(#726)
Default 03-24-2020, 07:32 AM
Originally Posted by drsnowmon
Thanks for your explanation that makes sense
Also for someone who has MK7.5, 93 octane, no mods, is it safe to set peak boost higher than 23 by raising failsafe psi higher?
You can set it to 25 or more. The way that value works is it does not control boost. Its a trigger point that if boost reaches that level the JB4 will revert to the valet/safety map.
drsnowmon drsnowmon is offline
Car: 2019 Golf GTI
Default 03-25-2020, 05:18 AM
Thanks George, I'm still learning
Ringo_Stingo Ringo_Stingo is offline
Car: 2019 VW Alltrack
Default T3 firmware Beta fixes boost reading too high - 03-25-2020, 07:08 AM
Latest firmware Beta, JB4_8_6_T3, appears to have fixed the issue (noted on the T2 variant) with boost readings being artificially too high...on my car, in any case. This 'T3' variant is available on the JB4 mobile app firmware manager. Early boost and peak boost do seem a bit higher, running T3, but I've not logged a WOT run to confirm.
Default 03-25-2020, 11:42 AM
Thanks for the update.
ZuMBLe ZuMBLe is offline
Car: VW Alltrack
Default 03-25-2020, 11:48 AM
I haven't had a chance to try it on my car yet but may do it tomorrow. Hopefully the issue is resolved on my car as well.
Does the 8_6 firmware still have no boost add when the OBD is removed?
Default 03-25-2020, 12:32 PM
Yes.
goodvibes goodvibes is offline
Car: VW Alltrack
Default 03-26-2020, 03:58 PM
Makes for easy breezy smog test.
Car: VW Alltrack
Default 03-28-2020, 11:46 AM
I tested this last night and found the boost readings correct also. Thanks for the quick fix, George!
WillyR7 WillyR7 is offline
Car: Golf R7.5
Default Yesterday, 01:58 PM
Hi, I don’t see any link for 8_6_T3.
On the 1st page the latest fw is 8_6
Default Yesterday, 03:07 PM
Originally Posted by WillyR7
Hi, I donít see any link for 8_6_T3.
8_6 is solid. T are test firmware versions hence T2 having boost reading that where out.
