(#126)
hungtran505 hungtran505 is offline
Car: Kia Stinger
Default 11-05-2019, 06:54 PM
It shouldn't. I have my on for awhile now.
monkey monkey is offline
Car: stinger
Default 11-05-2019, 09:11 PM
It happened right when the A light on the dash started flashing.
GT2?
Car: Kia Stinger
Default 11-05-2019, 09:17 PM
Mine is a GT. That's wired
Car: stinger
Default 11-06-2019, 08:02 AM
And you have the optional collision avoidance auto steering etc? Plus GT2 is drive by wire gear selection and has an extra brake signal to the trans
Car: Kia Stinger
Default 11-06-2019, 08:06 AM
Yes but mine is not a drive by shifter
Car: stinger
Default 11-06-2019, 08:19 AM
Drive by shifter is weird. Brake snip only works part way until the auto stop light on the dash starts flashing.
whytiptoe whytiptoe is offline
Car: 2019 Kia Stinger GT2
Default 11-06-2019, 07:36 PM
Looks like for the GT2 it will need to be incorporated into the JB4 some how!!!!!
MurlinatoR's Avatar
MurlinatoR MurlinatoR is offline
Kia Efficinato
Car: 2018 Kia Stinger GT AWD
Default 12-27-2019, 09:31 AM
Everyone still running problem free with the snip?
Any regrets?
-MurlinatoR
Connoisseur of all things Kia
20 year Kia salesperson
2018 Stinger GT AWD Sunset Yellow
30k miles
-JB4 w/bluetooth
-Burger Tuning pedal tuner
-Factory NGK plugs gapped @ .024
-Tork shorty intake
-ADD1 3.3v oil catch can
-Removed factory mufflers
-Firestone Indy Firehawk 500's
Default 01-04-2020, 03:30 PM
Not heard of much damage but have heard of lots of sub-4 second 0-60mph times. Overall it's been solid. Just don't over do it on the launch.
Default 01-23-2020, 11:19 AM
So if this is messing up the GT2 due to the shift by wire and other amenities, terry do you for see trying to work this somehow into the JB4, or is there no way of doing it? I would like to do it, but I have a GT2 and I'm not going to induce some issues if it is causing some on peoples cars already.
Beefer's Avatar
Beefer Beefer is offline
Car: Genesis G70 3.3T
Default 01-23-2020, 12:12 PM
Yeah...really wish there was a way for the JB4 to do this. That way there could be a safety involved.
I really don't want to snip any wires.
Waiting to see if Terry & Co. comes up with something...or if someone else has a brilliant non-snip solution.
2019 Genesis G70 3.3T AWD Sport
EdsNotHere EdsNotHere is offline
Car: 2019 G70 3.3T
Default 01-24-2020, 10:58 PM
So those of us with rear wheel drive and no Auto stop start system should have no issues correct?
Default 01-25-2020, 10:31 AM
The DIY is what it is this point and a wire cut is required to enable it.
As far as I know it generally works on all models including GT2, although there is some variance in how the launches themselves work which others will need to attest to. Our development RWD GT zero issues.
Car: 2019 G70 3.3T
Default 01-25-2020, 02:33 PM
Looks like the wire on the brake light switch may be the same wire.
Official 0-60 1/4 mile thread | Page 5 | Genesis Forums
Danny5's Avatar
Danny5 Danny5 is offline
Car: Kia Stinger GT1
Default 01-28-2020, 10:26 AM
I did this mod yesterday, but since I have a RWD GT1, is this just for the smoke show? Anyone figure out how to utilize this on a RWD car?
Vortex3.3 Vortex3.3 is offline
Car: Genesis g70
Default 02-03-2020, 10:46 PM
Depends on your rear tires. I’m rwd with a g70. I have sport cup 2 rear tires that are 285 wide. Air down to 18 psi. Do a quick burnout to mid second gear. Then launch at about 2350-2400 rpm. Was roughly 4-5 psi of boost but I hit my best 0-60 of 4.40 and helped me shave .32 off my 1/4 mile. 2.00 60’ was my launch for this run. Normal lc only got me a 4.62 0-60 and best 60’ was 2.109. Also in Las Vegas with a da around 6500
Danny5's Avatar
Default 02-04-2020, 08:11 AM
Originally Posted by Vortex3.3
Depends on your rear tires. Im rwd with a g70. I have sport cup 2 rear tires that are 285 wide. Air down to 18 psi. Do a quick burnout to mid second gear. Then launch at about 2350-2400 rpm. Was roughly 4-5 psi of boost but I hit my best 0-60 of 4.40 and helped me shave .32 off my 1/4 mile. 2.00 60 was my launch for this run. Normal lc only got me a 4.62 0-60 and best 60 was 2.109. Also in Las Vegas with a da around 6500
Do you leave TC on?
Car: Genesis g70
Default 02-04-2020, 11:07 AM
Yes. Leave everything on. You don’t have to. But I have had better launches with it on. Just mess around with a bunch of different ideas and see what works for you
Car: Genesis g70
Default 02-04-2020, 11:10 AM
Yes. Leave everything on. You dont have to. But I have had better launches with it on. Just mess around with a bunch of different ideas and see what works for you
Default 02-16-2020, 05:11 PM
I've heard rumors that the brake wire can be located at the brake pedal assembly and it might be possible to make a plug and play adapter for it. When time permits I'll try to confirm it and chase down the required connectors.
Beefer's Avatar
Default 02-16-2020, 05:16 PM
That would be brilliant...thank you!!
Car: 2019 G70 3.3T
Default 02-16-2020, 08:27 PM
Yea the only connectors Todd could find on the Genesis board were about $150 each.
Default 02-16-2020, 09:13 PM
We're working on it!
djerickd djerickd is offline
Car: 2019 GTS
Default 02-16-2020, 09:31 PM
Whaaaaaaat?!?!
Car: 2019 GTS
Default 02-17-2020, 08:46 AM
Maybe u can simply unpin it at the pedal??
