Bita Bita is offline
Car: 2013 335i M Sport
Default New to N54Tech.com ... Error message: Short circuit to B+ - 07-28-2019, 09:27 PM
Hi everyone,
Greetings from Australia !
I have a 2013 335i M Sport PWG and I am currently getting the following error message:
" 104401 MAP sensor, intake pipe, electrical: Short circuit to B+ "
Is this something I need to worry about it ?
How to fix it ?
I have cleaned this error but it comes back ...
Please let me know.
Cheers
Bita
Stoolz Stoolz is offline
Car: 11 135i
Default 07-29-2019, 02:19 AM
One way this can come up is if you have the Bluetooth kit red hooked to 12v instead of 5v.
It may also be a loose connection as Short can also mean open. (from memory)
Default 07-30-2019, 01:19 PM
It was fairly common on v1 systems if installed wrong. Is it v1 or v2? Install photos?
Default 08-07-2019, 02:20 AM
Hi guys,
Thanks for the replies.
It appears I chose the wrong MAP connection when I first installed the JB4.
My second-hand JB4 has 2 sets of light brown connectors (2 different types of connectors), 1 set of dark brown connectors, 1 set of blue (PWG) and 1 set of rainbow (TMAP).
I initially thought the light brown color was for the MAP sensors only but it turns out I used both light brown colours for the MAP and fuel pressure.
I had the dark brown colour plugged in the fuel pressure sensor and that was given the following error message:
All good as gold now !!
Cheers
Claudio
Default 08-07-2019, 02:27 AM
Sorry... I meant to say:
I had the dark brown colour plugged in the MAP sensor and that was given the following error message:
Cheers
Default 08-08-2019, 09:08 AM
You probably mean the old purple connection, that was dropped a few years ago, used to go to the MAF sensor on older systems. You can cut it off the harness.
