(#6326)
NJrep335I's Avatar
NJrep335I NJrep335I is offline
Car: BMW 335I
Default 03-16-2013, 05:21 PM
Yes I think ISO17 is pretty close to being the first ISO firmware out of BETA. There is just one little bug I've noticed. On rare occasion when the DME wakes up (when you are outside the car) I've heard the wastegates move. And they shouldn't. Has anyone noticed this? If so drop me a note as I have a patch I want you to try.
I've noticed my wastegates moving back and forth both when the DME wakes up and when I lock the doors and walk away.
Default 03-16-2013, 05:32 PM
Sweet, email me to see if this firmware fixes it.
Bobdudeman1988's Avatar
Bobdudeman1988 Bobdudeman1988 is offline
Car: 07 E90 335i
Default 03-16-2013, 06:55 PM
Just installed my g5 and went ISO . Can't wait to try it..weather permitting..are the default settings for g5 ISO ok with the latest interface ?
imageautodetail's Avatar
imageautodetail imageautodetail is offline
Car: 335 e90 spt pack 6mt
Default 03-16-2013, 08:22 PM
Terry, mine is still doing it, not as bad as it was with 16, where it was almost more wastegate clank, now it is more vacuum noise
Default 03-16-2013, 09:22 PM
just set the interface to G5 ISO and load firmware 17. Set to Map 5.
goaljnky's Avatar
goaljnky goaljnky is offline
Car: M5, Z4 3.5 IS
Default 03-16-2013, 10:46 PM
Quick question. I removed the JB4 (running map 5) for a dealer visit. Put in the SLD wires and upgraded to 17 while I had the cover off. Going to put it back in tomorrow. Will it remember the map 5 settings, or will it have to relearn again?
2011 S Drive 3.5 IS
2008 M5
2006 Mini Cooper S JCW
AWil335i's Avatar
AWil335i AWil335i is offline
Default 03-17-2013, 07:24 AM
i think the maps reset anytime you update firmware.... guess you'll have to WOT a few times... bummer
07 E92 335I | JB4 G5 ISO | BMS E85 Flash | DCI | BMS *** | Helix FMIC | Alpina TCU Flash | Walbro GLS392 | E70 | 429rwhp/474rwtq
Default 03-17-2013, 07:46 AM
Nope. It's stored in the motherboard. It only gets erased if you upload new firmware and don't check the box that preserves your settings. There's a little tick box for that on the Settings tab where you select your JB4 version. It reads "Do Not Reset Settings When Updating Firmware." I am pretty sure it has a purpose :-)
BEAR-AvHistory's Avatar
BEAR-AvHistory BEAR-AvHistory is offline
335is 7DCT/JB4
Car: BMW 335IS 7DCT/JB4
Default 03-17-2013, 09:42 AM
Did you change maps before you took it off?
Kevin
2018 440 MPPSK/MPE
2014 435 MPPK/THP
2013 135is 6MT/JB4/ISO
2011 335is 7DCT/JB4/ISO/BMS Flash(sold)
FF Cobra Mk-IV COYOTE BOSS + TKO-600
goaljnky's Avatar
Car: M5, Z4 3.5 IS
Default 03-17-2013, 06:33 PM
I did not check the box, but it did ask me if I wanted to change to defaults after the flash, to which I of course answered no. Are those not the same?
No, I did not.
2011 S Drive 3.5 IS
2008 M5
Russell @ BMS's Avatar
Car: 2009 335i AT
Cool 03-17-2013, 09:08 PM
If you do not change maps it does not have to re learn.
I may be wrong, but the check box, only refers to the user adjustment data under the "User Adjustment" Tab.
Craig Craig is offline
Car: 2007 335i Coupe
Default 03-19-2013, 05:30 PM
What updates does 17B provide?
Space Gray, 6MT, Sport and Premium Pkg., JB4 G5 ISO, VRSF 7" FMIC, BMW Performance Exhaust, BMS DCI - OCC - CDV - and Clutch Stop, M3 Spoiler, Clear Bra, 20% Tint
rasorjb's Avatar
rasorjb rasorjb is offline
Car: 09 '335i X-Drive
Default 03-19-2013, 07:18 PM
This
Default 03-19-2013, 07:30 PM
A change intended to stop the wastegates from moving when waking the car up. Also a minor change to map 5 for those with a 335is/1M. Both of which need further testing. So I just posted it to facilitate that.
albertc albertc is offline
Default 03-19-2013, 07:32 PM
I though 17B is better cuz B for Better right :P?
JB4 G5, DCI, **, IC, Del Cats, Walbro LPFP, Meth
robc1976's Avatar
robc1976 robc1976 is offline
Default 03-19-2013, 07:37 PM
Sweet, I thought I heard that happening....awesome Terry!
Default 03-19-2013, 07:41 PM
Test it and let me know if it helps.
robc1976's Avatar
Default 03-19-2013, 07:48 PM
I also noticed when starting the car wastegates close faster (within 5 seconds) didn't bother me just letting you know. Wastegates used to stay open for a bit then close.
Deemo Deemo is offline
Car: 07 335i 6AT
Default 03-19-2013, 08:11 PM
im definitely going to trying it out. the sound is annoying af!
goaljnky's Avatar
Car: M5, Z4 3.5 IS
Default 03-19-2013, 11:12 PM
Aahfercryinoutloud.... I just finally flashed to 17 not two days ago. I'm gonna need to come up with some sort of a quick release for the ECU cover.
2011 S Drive 3.5 IS
2008 M5
alexim's Avatar
alexim alexim is offline
Car: 1M
Default 03-20-2013, 03:17 AM
What are the changes to map 5 for 1M guys??? Will be uploading and testing today!
Cynical Cynical is offline
Default 03-20-2013, 08:41 AM
Or just route it thru the fire wall or leave it outside the dme*box
Not ecu
Nanehi Nanehi is offline
Car: 2009 335i Coupe
Default Does cutting G5 diodes void warranty? - 03-20-2013, 12:20 PM
If I cut the diodes on the G5 board, do I void my 1 year warranty?
Car: 2009 335i AT
Cool 03-20-2013, 12:55 PM
Not if the diodes (correct ones) are the only ones you cut.
JK JK
Default 03-20-2013, 03:11 PM
17b the first start it rattled. I restarted and it eliminated it.. I guess it adapted? Seems to have done the trick though!
Haven't driven yet.
