Anthonylee Anthonylee is offline
Car: 2011 bmw335i
Default 2011 335i pure stage 2 tuning - 03-18-2020, 03:54 PM
Hey I have just recently installed my pure stage 2 turbo and I am on map 2. With the set perimeters on the form. I have posted my log. Please let me know if there is anything I need to change thanks.
Default 03-18-2020, 08:22 PM
Attach the CSV to this post too! The photo doesn't let us see all your technical settings.
Car: 2011 bmw335i
Default CSV - 03-18-2020, 08:48 PM
For some reason it want let me post the CSV says itís to big and want let me re size it.
Car: 2011 bmw335i
Default CSV - 03-18-2020, 08:58 PM
I got it to Resize.
Default 03-19-2020, 12:30 PM
Looks good to me so far. What fuel and fuel system?
Car: 2011 bmw335i
Default 03-20-2020, 08:05 AM
I am on 93 octane. And still stick fueling system
Car: 2011 bmw335i
Default 03-20-2020, 08:09 AM
What would need to do next to get the max amount of horse power from this setup.
Zackman218 Zackman218 is offline
Car: 2011 BMW 335i M-Sport
Default 03-20-2020, 10:32 PM
Im not as experienced as some of the BMS guys however your fuel trims seem to be maxing out which usually indicates you are running lean. If i were you i would definitely get a walbro 450 LPFP upgrade before using map 2.
Car: 2011 bmw335i
Default 03-21-2020, 01:00 PM
Can I run an e30 if so with or without e85 backend flash
Stoolz Stoolz is offline
Car: 11 135i
Default 03-21-2020, 04:03 PM
There is no point having a ps2 and stock fuel system. I would look at WMI or PI and lpfp upgrades.
Default 03-23-2020, 10:36 PM
BEF
Likely not
