Dreanimal Dreanimal is offline
Car: 2014 F30 335i
Icon1 HUGE timing corrections - 05-14-2019, 10:52 AM
Hello all, this is my first post on this forum so I apologize if it isn't formatted correctly. I have an F30 335i Msport with an EWG and I'm running JB$ map 5. There is a huge timing correction that is occurring that seems to originate on cyl 1 and then hits the rest of the cylinders. I only have 67k miles, but it is the original plugs. I'm running BP premium fuel. Attached is a log of the pull. My initial thoughts are fouled spark plugs but I am concerned with the fuel trims and suspect it is a bit lean. I am also not hitting target boost.
I plan on changing the spark plugs this weekend. To my knowledge they are original. I just purchased the vehicle a few weeks ago. Any help is greatly appreciated.
Mods:
BMS intake
BMS charge pipe
JB4 (Obviously)
Car: 2014 F30 335i
Default 05-14-2019, 10:54 AM
For some reason the log did not attach.
jpuehl jpuehl is offline
Car: '12 135i
Default 05-29-2019, 09:48 AM
Mods:
BMS intake
BMS charge pipe
JB4 (Obviously)
I see that you haven't received a response yet so I thought I'd share the little info I know about this question. I was told by someone at BMS (I think it was Terry) that cylinder 1 on the logs are the target, so ideally the other cylinders should follow cylinder 1. Also the numbers are the actual timing and not corrections. Unfortunately I don't have a lot more to share.
Jim
'12 135i DCT N55 : Swift Spec R springs : Koni adjustable shocks : G.C. Street Camber plates : E92 M3 FSB, front & rear control arm bits : VRSF 7 HD FMIC & inlet/outlets & : Phoenix Racing CP : WhiteLine RSFBs & diff bushings: 1M front strut tower brace : JB4 map 5 & BEF : Quaife LSD
andrews013's Avatar
Car: 2013 E92 335i xDrive
Default 05-29-2019, 09:52 AM
I'm only able to open the log in excel, not the JB4 app. Did you manually modify the CSV at all? Can you re-upload?
Default 06-02-2019, 05:15 PM
Something is wrong with the CSV file and I can't open it in the JB4 interface. Make sure you are not opening or modifying the files in any way. Add another file here.
