(#2776)
Default 12-03-2019, 11:00 AM
Originally Posted by Soccerstyle
Got my WMI kit installed and wanted to see if you would check this log please.
Short run but seems OK. Update to v11 firmware so we see timing in all 6 cylinders next.
GenesisG70 GenesisG70 is offline
Car: GenesisG70
Default 12-03-2019, 02:33 PM
HI .sorry if this is in the wrong spot haven't posted much. I own a G70 Genesis 3.3.Not a lot of guys tuning the g70 as much as the stinger. mechanicaly the same engine. Installed Jb4 with fuel wires ..BMS Iintakes .changed to the recomended Denzo Spark plugs.Gaped at 24. In my geneses g70 , stock plugs were gapped to 34 just like the stinger.anyway map 2 is the highest I can go .Runs great .4.2 to 60 (mph) 1/4 in 12.5 . Map 3 breaks up at WOT and high RPM .I used a E30 mix .with map 3 ,because its recomended .do you think I could still have spark blow out at high boost with this gap at 24 I did log this run with the break up.on map 3 .But not sure what to look for.I will try to attach it here ..if I do t atach it .Its because I havnt figured iut how
Car: GenesisG70
Default 12-03-2019, 02:48 PM
Could not attach it .sent the file to burger motor sports.
Default 12-03-2019, 05:35 PM
OK we'll keep an eye open for your email.
Soccerstyle Soccerstyle is offline
Car: Kia Stinger
Default 12-05-2019, 07:42 AM
Got a couple logs in, 40mph-115mph and 0-100mph. Can you check to make sure everything looks good. Wondering if I need to adjust any WMI settings.
Default 12-05-2019, 09:16 AM
Looks really clean to me. Could raise the additive up 5 or 10 if you want to push a little more boost.
bbrillon998 bbrillon998 is offline
Car: Stinger GT AWD
Default 12-05-2019, 03:53 PM
What is the recommended octane mix for maps 5 & 7 ?
Default 12-05-2019, 04:03 PM
Half or more mix of unleaded race fuel. The stronger the mix the better.
Car: Stinger GT AWD
Default 12-05-2019, 04:29 PM
Thanks, I plan to use Sunoco GT260 unleaded 100 OCT one station sells its reliably. Ill just run the tank to near empty and pump in 1-2 gallons total if i mess with those maps. Its a blessing in a state where max pump is 91 Colorado.
Default 12-06-2019, 08:27 AM
That should be fine! I use Sunoco GT260+ when I can find it.
rboettcher81's Avatar
rboettcher81 rboettcher81 is offline
Car: 2019 Kia Stinger GT
Default No boost now... - 12-11-2019, 06:05 AM
Hey so this morning because we were expecting a light snowing on the way to work, I thought I'd run Map 4, the valet map to cut power just to try it out.
I floored it to see what kind of boost I'd hit and quickly something didn't "feel" right so I let off. Floored it again and watched the boost gauge do nothing.
Switched to Map 0, floored it and again, no boost. Also AFR is weirdly hanging in the 14's, which for WOT seems WAY lean. So the entire 30 min trip to work, the car would not build boost. Cruising was fine but had no balls what-so-ever.
I believe I was on v10 firmware. I updated it to v11.3 just now after digging around for answers.
Anyways, I haven't found anything definitive. First time I've encountered an issue. Car has around 4600 miles, BMS intakes and Denso plugs @ 0.022 gap. Temperature was 34 deg F.
Any insight would be appreciated. Thanks.
BTW, the screenshot of the log with a 7:16am timestamp is Map 4 when it first went down. You can see boost peaked to about 12psi (which seems too high for Map 4), then the ECU closed the throttle and stuff goes a little wacky. Shortly I release the pedal as you can see.
Second screenshot with 7:11 timestamp is Map 0 (stock) and a pull in 3rd gear. No boost, and an AFR in the mid 14's pretty much the entire pull which makes me feel uneasy.
What the heck is going on?
UPDATE: So at lunch I took a drive, and she seems to be back to normal. Builds boost stock as usual and I tried Map 1 in 3rd with no problems. Did a quick 3rd gear pull from 2k-5k, held boost around 14-15psi. I guess I triggered some kind of fail-safe mode this morning. I also upgraded the firmware but not sure if that had any bearing on the situation. I'll run Map 2 as usual on the way home and do a full highway send for a log.
Car: Kia Stinger
Default 12-11-2019, 09:10 AM
Has anyone installed Ultimate Performance HFC down p I p e s and mid p i p e s on there Stinger 3.3tt? The set up has uses an extension to keep the secondary o2 out of the stream to keep the CEL from coming on. Does this affect how the JB4 reads and adjust?
Jsron905 Jsron905 is offline
Car: Stinger gt
Default Help - 12-11-2019, 09:49 AM
I just installed denso plugs gapped to recommended specs running 93 octain map zero and car runs ruff and smell gas???
Car: Stinger gt
Default 12-11-2019, 12:40 PM
Problem solved.
Default 12-11-2019, 09:43 PM
Would need the CSV for any sort of log analysis.
Default 12-12-2019, 07:21 PM
No problem. CSV files attached.
Default 12-12-2019, 10:26 PM
Looks like map4 triggered a low boost mode in the ECU, even lower boost than map4 was targeting. I'm working on a revision for the valet map, email me and I can send you the firmware to test! terry@burgertuning.com
StingerLover StingerLover is offline
Car: 2018 Kia Stinger GT AWD Limited
Default Logs during dyno - 12-13-2019, 03:59 PM
I tried manually logging using the JB4 map during dyno pulls today. First was Map 3, then Map 2, and finally Map 0 (the Map 0 log file is zipped to fit the upload size restriction).
My 2018 Stinger GT AWD has Denso 5346 plugs gapped to 022, JB4 of course, DIY intakes, and MBRP stainless *** back.
I was running a full take of Shell 93 + 11oz Boostane Professional, which should have put the octane at about 99-100.
Map 3 returned a lower 380hp/445tq than Map 2 at 382hp/464tq, and they seemed to think (without logs) it might be pulling timing. Map 0 returned 325hp/405tq.
These numbers were off of a linked DynoJet.
Any helpful feedback is appreciated.
Default 12-13-2019, 04:31 PM
Hey guys, finally added gear (read from trans) and trans oil temperature to the JB4 logging. Need a few guys to log and confirm it's working right. Drop me an email if you have time this weekend for a log or two.
Default 12-13-2019, 04:32 PM
The bad news is I don't see anything in these logs. It's possible your OBDII/CANbus system was off, so all runs would be basically on map1 without fuel control. e.g. sort of useless.
Beefer's Avatar
Beefer Beefer is offline
Car: Genesis G70 3.3T
Default 12-15-2019, 02:35 PM
Terry...hope all is well.
I actually pulled out my JB4 for the first time last week. While it was out...I finally installed the Fuel Wire extensions that @ecko04 hooked us up with.
I put everything back...and logged 4 runs. Can you take a gander? All Map 3...99 octane (booster).
Wanted to make sure the Fuel Wires are working...and that all else looks kosher.
I see that the AFR/AFR2 values are moving up/down...so I assume that both are hooked up good.
Thank you...and Happy Holidays !!
2019 Genesis G70 3.3T AWD Sport
Default 12-15-2019, 06:32 PM
All looks good to me. Fuel trims match up bank to bank and drop as fuel enrichment increases. Boost looks good as does timing and AFR.
Default 12-15-2019, 06:35 PM
Added v12 BETA firmware to the first post to get a few more logs in. After 30 or so people have downloaded it I'll temporarily remove the link.
For those who were helping via email what is posted is the same as the "_T4" version.
Ahawk Ahawk is offline
Car: Kia Stinger
Default 12-15-2019, 08:13 PM
Hey Terry, with v12 firmware addition of gear info, do you think true boost by gear might be in the pipeline?
atr1 atr1 is offline
Car: Stinger GT
Default 12-15-2019, 08:19 PM
If my understanding is correct, it is already implemented in this version.
