wxs0621 wxs0621 is offline
Car: 2018 340i
Default B58 Mppsk CANFlap Reset - 09-17-2018, 05:37 AM
So I accidentally set off the JB4's control of the exhaust flaps in my MPPSK b58. Now I can't seem to reset the flap control back to MPPSK-style, where the flap is closed on comfort and open on sport/sport+.
I tried setting the blinkers back to "OEM" with the double blinkers with the BC button but this doesn't seem to set it back the MPPSK style.
I am guessing this feature was mainly designed for non-mppsk situations? Is there a way to reset this feature completely by disconnecting the JB4?
Default 09-17-2018, 06:22 AM
Should work as normal when the flap is closed.
Car: 2018 340i
Default 09-17-2018, 06:32 AM
Thanks for the reply - so are you saying I should keep the JB4 setting on the right blinker (valve closed), and this should allow the mppsk to open/close the valve?
bavarianmw bavarianmw is offline
Car: 17 320i, 16 M3 (outgoing), 18 340i (incoming)
Default 09-24-2018, 08:43 AM
That's how mine seems to be working.
