Car: M5501
2021 M550i dyno results -
06-22-2022, 03:38 AM
All,
600HP at the wheels running HF Active Autowerk ***, JB4 Map 1, an after market Axelback exhaust, Dual Cone intakes and 100 octane.
2021 M550i
Bernina Grey Amber Effect
BMS Elite Intakes
GPower Axel Back High Flow Sport Silencer
Active Autowerke High Flow DwnPips
HardRace rear sway bar and Dinan lowering springs
Barracuda Racing Wheels (Inferno)
JB4 Map 1
Retired:
2009 335xi
Completely Moded out
Beat corvettes - they were pissed
Car: M550i
06-22-2022, 01:07 PM
Nice thanks for the share. Is that a Dynojet?
What are your 100-200kmph times like when joining Der Autobahn ?
Anti-Social
Car: 2022 X3 M40i
06-22-2022, 03:51 PM
Is that corrected? I can’t read the sheet so excuse me if I’m asking about something obvious. 600whp should be right in the neighborhood of 675-680 at the flywheel with the ZF8 and xDrive losses. I’d say that’s pretty damn impressive considering it’s basic bolt ons and not even an M5.
Mike Levy
2022 Black Sapphire X3 M40i
Car: X5 M50i
06-22-2022, 07:08 PM
Let's look into those numbers you mentioned considering Burger hit 493 wheel stock with Map 2 taking it to 559 on E20. That would equate to a rough 0.05% DT loss and 10whp per lb boost gain.
Map 1: 4lbs
According to Burger Dynojet in example above would equate to: 533 wheel on 93, 20whp difference from 91 to E20.
An extra 70whp for intakes and 100oct since an axle back only contributes sound?
I've been able to push 26lbs in my M50i with a custom map 6 (accident but logs looked good).
17 peak stock (at least in my logs) on 93oct plus Burger's stock M550i results on 91: Should be 513whp baseline.
+90whp from my 29lbs at 10whp per/lb: 603whp at 26lbs on 93oct
Tell me my 5th grader math is wrong..
Anti-Social
Car: 2022 X3 M40i
06-22-2022, 09:09 PM
The problem is, each engine is different. They won’t all dyno the same numbers. So ideally, we need a stock dyno run before a tuned one. About the only thing we can be sure of, is that pretty much all of them are making way over 523hp.
Losses from the ZF8 and xDrive system are generally in the 10-12% range according to most. Seems a bit low to me, I’m thinking 12-15%, but they know better than I do.
Either way, without a stock run we can’t really estimate gains.
Mike Levy
Car: M5501
06-22-2022, 11:13 PM
Boosted, I am not sure if its a Dyno Jet but the rollers are sunk into the ground if that means anything as to the type of dyno? I have a draggy on order too so I can get those 100-200 soon.
Mike, the numbers are corrected and the tech and I talked about 10% drive train loss that got me to 599 WHP.
To the other poster, am not sure a exhaust does much other then help the turbos get air out faster due to less restriction. Also, I run 100-102 octane and this tank had 50/50 Aral 102 and shell 100 race gas. You didn't mention Pi(pS at all in your post so let not forget about the power those create! Active Autowerke states 20-40 HP based on a tune. If I am at 4 psi or 40 HP over stock 530+40 and then I add 30 for Pi(ps + 30 so those equal 600. Either way my set up is slightly different as I have access to higher octane which helps.
I might try and dial in a map6 tune with maybe 5psi to see if I can hit 610ish. But the tech also talked about transmission slip and recommended I not go higher on power...nothing beyond 620. Maybe he knows something I don't?
I hope this helps level set and helps to understand the situation this car is at to help achieve these numbers.
2021 M550i
BMS Elite Intakes
JB4 Map 1
Retired:
2009 335xi
Car: M550i
06-23-2022, 05:56 AM
Map 1: 4lbs
Adding boost inst a linear relationship to gaining HP. The first two pounds of boost might give you 30hp, then its gets much hotter, so the next two give you 20hp, then you hit your octane and timing limits, so the next two give you 5hp.
Car: M550i
06-23-2022, 05:58 AM
Its probably making 650hp at the motor, which what an OG M5 makes. So that would be my first question. What does a stock M5 f90 make on this dyno? Then secondly can you run a good 100-200 in line with an M5. If so all is well with the world and your car is storming fast!
Car: X5 M50i
06-23-2022, 07:16 AM
I understand that but in my scenario and question, my log says different with given temp readings and trims near unmaxed. A perfect linear relationship that won't happen again lol.
I'm just curious on sustained whp and target boost levels on this platform to safely hit the sweet spot. No one seems to have an answer on this yet and what would otherwise be detrimental.
Car: M550i
06-23-2022, 08:29 AM
Well if you question is what's the max boost the turbos can handle? There's a compressor map on the Borgwarner website for those calculations. If the question is whats the best boost for the best performance. Add boost until your dragy times start going the wrong way....
Car: X5 M50i
06-25-2022, 08:03 AM
Is there a consensus on what a late model M50i, M550i, M850i, (factory claimed 523HP) actually produces at the flywheel?
Car: M550i
06-25-2022, 09:33 AM
I've seen between 530 and 550 crank as the most common distribution. They aren't lowballed hard like the M cars.
Car: X5 M50i
06-27-2022, 07:19 AM
So in simple terms for the less technical like myself, is it reasonable to assume that an otherwise stock config N63B(late model M50i, M550i) on 93 octane fuel would produce about 600 at the flywheel JB4 Map 1?
Car: M550i
06-27-2022, 09:12 AM
From the data i've seen map one (+4 lbs) with good pump fuel and reasonable air is worth +60 to +70 engine horse power. So yes an easy 600+ at the motor.
The OP is making that at the wheels thanks to Intakes, D0wnP1pes and race fuel.
Car: X5 M50i
06-27-2022, 12:28 PM
Gotcha, Thanks.
Car: X5 M50i
07-01-2022, 07:13 AM
So approx. 600 HP at the motor. Would 650 TQ be expected? That sure would give a great bump on the SOTP meter.
Car: M550i
07-01-2022, 09:27 AM
Here's the Dyno from Dinans Tu3 piggy. I think this is around +3-3.5lbs of boost like the racechip.
Car: 340ix
07-01-2022, 03:31 PM
Map 2 on 21+ m550s with an e30 mix and ********* should be making probably close to 630awhp possibly more, I’m trapping constant 129 in high d/a with just those mods listed above
Car: M5501
07-01-2022, 10:14 PM
It will be so nice when we can get away from piggybacks and get a real tune that Taylor's to the car. Right now GPower wants my ECU for 2 weeks so it can sent to Russia for a hackathon. That's great but not practical for me. One day boys we can put a real tune on these cars. Anyway, nice power in the above post.
2021 M550i
BMS Elite Intakes
JB4 Map 1
Retired:
2009 335xi
Car: X5 M50i
07-02-2022, 06:18 AM
Damn, 129MPH trap in lousy air is kickin some ass my friend. My bone stock A8 C7 Z06 trapped 129-130 at 1,000 DA.
Anti-Social
Car: 2022 X3 M40i
07-02-2022, 12:01 PM
Thats how all the tuners are right now. Only FEMTO in Russia is able to unlock these computers. Unfortunately, its only a single unlock. If you flash back to stock, it has to go back to Russia to be unlocked again if you want to put the tune back on. Its ridiculous.
ProTuning Freaks say they'll be able to unlock them eventually, once they have the time and manpower to put into it.
Mike Levy
Car: X5 M50i
07-02-2022, 04:54 PM
Is that e30 straight from the pump at the gas station or are you mixing e85 with 93 octane in some proportion to get to the e30 level? I think our 93 octane here in Florida is 10% ethanol.
Anti-Social
Car: 2022 X3 M40i
07-02-2022, 07:59 PM
All of our pump gas is E10 unless it specifically says Ethanol Free. Our "E85" generally is closer to E50-E60 than E85 also. You gotta check it every time, because its not regulated.
Mike Levy
Car: 340ix
07-03-2022, 01:16 AM
The 93 I use has 10% and the e85 I use varies around 75-80 so I just mix in 4-4.5 gallons and the rest 93 to fill the tank it’s easier when the tank is empty less then 40 miles to empty
Car: X5 M50i
07-03-2022, 09:40 AM
How many gallons does your tank hold? My M50i holds 21.9 gallons.
Thread Tools |
Display Modes |
