alexis485's Avatar
alexis485 alexis485 is offline
Car: 2011 BMW E92
Default 01-05-2018, 09:13 PM
Originally Posted by ahmedmoe
subbed! I following a similar route. left my old engine (that I bent a rod) at a garage, should be able to rebuild it, well going to find out if so.
@alexis485 are you planning on changing the cams?
No aftermarket cams for N55 yet. I was hoping for VAC / Schrick to realeases upgraded cams but, I don't see it happening any time soon.
Originally Posted by CobraMarty
Will the head be ported and flowed?
Hey if you need more info on adding MILVs, let me know.
See my PM
2011 E92 ABR N55 Built Motor | ABR Built 6AT | Big Boost 3.4 Turbo Kit | JB4 + MHD | xPH Stg3 Flash | Fuel-It Stg 3 LPFP | Fuel-it PI Kit | COBB Exhaust | E85 |
alexis485's Avatar
Car: 2011 BMW E92
Default 6HP19 Built Trans - 03-28-2018, 01:16 PM
While we wait for the crank hub. I decide to work on the transmission.
I was debating in between getting my AT build or DCT swap. Like most of you know, the DCT swap is pretty expensive. For that reason I choose to build my current AT.
BTW, Propulsive Dynamics is not doing the AT builds anymore. They were selling just the clutch set until last week. Apparently, they have no plans on making more.
Anyhow, I talked to Alex@ABR about it and he didnt hesitate to do the work. So far, I got PD clutches and bushings.
Name:  PD Clutches1.png
Also, all trans internal parts (input shaft, basket, etc) has gone thru deep cryogenic process to increase strength and durability.
Yesterday, I received the torque converter back from TCR. They increased the stall to 2800-3000.
Custom trans oil cooler is up next.
JETmn JETmn is offline
Car: 2011 335xi
Default 03-29-2018, 06:53 AM
Keep us updated on how the trans goes, there is very little information out there so far. Thanks for posting the updates!
alexis485's Avatar
Car: 2011 BMW E92
Default Crank Hub Update - 04-02-2018, 06:12 AM
Some great news! Crank hub finally arrived this past Friday
orteeze orteeze is offline
Car: 08' 335i
Default 04-02-2018, 06:15 AM
Any word why PD stop offering this service?
E90 LCI M Sport
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 04-02-2018, 10:34 AM
I haven't heard but my guess would be that the customer base was not large enough.
2011 E92 335i Auto Sold
12.0 @ 125MPH JB4
VRSF Chargepipe | BMS Intake | Custom MHD | VRSF 7" Intercooler | ER Turbo Outlet | XHP Stage 2 | AEM Meth Injection | Pure Stage 2 V3 | Pure Inlet | GFB DV+ | AR DP |
CobraMarty CobraMarty is offline
Car: BMW
Default 04-02-2018, 11:22 AM
Did you ever get the head flowed?
alexis485's Avatar
Car: 2011 BMW E92
Default 04-02-2018, 07:58 PM
Im not sure why PD stop doing the upgrades but my guess is just like bimmer_boost said, not enough demand.
I dont know the numbers but, Im pretty sure the shop did tested. Ill find out soon.
alexis485's Avatar
Car: 2011 BMW E92
Default Transmission Oil Cooler - 04-10-2018, 08:38 AM
I couldn't find much information on the trans cooler so, I decide to make my own kit. In case some else wants to follow my steps, here a list of parts I bought out of Ebay.
Setrab Oil Cooler 50-625-7612
Setrab M22 to -8AN Male Adapter, 90 Deg
Improved Racing Thermostat FSM-165
Russell -10AN Twist-Lok Hose - 10 ft
Vader Solutions Trans Fittings -8AN (Plugs into the factory cooler lines)
Russell Straight -8AN Twist-Lok Fittings
Russell 90 Deg-8AN Twist-Lok Fitting
Russell 45 Deg -8AN Twist-Lok Fitting
Also, I'll make a custom bracket. I'll include post installation pictures later.
suchtragedy's Avatar
suchtragedy suchtragedy is offline
Car: 2013 335i
Default 04-10-2018, 11:13 AM
Attachment 73012
Interested in this trans cooler, subbed. FYI thank you sir you helped me with something I had been struggling with regarding my plan for an upgraded oil cooler setup. I had been researching options for an inline external oil thermostat but wasn't finding what I was looking for at first, but when I saw this trans cooler post you led me to Improved Racing's site and they seem to have what I been looking for to make this work. I didn't want to completely bypass the OEM oil cooler thermostat like most DIYs/Kits for N54/N55 I've seen out there. I just wanted find an alternative to open at a lower temp vs. stock + upgrade to AN fittings and bigger cooler so that meant going external thermostat since I couldn't find an aftermarket themostat that worked in the factory oil thermostat housing (at least one that said what temperature it opens at). You helped me figure that out I think. Thanks man
2013 335i F30 N55 PWG | JB4 + MHD BEF + xHP Stg3 | Pure Stage 2 + FBO | BMS PI controller + Meth | Fuel-It! Stg2 LPFP
alexis485's Avatar
Car: 2011 BMW E92
Default 04-10-2018, 05:05 PM
Originally Posted by suchtragedy
Interested in this trans cooler, subbed. FYI thank you sir you helped me with something I had been struggling with regarding my plan for an upgraded oil cooler setup. I had been researching options for an inline external oil thermostat but wasn't finding what I was looking for at first, but when I saw this trans cooler post you led me to Improved Racing's site and they seem to have what I been looking for to make this work. I didn't want to completely bypass the OEM oil cooler thermostat like most DIYs/Kits for N54/N55 I've seen out there. I just wanted find an alternative to open at a lower temp vs. stock + upgrade to AN fittings and bigger cooler so that meant going external thermostat since I couldn't find an aftermarket themostat that worked in the factory oil thermostat housing (at least one that said what temperature it opens at). You helped me figure that out I think. Thanks man :)
You are more than welcome, I'm glad I was able to help. :)
BTW, I just saw BMP is selling the trans lines AN fitting adapter for way less.Click at the link
http://www.bm-parts.com/index.php?ro...&product_id=59
alexis485's Avatar
Car: 2011 BMW E92
Default PR Ignition Kit - 04-11-2018, 09:19 AM
Early birthday present came in. Here is the N55 Precision Receworks Ignition kit. Hopefully, this kit will allow me to run higher plug gap. Previously, I didn't have any other chioce to run a pretty tight gap (0.017-0.018) to prevent misfires when I was running PS2 at 25psi on straight E85.
Name:  PR Coils1.jpg
Also, I really like that PR move the kit installation location. Now, they suppose to be installed on top of intake manifold. That should take away any heat damage concerns specially for people running top mount turbo kits.
Name:  PR Coils_2.jpeg
Stay tuned. I'm planning to do a DIY as soon as I get my car.
Bours Bours is offline
Car: 335i x-drive n55 2011
Default 05-02-2018, 06:08 AM
What was your setup when you bent a rod ?
335i x-drive 2011 e90 n55
ER chargepipe | performance line d.p | 90/10 bms meth kit | K&N drop in | JB4 + MHD pump flash | xhp stage 3 flash | PURE STAGE 2 turbo
Default 05-02-2018, 06:12 AM
Hey man im rebuilding my engine at mmp after i spun a bearing.
Will you do forged rods and pistons ?
I live in cold climate so.im afraid of piston slap and also it could enhance false knock it seems....
Forged rods have no downsides so im getting them
Let me know
alexis485's Avatar
Car: 2011 BMW E92
Default 05-03-2018, 09:34 AM
Let me know
I would get forged rod and pistons if I was you. I blew my motor a while ago when I was running a maxed out PS2. The shop found the problem was the piston in cylinder #4 disintegrated.
I'm not an expert on piston slap matter but, I asked the shop about it right before starting this project. They told me that is critical for them. A good shop is aware of this problem and they will avoided as much as possible. First, they should complete the honing process, then ordered the custom pistons to maintain the proper piston-cylinder wall clearance. In other words, every built should used custom pistons. Now, piston slap is possible on cold weather but, you could get them coated to minimize or combat any downside of running wider clearances. That's my 2 cents!
Default 05-03-2018, 11:14 AM
Excellent just told my builder (MMP) about everything you mentioned and he will make custom clerance to avoid slap
Lowon's Avatar
Lowon Lowon is offline
Car: Bmw M2
Default 05-03-2018, 05:52 PM
I'd get forged rods too if I rebuilt my m2's n55. I live in Canada and in the winters it gets to -35C or sometimes even -40C or colder with a wind-chill. Anyways from what I learned through Subaru engines is that the forged internals expand and contract alot more than the oem Pistons due to less silicon content. The issue with this is if the clearances are too tight then the expansion will cause too much rubbing on the cylinder walls and increased wear. So I always used a block heater in the winter to aid in warm up to prevent the piston slapping from occuring too long. But I'm not sure if this is available on bmws.
Anyways if you don't mind me asking, howd you spin the bearings on your n55?
Mods: Stock for now
Default 05-03-2018, 09:13 PM
I did a 3rd gear pull while spraying meth after i just installed pure stage 2 turbo.... ( like 9th pull after install ) and BOOM engine malfunction....engine sputtered and i had timing codes and a #1 cylinder sparkplug melted....
I fixed timing chain, tensionner and crank hub.....
Car ran fine for 3 days than spun a bearing...
I hope engine builder can tell me why it happened...
So i can get forged pistons for dirt cheap if i add forged rods too ( 2k $ for both ) or get oem pistons for 1500$ ...
You rly think forged pistons are not good or i should pay prenium for new oem ones ?
Default 05-03-2018, 09:14 PM
Oh and btw im from montreal so i know these terrible winters too unfortunatly
alexis485's Avatar
Car: 2011 BMW E92
Default 05-24-2018, 01:49 PM
Finally I got the numbers on the heads.
Huge gains after porting.
Name:  Heads Intake Lift.JPG
Size:  23.4 KB Name:  Heads Exhaust Lift.JPG
alexis485's Avatar
Car: 2011 BMW E92
Default 06-17-2018, 06:25 PM
A few more pics before the motor goes back in the car.
Stage 3 heads going in.
Big boost 3.4 turbo kit looking great after been installed.
Motor and transmission finally met each other again. Lol. Also, I got ADE engine mounts and Revshift trans mounts.
More to come soon.
Default 06-18-2018, 08:01 AM
That's looking really good!
Car: 2011 e92 335i
Default 06-20-2018, 11:54 AM
The shop that "fixed" his timing chain when it jumped timing screwed up during the installation and the oil pump wasn't working properly.
12.0 @ 125MPH JB4
Matticus91 Matticus91 is offline
Car: 2
Default 07-01-2018, 01:32 PM
Wow this looks amazing!
Default 08-24-2018, 12:23 PM
UPDATE ??
