Hi all
I need help to solve my weird "boost leak".
Symptomes:
- pulsating boost
- 30ff, mostly in 3rd and full throttle
- spontaneously also the following errors: 2ABC, 3100
Following things i have already replaced or tested:
- replaced all vacuum lines
- testet vacuum canisters
- testet westgate actuators, no vacuum loss. The rear westgate is working fine optically. I don't see the front westgate, but it sounds good when i test with the vacuum pistole
- replaced vacuum solenoids with working ones from a friends car
- replaced fmic with wagner evo 1
- check CP and other cold side hoses
- Change JB4 firmware from the 32.15 to 32.16 for testing
- i have no westgate rattle
But unfortunately no changes.
After I received the 2ABC error, I thought the MAP sensor is faulty. but then the error should always be displayed? Btw. I use the stock (2,5 psi?) sensor.
The car is im stock stat until the fmic and jb4. Turbos have 60'000 km.
I have installed a JB4 G5 but since i have no boost i used it in Map 4.
made a small log. I hope it will help.
Thank you for your help. (And sorry for my bad English
