Default Stinger WMI (water meth) Discussion - 11-11-2018, 12:07 PM
Oh what a difference JB4 controlled WMI makes. Couple of logs from the NFZ half mile racing event Saturday. Mods are JB4, 30% E85, BMS intake. Map5 (no meth) vs. map8 (meth on, 70 additive). With BMS WMI 146mph, without only 139mph. Videos to follow.
Install guide: http://www.n54tech.com/flash_files/s...mi_install.pdf
Default 11-19-2018, 10:04 PM
Stinger/G70 WMI game changer coming soon...
Default 12-01-2018, 01:04 PM
Just added our new PNP WMI adapters to the website. Someone asked what a Stinger WMI kit might look like so I put together a sample in the shopping cart.
Default 12-11-2018, 11:07 AM
Here is a quick WMI install guide: http://www.n54tech.com/flash_files/s...mi_install.pdf
sym sym is offline
Car: Stinger
Default 12-11-2018, 12:13 PM
Thanks Terry! Looks like this install can be as clean as the installer is willing to make it
Quick question, you say in the guide:
Once routed carefully reattach the fuse box cover over the FSB power wire. If you run in to an issue with WMI not turning on, this power wire coming loose or not being properly secured will be a primary suspect. Note, we strongly suggest SWITCHED power for the FSB. Resist the urge to use the easy to reach/attach to CONSTANT power sources.
Does this just mean we should avoid wiring the fused 12V to an always on supply (like the battery) versus a relay switched fuse, or is this saying we should add an external cut switch?
sym sym is offline
Car: Stinger
Default 12-17-2018, 10:15 AM
Since there's a thread for this now, I figured I'd add my thoughts on the WMI install:
1. Probably took 2ish hours total. Hardest part of the install was definitely routing the hose and wire through the firewall, and then under the paneling in the car. I ended up pulling off the passenger kick panel, and the passenger door sill panels for the front and rear doors which made the process a lot easier. As it stands now, you can't see the hose in the car as a passenger which was my intent.
2. If you have the factory remote start system, it makes the install a lot harder. The kit takes up a lot of space near the passenger side firewall. I had to remove a part of it and put it back in order to fish the line through.
3. All of the compression fittings I needed were included with the kit. Don't forget to use silicon / teflon thread sealant on the threaded connections (not necessary on the hose side of the compression fittings though).
4. A yellow stake-on fork was used for the FSB fuse connection. It would be in your best interest to have a set of stake-ons for the install. The wire nuts worked well but I replaced several of the fork connections to the chassis with ring connections.
5. The JB4 itself is starting to look like a bird's nest. I'll have to work on that if I find some time...
Final note, I do have some concerns about the billet injection nozzle not getting enough air flow across the element to accurately reflect the IAT. I will need to do some more testing and troubleshooting to confirm this. But looking at my old logs vs. new, there seems to be a much higher difference between IAT and ambient.
Default 12-17-2018, 10:40 AM
IAT is sampled at the intake manifold sensor, not the pre-throttle sensor, which is used for boost only. Was the first thing we confirmed.
sym sym is offline
Car: Stinger
Default 12-17-2018, 11:02 AM
That's great to hear. It probably has a negligible impact then, vs if it was being used for AFR control.
I'm running V7 firmware with WMI now, everything is good so far. I'll have some logs for you soon.
Stinger0618 Stinger0618 is offline
Car: Stinger gt2
Default BMS WMI review - 12-24-2018, 09:17 AM
Happy holidays to everyone!! Just wanted to write up a little review on the BMS water meth kit with jb4 integration. I installed my kit this weekend. Everything that is needed is pretty much included but I would grab a pack of the assorted electrical connectors to possibly clean up the install a little bit. The kit installed very easily and took a total of around an hour and half to two hours with a friend just taking our time.
Before the stinger I came from a built motor big turbo golf R that had a snow stage 2 WMI kit on and honestly I like this BMS kit much better. Originally I was driving around and felt that the WMI should come on a bit sooner, it felt as though it waited until 90% throttle to come on which to me felt a little late but at the same time you donít want it spraying when itís not needed. I shot an email to terry with my suggestion of WMI hitting at 75% throttle. He shot me a beta file back within minutes of map 8 having WMI come on around 50% throttle above 8psi and it is PERFECT. Prior at 90% I really was only using WMI on the highway but now itís spraying on backroads when getting into it for a little bit and you can really feel it as it starts spraying. Iím on a 65 additive so there is still more to go. Drivability is perfect and the car is evenmore fun.
You really canít go wrong with this kit. Also I suggest using silicon on all of the fittings as some of them leak a little bit. BMS suggested it in the instructions but I didnít use it with my last kit so i left it out. Kicked myself for it after bc each fitting leaked a small amount one by one but once I used the silicon everything is perfect. That was my own fault but figured Iíd mention it in case anyone else wants to skip the silicon on the fittings.
Here is a log doing a highway pull. Everything looks great to me.... what do you think terry?? Everything look good?
Default 12-24-2018, 10:00 AM
Looks good to me!
Car: Stinger gt2
Default WMI additives - 12-26-2018, 05:42 AM
terry,
right now i have the App set to a 65 additive and from the logs in my above post you can see they look good. if i was going to be playing around at a track with some cars can i turn that up to a 75 additive using 93 octane and boost juice only, or would i also have to have some E85 in the tank?
thanks.
Default 12-26-2018, 09:23 AM
More octane always helps, for track use i'd add in a couple gallons of E85 or a can of MMT based octane booster if you can. Then crank it up.
dgascho dgascho is offline
Car: Cobalt SS/TC 502whp
Default 01-08-2019, 11:34 AM
Hoping to soon get WMI set up on my car. Can you comment on the appropriate boost additive? I hear some are at 65, yours at 70, etc. Any reason why I should leave it at the 50 advised in the install document?
Also, if I'm running map 8 (E30 blend in the tank and WMI on) and decide I want the WMI off for some reason (wife daily driver to work), it's as simple as simply switching the map back to 3 or 5 or something appropriate for the E30 that's still in the tank?
BHR Stinger BHR Stinger is offline
Car: Stinger 3.3T
Default 01-17-2019, 07:22 AM
Hey Terry, I would like to buy the adapter and incorporate it with the Snow kit I have.
What are the thread sizes for both the inlet and outlet on the adapter? I just want to make sure the Snow inlet fitting and nozzle will work.
JB4 - Denso 5346 - AEM Intake - VT Snorkels - Snow WMI - NGT Primaries - JUN BL Mid-pipe w/200cell HFCs & EVC c@t-back - Radium OCC x2
Default 01-17-2019, 09:32 AM
1/8" NPT. You'll need a BMS nozzle for the adapter too I'm sure.
Default 01-17-2019, 09:33 AM
You'd have to evaluate and set it properly for your fuel, mods, climate, risk level, and power objectives. Start slow at say a 40 additive and go from there.
Car: Stinger 3.3T
Default 01-17-2019, 01:04 PM
Because of different size thread or nozzle length, cause I believe the snow nozzles are 1/8" NPT as well.
(#1) 60 ML/MIN Hyper-Sonic Water Methanol Nozzle
they are longer due to the filter, i am not sure if that will be a fitment issue as well.
snipe99999 snipe99999 is offline
Car: Stinger GT
Default 01-18-2019, 07:19 AM
I am very new to the WMI concept but it really interests me. I have some specific questions that might sound really dumb but I think this is the correct place to post them. If not please point me in the right direction.
1. My Mods are just the JB4 and the BMS intake do I need or would I benefit from any other mods before running WMI? I run 93 octane.
2. This car is my daily driver and I wouldn't want to run WMI all the time. Is it really as easy as setting it to MAP 8 when I want to run WMI and back to MAP 2 for daily driving? Will that turn it on and off?
3. Is MAP 8 all set in the app or will modifications to some parameters be needed before running WMI? When I installed the JB4 I set it on MAP 2 and nothing else needed to be done and I never looked back. Is it the same with MAP 8 and this WMI kit? I am trying to get a feel for how easy this is to maintain.
Thanks in advance for answering my questions and sorry if they have been answered somewhere else.
Default 01-18-2019, 09:17 AM
1 -WMI will definitely help you with bringing the octane up so you can run higher boost *safer* than just with 93 octane.
2- Yup, exactly how it works! Super simple
3- Map 8 has about 3-4 values you'll need to input, but it's all straight forward. You can always email me and I can help you set it up.
After you set it up, it's good to go.
Payam@burgertuning.com
Default 01-18-2019, 10:46 AM
Yes I just don't know. You'd have to try it. On the BMS setup we put the filter before the solenoid, as it's just as much of a risk point for clogging as the nozzles are.
Default 01-18-2019, 02:57 PM
We have the BOV adapters in stock finally: BOV adapter for KIA Stinger GT 3.3L - BurgerTuning.com
Rather than waiting until we get the valves with the right springs we decided to just offer the adapter ala-cart. There are authentic valves on amazon and ebay with the spring for $260 shipped. And fake Tial valves for a fraction of that for those who prefer that route.
Car: Stinger 3.3T
Default 01-22-2019, 05:12 AM
Is the adapter directional, or can it be mounted either way?
I need the opening to be towards the radiator.
Default 01-22-2019, 12:30 PM
No it's symmetrical.
Car: Stinger GT
Default 01-25-2019, 08:08 AM
Thank you so much for the information.
Any idea when the bolt on stealth bracket will be available?
Also what water/meth product do you guys use or recommend for putting in the tank?
Default 01-25-2019, 02:11 PM
Start with boost juice 49/51 mix as it's really easy. Then you can evaluate down the road. you'll make more power with a stronger mix but it's harder to source.
