DIEGO MAYORAL DIEGO MAYORAL is offline
Car: bmw m235
Default ayuda para poder tunear mi bmw m235 - 05-30-2015, 11:10 AM
buenas tardes me podrian ayudar en mi carro, compre la reprogramacion jb4 porque queria que tuviera mejor tiempo en 1/4 milla.
en mi carro tengo, tuberia complenta con dowpipe 4¨, filtro de aire burguer, sistema de agua metanol.
boost82 boost82 is offline
Car: M235i
Default 05-30-2015, 12:28 PM
I don't understand spanish but your logs look horrific. Trims are maxd, under boosting the whole way. Avg ign is high if you are running methanol. Something is wrong with the meth kit too. I dont think it's spraying cause your iats are insanely high
Car: bmw m235
Default 05-30-2015, 09:43 PM
boost82 thank you recommend me to modify you help me
1slowN55 1slowN55 is offline
Default 05-30-2015, 10:17 PM
Quien te dijo que lo andes en mapa 6?y otra cosa cuando hagas logs hacelos de 3000rpm hasta 6500rpm en tercero y no mas.. no debería estar en mapa 6
2011 N55 335i E92
PURE STAGE 2 FBO
JB4+BMS MHD BEF E50
FX500 Clutch
Car: bmw m235
Default 05-30-2015, 11:24 PM
what map do you recommend to use??
ShlemN55's Avatar
ShlemN55 ShlemN55 is offline
Car: F30 335i msport
Default 05-31-2015, 06:27 AM
Damn 176 iats that's the highest I ever seen .. If you need meth asap ..
1993 Dodge Caravan ( Bone Stock )
2016 Tanzanite Blue F80 M3 jb4 , awe non res, bmc filters.
2fast4utoo! 2fast4utoo! is offline
Car: 135
Default 05-31-2015, 09:05 AM
Map 3
Car: bmw m235
Default 05-31-2015, 01:39 PM
these logs were those who had the car..
Default 05-31-2015, 08:50 PM
Post a screen shot of your user adjustment tab and take a couple logs on map 1.
Car: bmw m235
Default 06-01-2015, 01:30 PM
here is the logs map1
now stalling the map 4 I felt it best
