(#2701)
Default 10-08-2019, 12:50 PM
Originally Posted by kcranmer
ok. I'll get the data cable and try the firmware upgrade. The latest version is 11_3 it looks like is that correct? Also, Do you think closing the gap on the factory plugs would help the idle?
Yes or swapping them. On the 4bangers the plugs are easy to reach.
psykostevo psykostevo is offline
Car: 2019 Kia Stinger GT1
Default 10-08-2019, 08:43 PM
Crap, what did I get myself into? This isn't like I remember with my 87 Mustang LX 5.0 20 or more years ago!! I ordered a plug gapping tool last night. I just read something over on a stinger forum about changing the plugs and it seemed like a process. I have climbed under a hood in a long time and just remember wrenching out the old and putting in the new. Is this something I really shouldn't tackle myself? I never heard of spark plug blowout prior to today and not I'm not so confident I should be tinkering with a brand new car but I'm sure I still will. Just don't want to F it up just to gain a few HP.
Only two of the plugs are a pain to reach. But use the flex joints on your ratchet so that you don't have to take the intake manifold off. Even then they are still a chore, but nothing as complicated as a full upper intake manifold removal.
Beefer's Avatar
Beefer Beefer is offline
Car: Genesis G70 3.3T
Default 10-09-2019, 01:51 AM
^ or just pay $100-$130 and get a guaranteed professional to do it...like I did.
You paid this much so far...why cheap out now? Unless you love doing this stuff of course.
2019 Genesis G70 3.3T AWD Sport
Team Tonka Team Tonka is offline
Car: G70
Default 10-09-2019, 06:54 AM
Terry, can you check these out please. I increased the settings to 4.3 for Map 6 boost at 1500, 2000, and 2500 RPM.
First is a 0-60 run
Second is just short drive from a stop.
Thx!
Originally Posted by Team Tonka
Oops. I think I entered my values incorrect.
I'll try 4.3 @ 1500RPM and 4.3 @ 2000RPM and try again.
Manchuz Manchuz is offline
Car: 2018 Kia Stinger GT Ltd
Default 10-09-2019, 08:04 AM
Hello, new member here and new owner of JB4. Can you kindly look at my map 1 readings and see if they're fine.
Dumb question, but how do you know if you've installed the fuel wires correctly? Can you see it in the readings? I installed the plug and play cables and did a bit of hack and slash job on the wires to add quick disconnects.
|Denso @ 0.022|CAI|91 octane|v11_3|not sure what my elevation is
Default 10-09-2019, 09:19 AM
First is a 0-60 run
Thx!
Seems fine to me
Default 10-09-2019, 10:04 PM
Been doing it 20 years, I like doing this stuff.
atr1 atr1 is offline
Car: Stinger GT
Default 10-11-2019, 04:44 AM
Hello
I did the firmware update to the v11 and my user adjustment values are weird.
I have never set a map6 but all is filled with values,
and my boost safety is set to 28.9 (was 21).
N20 TMAP is also set to 1 and I have no clue about what it is.
WMI settings also changed a bit.
I am very worried.
Did I do something wrong?
(I updated from v9 to v11 skipping v10)
Default 10-11-2019, 07:54 AM
All normal. After loading v11 you'll need to recale your map6 and boost safety values back. TMAP will remain at 1 (you can't change it to 0).
Car: Stinger GT
Default 10-11-2019, 08:31 AM
Indeed I tried to disable it and it didn't work.
(I panicked and reverted to version 9 lol)
Default 10-11-2019, 08:56 AM
Default 10-11-2019, 09:43 AM
Then you'll have to redo all your settings again for the scaling change.
Default 10-11-2019, 09:44 AM
Log looks OK. You can check the fuel wire performance via the fuel trims. If they are dropping as fuel enrichment goes up, and relatively close together, your fuel wires are working properly.
Thumbs up 10-11-2019, 01:42 PM
Awesome, thanks!
kcranmer kcranmer is offline
Car: 2020 Kia Forte GT
Default 10-16-2019, 02:17 PM
Finally got the cable and upgraded to v11. In reference to Atr1's experience upgrading, is there anything else I need to do after the upgrade? I am only using Map 1.
Also, I want to confirm it has seemed to smooth out the idle. I did notice when revving the engine up it occasionally has a pop when I lift off the gas. I haven't gapped the stock plugs yet because I don't know the torque needed when putting them back in. So that leaves me with 3 questions. Do you think the pop is coming from the plugs not being gapped properly? Does anyone know what torque is needed on a 1.6L Turbo? Finally, I wanted to leave the data cable plugged into the JB4 and run the cable through the fire wall into the cabin of the car but the case is not capable of closing due to a piece of metal in the top half of the housing hitting the connector of the data cable. Is the case not designed to keep the data cable plugged in?
2020 Kia Forte GT
JB4 Map 1
Default 10-16-2019, 09:26 PM
You remove the shell on the data cable to mount it in the box, see video:
JB4 Mobile How To - YouTube
Default 10-17-2019, 04:28 AM
Shoot, I forgot that was in the video. I watched it before I got the cable and should have watched it again I guess. Thanks.
2020 Kia Forte GT
JB4 Map 1
djerickd djerickd is offline
Car: 2019 GTS
Default 10-17-2019, 07:25 AM
Hey Terry I noticed mine doesn't display some of the guages like, trans temp, gear, oil temp. Is it supposed to??
Default 10-17-2019, 08:17 AM
It's normal as not all parameters are connected to the Q50
suwon5788 suwon5788 is offline
Car: stinger
Default hybrid turbo system. - 10-19-2019, 09:42 PM
hi terry
when launching?
and..
how much?
TerdBath TerdBath is offline
Car: G70 3.3
Default 10-20-2019, 11:41 AM
Does the bit7 “on” work with any map? Currently running map 2 on 3.3 g70 AWD.
Default 10-20-2019, 08:54 PM
Originally Posted by suwon5788
hi terry
when launching?
and..
how much?
It's not a BMS product. Check with Pure Turbos for their Stinger offerings.
Yes the option is global for all maps.
Car: G70 3.3
Default 10-21-2019, 06:56 AM
Good to know Terry. In the WRX world the Accessport did something similar. That turbo 4 would lag down low then all of a sudden give 100% turbo mid turn when merging into traffic from a stop. The Accessport changed the turbo delivery to make it more predictable/linear. I'm still in the break in period so have taken it easy so far with the G70. Only 100 more miles before I can really start playing around.
FlooF FlooF is offline
Default Just Wow! The JB4 Tuner is Awesome - 10-21-2019, 06:42 PM
Good Evening Terry,
Thank you for developing such a wonderful tool.
I have attached my logs of my most recent run and was curious to your opinion.
I have the BMS intake and JB4 running on Map2. Ambient temperature was 82F and humidity was about 95%.
My best 0-60 times are about 4.7 Seconds.
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
RUFFSTUFF
