135ilove 135ilove is offline
Default 640 WHP N55 135i DCT - 06-27-2019, 10:54 AM
Hey guys I threw my 2013 135i n55 dct with a big boost exhaust manifold, 6871 comp turbo, turbosmart wastegate, stage 3 fuel it lpfp, jb4 w/mac solenoid, 100 percent E85 and FBO.
Car made 558 whp @ 18 psi, 638 whp @ 22.5 psi and 600 whp @ 20 psi(not pictured below). When I turned the boost up I started to get spark blowout on the top end because my spark plug gap is too big. I have also attached a log from a street pull below with the same flash tune that I used on the dyno.
2013 DCT Jet Black 135i
-JB4 Stage 2 ISO/w Flex Fuel Wires-Fuel it Stage 3 Bucketless LPFP-PDU Port Injection-Big Boost 6564 Bottom Mount Turbo Kit-Big Boost Chargepipe-Active Autowerke-BOV-Injen SP Intake with Blox Velocity Stack and Turbo Guard Filter-VRSF 7.5 in Stepped Race Intercooler--BMS OCC/OCV/CF-N20 TMAP-N20 Plugs-Motul 300v 5W-40-Archoil 9100-Motul Mocool-Custom 3.5 inch Straight Pipe Exhaust-Stoptech Rotors/Fluid-PFC Track Pads-VMR 710-Toyo R888r-M4 Flywheel- SSP R Clutches
Default 06-27-2019, 01:45 PM
Log looks really good!
AFR, trims, boost is all where they should be. PI is firing as well, so that's good.
HPFP is nice a steady. Just had little timing pull on cyl 5 but other than that, it's healthy!
Default 06-27-2019, 02:08 PM
Thanks for the review. In terms of cylinder 5 dropping timing I’m almost certain that’s because of spark plug gap that give me spark blowout once I turned it up on the dyno
Default 06-27-2019, 02:31 PM
Originally Posted by 135ilove
Thanks for the review. In terms of cylinder 5 dropping timing Iím almost certain thatís because of spark plug gap that give me spark blowout once I turned it up on the dyno
Yea, no big deal. Just tighten the gap a bit more. I run .018" on my N54 with the NGK97506
Default 06-27-2019, 03:27 PM
What coils are you running? Iím running ngk 95706 @ 0.025Ē with PR coils
houtan houtan is offline
Default 06-28-2019, 08:58 AM
Nice result!
You end up getting a used M4 flywheel?
Who is doing the flash tune?
Default 06-28-2019, 09:02 AM
I'm using Delphi GN10571. No issues at 800+whp
Default 06-28-2019, 10:26 AM
Originally Posted by houtan
Nice result!
Yes Iíve been a used m4 flywheel and Ssp r clutch packs for a little over a year now. Pure evil tuning made the flash tune for the car
Default 06-28-2019, 10:27 AM
I used to run a gap of 0.018 when I was stock coils but I raised it up to 0.025 when I went PR. Iíll lower the gap back down to 0.020 and go from there. There is definitely a lot more power left in the car boost wise
M-terkait's Avatar
M-Terkait
Car: F30 335i
Default 06-30-2019, 12:18 AM
isn't that just too much timing :o, i see ign# over 10's.
nice numbers tho.
N55 - Doc race 6266.
luchocamp's Avatar
Default 06-30-2019, 06:56 AM
Keep it up !
15 BMW M4 Full Weight 10.69@133mph stock turbos SOLD
18 BMW XXXX Car in Process
Default 07-01-2019, 08:37 AM
i think the lag makes tuning easier and with cleaner logs (from what I have seen). The speedtech spools so early it makes tuning tip in a real PITA
KevinC39 KevinC39 is offline
Car: 335i 6MT RWD
Default 07-01-2019, 09:05 AM
Are you doing the MHD tune yourself? I was thinking of having twisted tuning or someone do mine. I'd be going flash only though
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 07-03-2019, 11:08 AM
nice numbers tho.
The timing he is running is perfectly fine since he has the octane to support it.
Default 07-05-2019, 12:07 AM
nice numbers tho.
No 13.5 degrees is right where I like it, MBT is around 15-16 degrees on these cars so thereís still power to gain with increased timing on my car
Default 07-05-2019, 12:11 AM
Idk why but my car spools slower on the dyno than the street. Also this is a much bigger turbo than what the speed tech kit runs
Martin.328 Martin.328 is offline
Car: 16 328
Default 07-13-2019, 06:26 PM
Because the dyno is less load than on the street
Default 07-18-2019, 10:22 AM
Load.
Awesome #'s btw
any vids of this thing in action?
Sticky Sticky is offline
Car: M3
Default 07-18-2019, 06:31 PM
Got an engine bay pic? Pics of the car? I think this deserves a feature.
TurboTom TurboTom is offline
Car: 2013 E82 135i
Default 08-01-2019, 08:12 PM
If you don't mind me asking, what did the trans upgrades run you with labor? I'm building my 135i, if I can keep the damn thing alive until the turbo arrives. $3,500 in maintenance in the last 2 months and something else broke tonight. I'm a bit concerned about the DCT with the Pure S2. Thanks!
Zackman218 Zackman218 is offline
Car: 2011 BMW 335i M-Sport
Default 08-02-2019, 07:59 PM
I have 2011 335i with N55 Its full bolt on. mod list; walbro 450, jb4, mhd bef, intercooler, ******* **, gfb diverter valve, ARM intercooler piping, ARM chargepipe. I peak at 18-19 psi and am running e50 with the mhd bef e85 bin. Anyone have any ideas what horsepower numbers I'm at? Cause I see ur at 18 psi making 550 but I'm assuming that has a lot to do with more aggressive timing and 100% e85 or is there something I'm missing?
Stoolz Stoolz is offline
Car: 11 135i
Default 08-02-2019, 10:20 PM
You'd be around 400.
You're missing his BIG turbo.
fryj00's Avatar
fryj00 fryj00 is offline
Car: 2011 e92 n55 xDrive 6MT
Default 08-08-2019, 04:58 PM
You would be missing the air density. Larger turbos move air more efficiently so they don't heat the intake air as much as smaller turbos. That is why they make much more power at the same boost levels. Less heat = more dense = more oxygen molecules per pound of boost. The price you pay for that efficiency is greater lag in the turbine responsiveness.
-Bryan
2011 E92 N55 xDrive 6MT
Default 08-12-2019, 09:34 AM
Thank you, sorry about the late reply but its not letting me upload any of the photos or videos. Maybe I can email them to you.
Default 08-12-2019, 09:35 AM
Load.
Awesome #'s btw
I would post some but its not letting me upload any attachments
