(#1451)
g0t2bmiirii's Avatar
Default 10-31-2017, 08:46 AM
Mobil is one of the most expensive gas prices here not by much but it’s uaully the highest out of its competitors
Slowjoe Slowjoe is offline
Car: 2017 Infiniti Q50S AWD
Default 10-31-2017, 09:06 AM
Here are some pictures for my set up with my Gpad for the JB4 app. I ran the USB cord under my floor mat for now and I tuck the cord next to my seat so it is not very noticeable. The great thing about the tablet holder that goes into the CD player is it removes/installs in 10 seconds. So if you want a clean look it can be removed quickly. Then I just stick the GPad in the driver door cup holder area. I can't see it but it will at least log for me.
Default 10-31-2017, 09:13 AM
Originally Posted by g0t2bmiirii
What you mean by “bad tank”?? Bad gas?? Also I don’t always race with it, no where to really race in NYC
Yeah, something wasn't right with it. It was labeled 93, but the car was pulling timing like no ones business. When I turned it down to a lower map it stopped pulling timing. Guessing it wasn't really 93 octane.
I also have the ability to add Ethanol when ever I want, it is almost everywhere here. So I have run tanks of E30, but then I have to go to 2 gas stations, so I am happy with this set up that I can run on 93. I have already embarrassed some people, which is fun.
I can run E30 for "Race" days.
jrobohm's Avatar
jrobohm jrobohm is offline
Default 10-31-2017, 09:16 AM
Very cool - I have a new weekend project!
Car: Infiniti Q50 RS400
Default 10-31-2017, 10:20 AM
Anybody with lowers? How’s the car running? Have you data logged yet?
IridiumRS400 IridiumRS400 is offline
Car: 2017 Infiniti Q60S AWD
Default 10-31-2017, 07:42 PM
I have FI Lowers & CBE, and running 92 octane (Chevron) on my '17 RS w/tapered boost.
Just got the Bluetooth kit installed, so I will be logging in the next few days. I managed one run tonight, and the Speed Timing in the JB4 app measured my 0-60 in Standard mode @ 4.2 sec.
My Map 6 settings:
RPM Boost
1500 2.0
2000 2.5
2500 3.0
3000 3.5
3500 4.0
4000 4.0
4500 3.5
5000 3.0
5500 2.5
6000 2.0
6500 1.5
7000 1.0
2017 Q60 Red Sport AWD Iridium Blue / Monaco Red / Premium Plus Package 3.0t Sport / XPEL Clear Bra - Full Hood, Fenders, Doors, Mirrors, Rockers, A-Pillars, and Roof & Rear Qtr (Partial) / FI Full D Ps & CBE / Stoptech Trophy BBK FR & RR w/SS-Braided Brake Lines / Infiniti HE / Infiniti Intakes / AMS LPFP & HPFP (not installed) / Ecutek Tune / BMS Pedal Tuner / Infiniti Radiant Sport Grille / EMM Tuning CF Foglight Finishers / CF Duckbill RR Spoiler / Mishimoto OCC / Stillen RSB & SPL End Links
Yld2rob Yld2rob is offline
Car: Q50 RS400
Default 11-01-2017, 06:32 AM
Excellent. post the logs and get Terry's feedback.
My Map 6 settings:
RPM Boost
1500 2.0
2000 2.5
2500 3.0
3000 3.5
3500 4.0
4000 4.0
4500 3.5
5000 3.0
5500 2.5
6000 2.0
6500 1.5
7000 1.0
Car: Q50 RS400
Default 11-01-2017, 06:38 AM
On my 17 RS with 93 Octane I have been running the below..
1500 1.0
2000 2.0
2500 3.0
3000 3.0
3500 3.5
4000 3.5
4500 4.0
5000 4.0
5500 4.0
6000 4.0
6500 3.0
7000 1.0
Default 11-01-2017, 01:54 PM
I performed a 0-60 run last night in Standard mode. Interesting observations:
- Additional boost request below the 3000 rpm threshold is ignored, based on comparing ecu_psi vs boost. The "target" parameter is the User-defined added boost in Map 6, which I have currently loaded on the JB4. Once passing 3000 rpm, the added boost matches the "ecu_psi + target = boost" equation. Maybe a function of Standard mode, or is this in all modes? I'll log a 0-60 in Sport and compare results. I liked Standard mode as the shift point is lower and more
within the turbo efficiency plot (from Stillen research).
- AFR is from the mid 10's to the mid 11's above 5000 rpm. A little rich, but maybe not a bad thing vs lean in this rev range.
- Pedal goes to 109% at idle, but throttle doesn't go to 100% until crossing the 2000 rpm threshold. Again, a side effect of running in Standard mode? Is this throttle lag removed in Sport mode?
Otherwise, not a bad run on 92 octane Chevron @ sea level.
File Type: csv 0-60_IridiumRS400_JB4_log_10-31-2017.csv (5.9 KB, 77 views)
Car: Q50 RS400
Default 11-01-2017, 04:11 PM
Thanks for the information. Please try Sport plus mode. I would like to see how that mode will change boost and pedal
Default 11-01-2017, 09:25 PM
The math on the pedal logging parameter is wrong, it can't go past 100 obviously. We'll fix that next firmware version.
On boost requested over stock it can't make more boost than stock until the turbo spools up enough to allow it.
On pedal vs. throttle, pedal is your request. The ECU throttle is when it decides to start going. If brake boosting it probably doesn't go until you let off the gas pedal, etc.
NeedMoreBoost NeedMoreBoost is offline
Car: Infiniti Q50 3.0t
Default 11-02-2017, 10:11 AM
How do I activate the 0-60 feature on the JB4?
bbbrrrx1 bbbrrrx1 is offline
Car: q50s
Default 11-02-2017, 11:17 AM
I finally got a long enough USB extension to log my Q50 SS RWD. I'm using JB1 set at 7.0 boost safety, and a DWP of 30; with an e30 blend. I did a 35-115+ pull in 4th gear, and two 1st through 2nd gear pulls with traction off in sport+ mode. The pic is the 4th gear pull. How does it look?
Mastalee Mastalee is offline
Car: Infinti Q50 3.0t 2016
Default New JB4 owner - 11-02-2017, 11:21 AM
So I've got the JB4, I was wondering what setting I should be using for 91 octane for Map 6? I have a premium and have no clue what boost settings I should be using for that octane level.
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2017 X3 xDrive35i
Default 11-02-2017, 02:03 PM
I don't think its active. It never worked on my 335.
Mike Levy
2021 M550i - July build, waiting for dealer allocation
2017 X3 xDrive35i
2018 Equinox LT 2.0T
Hammer663s Hammer663s is offline
Car: 2017 Q50S 3.0t
Default 11-02-2017, 04:13 PM
I'd max at +4. Start at +2 and taper up to +4, then stay at +4 till 5500 and start tapering down quickly. That's what I run here on 92 with my SS 3.0t and it is fast and, hopefully, safe.
M
Default 11-02-2017, 06:21 PM
"Speed Timing", typeset in blue, between HUD Mode and Gauge Set on the App.
Not aware what inputs it uses for speed, either the vehicle speed sensor or GPS.
Car Guy Q50 Car Guy Q50 is offline
Car: 2017 Q50 RS 400
Default 11-02-2017, 08:32 PM
Hello everyone, new to the Q50 world. I have a 2017 Q50 RS 400. Terry, I have attached 2 logs from JB4 MAP 1 on 93 Octane, can you take a look and see if anything I should be concerned with. Thanks.
Default 11-02-2017, 09:54 PM
I'll chime in, as I can only compare to my own logs. Your AFR started out rich, and fuel trims peaked in the 40-44 range. Now maybe this had to do with 80 degrees on the IAT? Looks like you were in Sport+ mode?
In comparison, in my 0-60 run posted in this thread, which I ran in Standard mode, my IAT at the time was 60 degrees, my AFR was at right around 14.7 from idle to 2700 rpm, and my fuel trims peaked at 37, ranging typically from 23-34 over the run. I am running Map 6 with tapered boost to a peak of 4, Lower Downs & CBE, and 92 octane.
Anyways, let's see what Terry says.
Default 11-03-2017, 10:01 AM
Log looks really clean to me. Log map2 next!
Default 11-03-2017, 10:03 AM
I'm on my way back from SEMA tonight and will be racing our Q50 at NoFlyZone half mile race tomorrow. Will be a great opportunity to to get some JB4 data during extended runs. Hopefully can win a few races too... Stay tuned for photos and logs.
chainar1 chainar1 is offline
Car: 2017 Q50 Sport
Default 11-03-2017, 11:27 AM
Actually looks really similar to my SS logs on map 2 w/ 93 pump. Have had 0 issues with it for over a month now through countless WOT runs.
Default 11-03-2017, 09:55 PM
M
Thanks, I'll try that out!
Default 11-04-2017, 05:27 PM
Curious maybe someone can confirm this for me, is it possible to shut off the AWD to make it only RWD? Asking because someone told me yes by unplugging a plug in the trunk? If so are there any cons to this?? I was told a bunch of lights on the dash will come up
VirusbetaX VirusbetaX is offline
Car: Infiniti Q50 SilverSport 3.0T
Default 11-04-2017, 07:46 PM
No benefit the AWD cars have added drivetrain components that add weight to the vehicle turning it off would give us no benefit and may slow down the car. Plus AWD is superior and worth the minor weight gain, adds a lot of stability and is a godsend in snow.
