(#2001)
Okierican Okierican is offline
Car: Kia Stinger GT2
Default 04-09-2019, 07:39 AM
Originally Posted by P4RTYH4RTY
.022
Thank you my friend. Glad I checked before I started. I was about to install them at .026 😬
snipe99999 snipe99999 is offline
Car: Stinger GT
Default 04-09-2019, 10:35 AM
So I have been running into an issue where the JB4 mobile app will connect to the JB4 and it'll show me that MAP 2 is selected but nothing else is working. The RPM, IGN, AFR, IAT which all used to work now all sit at 0. Sometimes if I stop the car and shut it off and unplug and reconnect the ODBII wire it'll start working again. I just noticed this recently and was wondering if there is a way to tell if it's just the app not working or if the JB4 isn't getting the signal either. Also any thoughts on what I can do to troubleshoot.
I also just noticed this after upgrading to the latest firmware but honestly I wasn't really looking that often before upgrading so it may have been always happening.
Thanks for any suggestions or feedback.
DaBears4Lyfe's Avatar
DaBears4Lyfe DaBears4Lyfe is offline
Car: Kia Stinger GT1
Default 04-09-2019, 11:22 AM
I had the same issues for a while. After working with terry, i noticed that If i took apart the JB4 plugs cleaned everything (connections) and did the same with the OBD plug it works. Issue comes back every couple months but a simple unplug and wipe it fixes the issues.
Car: Stinger GT
Default 04-09-2019, 12:09 PM
What did you clean them with and which ones did you clean? Just the ODBII side in the car? Or are you talking about the connections to the TMAP and MAP sensors as well?
Did you determine that the JB4 wasn't receiving the signal or just the mobile app?
Default 04-09-2019, 12:27 PM
Generally an issue with the OBDII cable either between cable and car or cable and JB4 harness.
Car: Stinger GT
Default 04-09-2019, 12:31 PM
Do you have a suggestion on what to do to resolve it? I have unplugged it from the interior connection and reconnected it. I will re-seat the other end as well. What if that doesn't work?
Default 04-09-2019, 01:42 PM
Normally first step is to email support in and ask them to send you another OBDII cable to rule out the cable itself being damaged.
Fools Fools is offline
Car: 2019 Hyundai Veloster N
Default 04-10-2019, 02:57 PM
Hey Terry, what would be the best way to contact you? I have a 2019 Veloster N and have a few questions regarding the jb4.
Default 04-10-2019, 04:45 PM
Easiest way is to just post your questions here, or make a new thread if you prefer.
Default 04-10-2019, 04:52 PM
Are you still looking for trial vehicles for the jb4? I saw it works for the veloster n but have not seen any posts or data on the specific car.
Default 04-10-2019, 06:20 PM
It's a supported model. We've shipped a few without issue! Once installed if you want to post or send in logs we can always double check it with you to ensure it's working properly.
NLJ NLJ is offline
Car: G70
Default 04-11-2019, 06:30 AM
Does the fuel wires add any HP when used on Map1 or Map2 on 91-93 Octane?
Or is it only for E85 fuel mixtures and up?
Thanks.
Car: Stinger GT
Default 04-11-2019, 06:42 AM
Thanks.
They allow the JB4 to alter the air/fuel mixture and are beneficial with all MAPs not just the E85 and up.
If you look at the dyno results on the JB4 site you can see that MAP 1 without fuel wires was 356.85 WHP and 465.25 torque. With the wires MAP 1 was 377.69 WHP and 462.50 torque.
NLJ NLJ is offline
Car: G70
Default 04-11-2019, 06:48 AM
Sorry I don't see that anywhere on their site. I only see Stock and Map1 with fuel wires. Not Map1 without and with.
Can you link me to it please?
Car: Stinger GT
Default 04-11-2019, 06:51 AM
2018 Kia Stinger JB4 Tuner | BurgerTuning.com
You will see a graph for Stock vs. JB4 maps basic install and one that says Stock vs. JB4 with fuel control active.
NLJ NLJ is offline
Car: G70
Default 04-11-2019, 07:05 AM
I see now. Thanks. So it looks like it upped the HP quite a bit but dropped the TQ a tad.
Maggei82 Maggei82 is offline
Car: Hyundai i30N
Default 04-11-2019, 11:34 AM
Hello guys,
does anybody know where i can find the primary O2 sensor from mi Hyundai i30N!
I think it‘s the same like the Veloster N.
Default 04-11-2019, 04:17 PM
It's right on the exhaust manifold, white wire is the one you posi-tap. I have a photo somewhere will track it down later.
CursingDingo CursingDingo is offline
Car: Kia Stinger GT
Default 04-12-2019, 07:37 PM
Got a couple logs from my last trip to the strip. All 12.3X runs.
Mods are Intake, Midpipe, IC, e30 Map3/5. Had no issues with traction but couldn’t get a sub 2.0 60’
Any feedback would be appreciated.
pgeneste pgeneste is offline
Car: Kia Stinger 3.3T
Default 04-12-2019, 08:39 PM
Mods are Intake, Midpipe, IC, e30 Map3/5. Had no issues with traction but couldnít get a sub 2.0 60í
You mean sub three's i.e. 3.X sec for 0-60...
That is where you should be...
P4RTYH4RTY P4RTYH4RTY is offline
BMS Fanboy
Car: 2019 Kia Stinger GT RWD
Default 04-12-2019, 08:41 PM
He said 60 ft time, not 0 - 60 time.
Default 04-12-2019, 09:41 PM
Log looks clean. How are traps?
Default 04-12-2019, 10:03 PM
LoL sorry CursingDingo, little late here. But looking at your Map5 (hard due to log resolution) but it looks like your 0-60 is ~3.93 sec. Not bad... but suggest a Dragy or Torque App to get the detail you want. Both use the accelerometers + GPS to get 100 Hz resolution. Like Terry said what were your trap times ? Also just as a FYI looks like you Timestamps are ~1/2 of real time. (?!?)
Car: Kia Stinger GT
Default 04-13-2019, 08:28 AM
114.94 - 116.02 across four 12.3 runs.
Car: Kia Stinger GT
Default 04-13-2019, 08:30 AM
How do I improve log resolution?
I have Draggy and was running for most runs but a few got messed up because it started the run when I tried to spin the tires before staging.
Iím not sure what you mean by timestamps are 1/2 of real time?
