JBoe JBoe is offline
Car: M240i
Default Sub Forum Suggestion - 09-03-2018, 04:49 PM
Hi Terry,
Can you update and make a sticky, similar to the following, for the B58?
http://www.n54tech.com/forums/showthread.php?t=21269
I know we have the support section, but this sticky puts more info into an easily accessible spot. It could easily be locked to further posts. Thoughts?
Also what do you think of a sticky on WMI setup/tuning for the B58? I know the above link provides some data within it and the settings thread provides some more, but it's not readily accessible as in a one-stop spot. Once setup, you'd probably only need some tweaking for other platforms and/or updated firmware.
I look forward to your thoughts/response. Thanks for all the support, it's been great. Hopefully, some suggestions like this help you/BMS also. It's good to give back. lol.
Default 09-03-2018, 05:28 PM
We'd have to write a thread specific for the B58 as that one was an E chassis thread. But it's a good idea, we've got no shortage of work to do around here.
Car: M240i
Default 09-03-2018, 05:59 PM
If I knew all the corrections, I'd assist. lol. Still a relative novice to the JB4, but I'm learning quickly. Thanks to a lot of reading and your support.
