross22 is offline
Car: 2007 BMW 335i
Default 01-08-2016, 07:41 PM
Serious 60ft coming. Good luck.
Car: F20 M135i
Default 01-08-2016, 11:49 PM
Looking forward to your results!
peter@pureturbos.eu
pureturbos.eu
Default 01-09-2016, 01:04 AM
Yes, I'm sure it does. Perfect to take all those turns on the drag strip.
www.Vargasturbo.com
E90Convert E90Convert is offline
Car: 08 E90 335i
Default 01-09-2016, 06:43 AM
Can't wait to see this thing go!
E90 335i 6-Speed Manual
JB4 ISO G5 - BMS Pump flash - VRSF Inlets - VRSF FMIC - VRSF CP - HKS BOV - VRSF **'s - Dinan oil cooler - BMS OCC - H&R sways - Goodridge Stainless lines - ATE slotted rotors - Hawk HPS/R Pads - Apex Arc-8 17x9
justa335i's Avatar
justa335i justa335i is offline
Car: 07 E92 335i
Default 01-09-2016, 07:57 AM
2007 E92 335i 6MT
New Jersey
N54-Tuning 3'' Downp!pes, Vrsf 5'' Intercooler, Vrsf Charge Pipe, Tial-Q BOV, Vrsf Lower Charge Pipe, Act HDSD Clutch, JB4 G5 ISO, BMS Intakes, Custom Axle Back w/ 3" Tips
Turbocripple Turbocripple is offline
Default 01-09-2016, 08:02 AM
Looks good man! can't wait to see what it runs!
Default 01-09-2016, 05:52 PM
Same here! I cant wait to see how well it stops and turns too!
BMW 335i
RB's 550whp
2000 Camry
2000 LS1 T56 Camaro
RSTECH RSTECH is offline
Car: e90 335i xdrive
Default 01-09-2016, 08:05 PM
Would love to see consistent 1.5 60' out of this now, wouldn't be surprised if a 1.4 is in it. Hope you get everything worked out soon Tony excited to see what this bad boy can do.
2010 e90 m-sport a/w xdrive, jb4, d_wnpipes, muffler delete, 40/60 e85/93 RIP
2010 e90 a/w xdrive mhd v5 e40 map, ar d_wnPipes, vrsf charge pipe, tial blow off valve.
95 civic-k24 block-k20 head-12.5:1 c/r pistons-drag cartel stg 4 cams-ported rbc mani-q45 90mm tb-ssr headers- 3" exhaust, 300+whp, under 2000 lbs with driver.
NA55 NA55 is offline
Default 01-10-2016, 10:28 AM
You have to do it right if you want to go faster..
Looking forward to see you put all the power down to the ground..
goldfz8's Avatar
goldfz8 goldfz8 is offline
Car: BMW 135, Yamaha fz8
Default 01-10-2016, 01:40 PM
Is that car an auto or manual?
502whp 593wtq
11.995 @122.08. 60' 2.041
3180lbs w/o driver
kennejp's Avatar
kennejp kennejp is offline
Default 01-10-2016, 04:39 PM
Tony do you have any track days set yet?
07 E92 MT RB Turbos-600whp
08 E82 Built engine/trans Speedtech ST 6466
Default 01-10-2016, 05:50 PM
Car is an MT, and yes this car has been the track once prior with no suspension arm upgrades, no LSD, a lot less power, and shift bog. It ran an 11.4 at 125, with a 1.7 60 ft, and bad shifting. Only got 2 runs in before the clutch welded
www.Vargasturbo.com
Jt0407 Jt0407 is offline
Car: Bmw
Default 01-11-2016, 04:55 AM
What ckutch and turbos did you have at the time?
Default 01-11-2016, 08:11 AM
Spec 3+, stage 2 turbos
www.Vargasturbo.com
