sooosha's Avatar
sooosha sooosha is offline
Car: G35
Default BOV drill and tap vs Vacuum Adapter - 03-24-2020, 09:26 AM
Newb question
After discovering the BMS/Vader Solutions BOV vacuum adapter I feel a bit more confused
Originally I was going to do the drill/tap method and modify the 1/8th nipple on the intake manifold for my BOV/CP install.
If I installed the vacuum adapter, does that provide a true 1/4th fitting to my BOV like the drill and tap method? What happens to the original 1/8th nipple if you get the adapter?
I wouldn't mind doing either one but if the adapter is going to make it a lot easier and works just as good i'm all in..
Default 03-24-2020, 12:17 PM
With the BMS adapter it's PNP, comes with two ports and we include a rubber block off and ziptie for the OEM nipple to be covered.
https://www.burgertuning.com/product...17fecf68&_ss=r
rockstar B rockstar B is offline
Car: 08 135i
Default 03-24-2020, 04:03 PM
I did the adapter today and it was cake
sooosha's Avatar
Car: G35
Default 03-25-2020, 06:53 PM
Good to hear
sooosha's Avatar
Car: G35
Default 03-25-2020, 06:54 PM
Sweet, just to be clear, this adapter will make it a 1/4 line (from intake manifold) to the BOV? just like the drill and tap method, not an upgraded 1/8th, correct?
tks535i tks535i is offline
Car: 08 535i 6spd
Default 03-26-2020, 03:03 AM
Yes it will make a true 1/4 line. Go with the adapter. It is so easy to install and not worth the risk of ruining your intake manifold.
Dayton, Ohio
2008 E60 535i 6speed Sport Suspension
JB4, MHD BEF, DCI, D0wnp1pes, 7" VRSF FMIC, CP and BOV, H20/Meth Injection, OCC
Default 03-26-2020, 09:52 AM
Yup, go with the full kit with the PNP hose locks. Set and forget, never have to worry about them blowing out cause of high boost etc.
Devildog0905 Devildog0905 is offline
Car: 2007 BMW 335i Coupe
Default 03-26-2020, 12:54 PM
Newb question
Definitely a better and easier solution to get the adapter. The factory plastic manifold could crack or leak. This adapter is great
sooosha's Avatar
Car: G35
Default 03-28-2020, 07:05 AM
Thank you all! Will go ahead with the adapter
sooosha's Avatar
Car: G35
Default Today, 09:20 AM
Hey! Two questions about the BOV Vacuum Adapter i'm going to purchase..
1. I'm opting for ER CP combo w/ HKS. Will the HKS cause me any issues with install?
2. If I'm sourcing my own 1/4" (6mm) lines will I need to get the upgraded kit, over the basic?
Thank you!!
Default Today, 10:56 AM
Thank you!!
No issues with HKS, I just know their line off the BOV is a bit smaller than 6mm IIRC.
You need basic kit for the HKS.
