(#3751)
Default 10-11-2020, 08:36 PM
Originally Posted by twister68
Running v19 MAP 2 with intakes, EWG & Fuel wires....Petro Canada 94 RON (allegedly)
a couple of logs just to check everything looks cool please Terry and to see if I need to change anything....
Map 3 with Boostane next...
So far super smooth...wish I could get hand of the launch control though...
Short run but looks fine to me!
wardyl36 wardyl36 is offline
Car: Kia stinger gt
Default 10-12-2020, 07:58 AM
Hi Terry,
Please check log when you have a moment. I posted in different section by mistake. Ran a 12.5 at 112 off launch control with computer doing shifting. Was told timing dropped out and shifting too high. Is it better to run with paddles? Had 93 octane with wmi.
twister68's Avatar
twister68 twister68 is offline
Car: 2017 Q60 RS
Default 10-12-2020, 08:36 AM
thanks Terry, I'll do some longer runs
Twister
2021 Genesis 3.3T
Siberian Ice
JB4 kit with EWGs MAP 2 94RON
Feeling the JB4 difference
Default 10-12-2020, 08:51 AM
Originally Posted by wardyl36
Hi Terry,
Data side seems fine to me. On getting those good times practice makes perfect and weather plays a large role too.
mbr mbr is offline
Car: Cerato GT 1.6T
Default Log check for 1.6T - 10-15-2020, 02:20 AM
Hey Terry, could you please check my log when you've got a sec?
1.6T
map 2
gear 3 (DCT)
regapped stock plugs to 0.24
100RON fuel (5% ethanol)
Fuel wire has been installed but not sure if I got it right, I've also set the DWP to 100 (which has made the car waaay better to drive by the way)
cheers
twister68's Avatar
Car: 2017 Q60 RS
Default Log Check please Terry - 10-16-2020, 03:45 PM
Map 2 94 RON, couple of decent pulls before I go to Map 3 as I just put can of additive in but may not have mixed fully yet as it was only about 20 miles after top up
12.47 1/4 mile and 4.4s 0-60 but still losing on this damn launch but getting better.....4.14s with 1ft roll, too early for brake boost :-)
Twister
2021 Genesis 3.3T
Siberian Ice
Last edited by twister68; 10-16-2020 at 04:35 PM.. Reason: Saved adding another reply
Default 10-18-2020, 08:19 PM
1.6T
map 2
gear 3 (DCT)
cheers
Seems OK to me. On the 1.6L it's harder to tell if the fuel wire is working but the trims seem to be dropping at fuel-enrichment goes up so I'd guess it is.
twister68's Avatar
Car: 2017 Q60 RS
Default Terry - Log File missing from previous post - 10-19-2020, 04:05 AM
Hey Terry - Map 2 with 94 RON & Booster Juice. Can you please take a look to see if all looks well?
thanks
Twister
Twister
2021 Genesis 3.3T
Siberian Ice
mbr mbr is offline
Car: Cerato GT 1.6T
Default 10-19-2020, 03:36 PM
Thanks for that terry, Iím going to have a crack at e30 with map 3 next and see how it goes.
Cheers
Default 10-19-2020, 03:47 PM
thanks
Twister
Looks good to me.
ScottyDangles ScottyDangles is offline
Car: 2018 Kia Stinger 3.3
Default 10-26-2020, 06:54 AM
Good Morning Terry:
Quick question, I'm currently selling my JB4 for the 3.3T Stinger, bought a couple years ago. Will my unit auto detect to the other platforms as well, I assume that is part of a firmware update?
In case you're wondering, I'm selling because I bought an 2019 Audi RS3, I'll likely get the JB4 for it as well.
Regards,
Scott
DavG70 DavG70 is offline
Car: Genesis G70 197 hp
Default 10-26-2020, 11:22 PM
Hi Terry.
What you think about this log?
sonyerickson88 sonyerickson88 is offline
Car: veloster n
Default 10-27-2020, 07:53 AM
Hey Terry,
Been playing around with map 6 a bit. Added some boost in the mid range and took out a little in the top end. Feels really strong. Was able to edge out against a 335d fbo and tune. Just wanna make sure numbers are still looking pretty safe and where they need to be I'm still intercooler, turbo inlet, intake snorkel, d0wnp1pe, cai, catch can and 92 octane.
Default 10-27-2020, 08:54 AM
Originally Posted by ScottyDangles
Good Morning Terry:
Regards,
Scott
The Stinger model will work for other Kia vehicles. The JB4 mobile adapter you can keep and reuse with your next JB4 along with the app.
Default 10-27-2020, 08:55 AM
Originally Posted by DavG70
Hi Terry.
Looks normal to me.
Default 10-27-2020, 08:57 AM
Originally Posted by sonyerickson88
Hey Terry,
There are some timing corrections so I think you'd be better off with more octane if possible. But all things considered it's not bad. If it's pulling strongly then probably fine.
Default 10-27-2020, 01:26 PM
bit6 - Turn on if vehicle has an aftermarket flash map loaded to the ECU.
Whatís this bit doing?
theshanestation theshanestation is offline
Car: 2020 Kia Forte5 GT
Default log check please - 10-30-2020, 10:53 AM
Hi, just got my HKS M45 plugs installed. Gapped to .025
Cold starts are definitely much better, less hesitation and sputtering.
can you please check my logs to see what you think?
these were done on map1 with 91 octane
Car is stock other than CAI.
Thanks.
2020 Forte5 GT
CAI
JB4
Default 10-30-2020, 11:25 AM
Let's the JB4 know an aftermarket flash is loaded to the vehicle. What is done with that data varies by model and firmware version.
Default 10-30-2020, 11:26 AM
Thanks.
Still a couple weird AFR spikes where you would not expect to see them. Turn off fuel control next, options bit0 on.
Default 10-30-2020, 01:13 PM
How about now?
Looks like the spikes are gone
2020 Forte5 GT
CAI
JB4
Default 10-30-2020, 01:51 PM
Now it only spikes during the shift where I'd expect it. For the 1.6L models o2 biasing isn't really that beneficial anyway unless running a heavy E85 mix so I'd leave JB4 fuel control disabled.
BHR Stinger BHR Stinger is offline
Car: Stinger 3.3T
Default 10-31-2020, 12:00 PM
Little help here Terry.
Car runs strong, after WOT the boost goes to above 30psi and stays there for a while and then all the dash lights come on and the car runs like crap. I get a 061B code, I clear it and things go back to normal. Car has EWG, WMI and on map 2.
Let me know were to start.
JB4 - Denso 5346 - AEM Intake - VT Snorkels - Snow WMI - NGT Primaries - JUN BL Mid-pipe w/200cell HFCs & EVC c@t-back - Radium OCC x2
twister68's Avatar
Car: 2017 Q60 RS
Default Map 4 Test Log Check - 10-31-2020, 12:26 PM
Hi Terry, can you check this log out from today please
Twister
2021 Genesis 3.3T
Siberian Ice
neonland neonland is offline
Car: kia stringer
Icon1 Log Check - 10-31-2020, 12:46 PM
Mind taking a look? Any suggestions to increase performance or anything look questionable as far as safety? Thanks
Trims look real low at times. Are trims significant if so why? Thanks again.
