Wnsduf1 Wnsduf1 is offline
Car: Stinger
Default Stutter after reinstall - 06-12-2020, 05:50 AM
I uninstalled JB4 for the service at Kia dealership for an oil change, i reinstalled my JB4 including the fuel wires. I put it on Map2(which is what i usually sit at) this morning, first time driving after the reinstall, noticed stutter and jerkyness when i press on the gas, pretty consistently, basically all the time. I changed it to map0 and still the same, i unplugged my JB4 and no stutter or anything, running smoothly. My car and JB4 was working properly for months without an issue until i uninstalled and reinstalled.. I donít know if itís misfire or what is going on
Beefer's Avatar
Beefer Beefer is offline
Car: Genesis G70 3.3T
Default 06-12-2020, 06:09 AM
This happened to me as well. Got the 106 code which I think is connections. Car is undriveable...even stalls.
Map 0...same.
Had to disconnect everything.
Been working fine on my G70 3.3T for well over a year !!
Have not had time to mess with it...so not even using my JB4 right now.
This sucks.
Car: Stinger
Default 06-12-2020, 06:16 AM
Mine hasnít stalled
Default 06-12-2020, 08:50 AM
Sounds like something is loose, photos of install? Maybe OBDII cable in wrong orientation? JB4 log?
Car: Stinger
Default 06-12-2020, 08:52 AM
I will check all the wires!
Car: Stinger
Default 06-12-2020, 09:21 AM
Could having some wire cover residue particles affect the stutterness? When i installed the driver side fuel wire, i might have had some pitched between the posietap and the end cap.
Beefer's Avatar
Default 06-12-2020, 09:39 AM
I removed my fuel wires first...and still the same thing. Then I proceeded to remove the entire JB4 setup.
ODBII connector (inside and into JB4) can only go in one way.
Car: Stinger
Default 06-12-2020, 02:28 PM
I did both reinstall of all the fuelwires and rainbow/brown connector, and updated to firmware 15. Still the same after i ran it for 10 mins? Itís almost like my car canít shift and get rpm up
Default 06-12-2020, 05:29 PM
See my previous post re: information we'd need to provide assistance.
Car: Stinger
Default 06-12-2020, 06:10 PM
Well itís currently off of my car..
Car: Stinger
Default 06-13-2020, 09:43 AM
My question is, can spark plug be an issue? Or not at all?
Beefer's Avatar
Default 06-13-2020, 12:47 PM
No...as it runs perfectly with the JB4 out.
I do use BOOSTane Pro. Since I rarely drive lately...wonder if the fuel is giving the JB4 issues.
Not sure if the BOOSTane settles over time or if it’s permanently blended with the fuel.
