(#226)
Fmonteiro444's Avatar
Car: 09 E92 SG
Default 05-16-2018, 01:54 PM
This turbo is absolutely massive!
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 05-16-2018, 04:36 PM
Originally Posted by houtan
I dont even bother asking anymore. Unsubscribed. Canít stand the lack of transparency.
It's a disservice to the community to flaunt partial information when people are trying to consider the product for themselves.
2011 E92 335i Auto Sold
12.0 @ 125MPH JB4
VRSF Chargepipe | BMS Intake | Custom MHD | VRSF 7" Intercooler | ER Turbo Outlet | XHP Stage 2 | AEM Meth Injection | Pure Stage 2 V3 | Pure Inlet | GFB DV+ | AR DP |
Peter @ Pure's Avatar
Car: F20 M135i
Default 05-16-2018, 11:10 PM
what do all these big turbo kits do 100-200 or 60-130? My PB with the PS2 was 6.26 100-200, 7.4 60-130... I would have expected this record to be broken long time ago...
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
luchocamp's Avatar
Default 05-17-2018, 04:34 AM
Great number Pete in your M135i 100-200 6.26sec.
I told in my first post that Pure Turbos are great upgrade.
My personal experience after over 1.5 year and 200 passes trying to improve my e.t. is that in a little heavy F30 335ix and caribbean weather was 11.5@122mph with 1.8 on 60ft. Now ST3 the car is qwicker and faster 11.2@126mph. Same oem fuel system + wmi (7+7) meth. Next week we are going to install Port Injection an increase boost from 21.3psi and see improvements.
A90 Supra Full Weight No Nitrous 10.78@133mph
BMW M4 10.69@133mph Full Weight stock turbos
Default 05-17-2018, 10:02 AM
Logs: Guys I have posted logs and can post more if needed, you can always email me and I can send you something recent. Still dialing it in with just MHD.
@ Peter, Not sure we can compare to your 60-130, best to compare ps2 to speedtech on same car same mods as luchocamp and myself have both done. Car is faster with speedtech, i think its common sense. Not saying speedtech is the best, shoot, i hope someone makes something better, need to move the platform along. I have to say your 60-130 are mutant. Basically your M3 runs with 800-900 whp supras and 997TT and your 135i times are not far behind. Im still tuning, not pushing limits at all, but nowhere near your numbers. What I can say is just think it would be a little faster and engine less pissed off with a proper stage 3 .
luchocamp's Avatar
Default 05-18-2018, 10:21 AM
126.4mph today peak boost 21.9psi .. oem fuel system + wmi (7+7 jets) max out
luchocamp's Avatar
Default 05-19-2018, 09:35 AM
100 to 200kph graphic
Car: F20 M135i
Default 05-24-2018, 02:29 AM
Ofcourse in theory a big single should be faster than a hybrid setup. However it seems in practice it's not so easy. And yes my 100-200 at 6.26 or 60-130 at 7.4 was quite fast. Hence it's a standing record. I have always said 0-100 (0-60) you need grip (xdrive advantage), 100-200 (60-130) power and weight come into play, 200+ (130+) it's mostly power and aerodynamics that you need.
My F20 M135i was quite modded and light hence those monster times with PS2. I must say in all fairness that most PS2 setups when pushed to the max do around 6.6-7.0 100-200 (7.8-8.2 60-130) in ideal atmospheric conditions.
But honestly it should not be too hard if you spend money on a big turbo kit and you take care of fuelling that you get close to these times as well. And eventually when pushing the setup even harder surpass them.
So my post was more of an incent to see some of you guys going for my record As I moved away from the N55 platform I am pleased my times still stand and waiting for someone to take over the top spot
You have posted a lot of Q-mile times, can any of you post 60-130 or 100-200 times as well? Just curious to see where you are at right now.
Kind regards,
Peter
peter@pureturbos.eu
pureturbos.eu
luchocamp's Avatar
Default 05-24-2018, 02:52 AM
Hi Pete... my car running without Port Injection is making 7.0 ~ 7.2sec in 100 - 200 kph. For my point of view 126.4mph at 1/4 mile is most I had seen on F series with oem pump + (7+7 jets 100%meth injection).
In a few days I will start working with Port Injection and we will see improvements for sure.
135idct 135idct is offline
Default 05-24-2018, 06:10 AM
not bad for xdrive, what's ur time on ps2 turbo?
Car: F20 M135i
Default 05-24-2018, 06:12 AM
On the PS2 with meth only (dual CM5/7 setup) and E30/98 ron mix I did around 7.2s (pre inlet upgrade). And after inlet upgrade around 6.7-6.8s (6c ambient).
Then you run out of fuel. So with your PI setup I am sure you can do better! Good luck! Looking forward to more results!
peter@pureturbos.eu
pureturbos.eu
luchocamp's Avatar
Default 05-24-2018, 07:56 AM
6c ambient is on your favor .... local ambient is 30įC.
135i vs 335ix ... different weight also
luchocamp's Avatar
Default 05-25-2018, 07:15 AM
Best 100-2000kph 6.93 sec
Best 1/4 mile E.T. 11.16 @ 127mph 1.72 on 60ft
82 F = 28 C ambient temp
luchocamp's Avatar
Default 05-25-2018, 07:20 AM
Bours Bours is offline
Car: 335i x-drive n55 2011
Default 05-25-2018, 09:11 AM
Whats your 0-60 ??? Great time son !
335i x-drive 2011 e90 n55
ER chargepipe | performance line d.p | 90/10 bms meth kit | K&N drop in | JB4 + MHD pump flash | xhp stage 3 flash | PURE STAGE 2 turbo
luchocamp's Avatar
Default 05-25-2018, 12:18 PM
60ft was 1.72sec
Default 05-25-2018, 12:36 PM
60ft was 1.72sec
0-60 mph i meant
luchocamp's Avatar
Default 05-25-2018, 01:19 PM
0-60mph in 3.42sec
0-130mph in 11.86sec
sorry
Default 05-26-2018, 08:24 AM
Originally Posted by cnm135i
Logs still not being shared..? Why even bother bosting?
i run same setup efr8374 but EWG, posted logs long time ago
http://www.n54tech.com/forums/showthread.php?t=48694
only jb4 no flash
luchocamp's Avatar
Default 05-26-2018, 12:23 PM
Last Night at track
Jm276607@gmail.com Jm276607@gmail.com is offline
Car: 2013 bmw 335ix
Default 05-26-2018, 01:58 PM
Last Night at track
Flirting with 10s!
NorCalN55 NorCalN55 is offline
Car: '11 335xi M Sport
Default 05-26-2018, 08:10 PM
Logs or it never happened.
luchocamp's Avatar
Default 05-27-2018, 07:06 AM
only video was next car camara Blue M4 without cats and map2 JB4
https://streamable.com/lsa6q ******* **
luchocamp's Avatar
Default 05-27-2018, 07:39 AM
Default 05-27-2018, 09:09 AM
Guess it never happened
