(#701)
lazer's Avatar
lazer lazer is offline
Car: 135i n55
Default 04-28-2017, 11:12 PM
On the pump flash what timing i supose to have?
135i 2012 6speeds n55/FBO/ps1/inlet/stg2 lpfp/bms meth
Pump flash
tho's Avatar
tho tho is offline
Car: 2011 335i Convertible
Default 04-30-2017, 09:56 AM
With the MHD Pump flash, is the Min Flow Boost (PSI) setting still an active setting? I have mine set to 7 (originally 8) but the meth doesn't seem to flow until about 12-13psi. See attached log showing meth flow. I could have sworn that the meth started flowing a little earlier prior to the MHD flash. I don't think that it's much of an issue since I'm running ethanol but I'd like to know.
Edit: I uploaded the wrong file. The right one is there now.
Default 04-30-2017, 10:06 AM
MIN PSI is active, RPM has to be over 2000rpm, throttle more than 50% open, etc. Looks like it's taking meth around a second to get up to full flow in the log. A bit slow but not that far off. Maybe drop down to a min psi of 5.0.
The BEF has nothing to do with the meth flow or mapping.
tho's Avatar
tho tho is offline
Default 04-30-2017, 01:37 PM
OK Thanks!
lllN54lll's Avatar
lllN54lll lllN54lll is offline
Car: 335i N54
Default 05-04-2017, 10:43 PM
Can someone confirm that the speed limiter works? I have tried the pump flash and it is still limited at 255km/h.
Or does something have to be encoded with ncsexpert?
thanks
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default MHD 1.0 - 05-05-2017, 06:05 AM
MHD is getting out of beta status, with 2 new features added for the 1.0 release:
- Linear throttle flash option
- Coolant target flash option (Stock / Sport / Track)
Sport Mode:
Coolant normal 95c (106c Stock)
Coolant high 90c (95c Stock)
Coolant high+kft 80c (85c / 80c Stock) (This mode is activated at full throttle)
Amb threshold for high mode 27c (37c Stock)
Amb threshold for high + kft 32c (42c Stock)
Track Mode (only for drag race application):
Coolant normal 90c(106c Stock)
Coolant high 85c(95c Stock)
Coolant high + kft 80c(85c / 80c Stock) (This mode is activated at full throttle)
Amb threshold for high mode 22c(37c Stock)
Amb threshold for high + kft 27c(42c Stock)
There is an ECO target (109C stock) but it is not modified
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 05-05-2017, 06:07 AM
thanks
No extra steps are required but some cars still don't take the limiter removal. Is your car Euro or US spec? How did you check the 255 limit, because the DME won't output more than this when logging.
orteeze orteeze is offline
Car: 08' 335i
Default 05-05-2017, 06:57 AM
Sport Mode:
I guess I know what I'm doing tonight. Good work guys!
E90 LCI M Sport
Bours Bours is offline
Car: 335i x-drive n55 2011
Default 05-05-2017, 07:30 AM
Sport Mode:
Its for mhd only ? Or it can be added in the pump bef ?
335i x-drive 2011 e90 n55
ER chargepipe | performance line d.p | 90/10 bms meth kit | K&N drop in | JB4 + MHD pump flash | xhp stage 3 flash | PURE STAGE 2 turbo
lllN54lll's Avatar
Car: 335i N54
Default 05-05-2017, 10:58 AM
Tested on the road. At about 255-260km/h the boost begins to regulate up and down. Like original flash.... It is EU Spec car.
thanks....
Car: 2011 N55 135DCT
Default 05-05-2017, 11:13 AM
You must use the latest bms flashes. Terry changed it to 320kmph. In the older flashes it was not removed
lllN54lll's Avatar
Car: 335i N54
Default 05-05-2017, 12:58 PM
Yes, I already know. I use the JB4_N55_022317 files
fisc0h fisc0h is offline
Car: 335i xdrve/m-sport
Default 05-06-2017, 04:09 PM
Seems like it's only a flash-time option for standalone flash, not for BEF
2011 335i x-drive MSport: MHD PUMP_BEF + JB4 ISO 5.16 / Pure Stage 2 / Stage 2 LPFP (bucketless) / N20 TMAP / BMS Intake / ER CP / VRSF ** / VRSF 7" FMIC
Default 05-06-2017, 04:10 PM
+1. I know that looking at the timings themselves is what matters when looking at these BEF logs, but in general terms, is avg ign < 2.0 for E85 blends < 5 for pump gas, still a "safe" range?
lazer's Avatar
Car: 135i n55
Default 05-06-2017, 05:33 PM
Yes..still lock to 215kmh with bef pump flash. **** ive bought mhd more for top speed than the flash haha
Pump flash
Newguy123's Avatar
Car: 12' 135i
Default 05-06-2017, 07:57 PM
Thanks for the continued support!
Sport Mode:
18 Glacier white RS3
#PURETURBOS
#FUELIT
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 05-07-2017, 01:40 PM
Coolant target should be available whatever the map. On n54 Terry asked to remove linear throttle, I assumed it would not play nice on n55 with a jb4.
My pleasure. Once F and late E series are on rails, things should get even quicker.
Default 05-07-2017, 04:25 PM
So if i want coolant targets on my bef fir n55 i reflash the latest map ?
Default 05-07-2017, 04:33 PM
On throttle mapping we already have that on the JB4 end via menu11 in dash, doubling it up in the BEF will cause headaches.
Default 05-07-2017, 06:44 PM
Ok.you are right but what about coolant targets ?
Newguy123's Avatar
Car: 12' 135i
Default 05-07-2017, 06:49 PM
Coolant targets are there now, select the BEF file you're currently using and there is 3 different settings under options right before you flash.
#PURETURBOS
#FUELIT
lazer's Avatar
Car: 135i n55
Default 05-08-2017, 11:30 AM
Why my speed limitee still there with pump flash?
Pump flash
Default 05-08-2017, 11:32 AM
It is disabled in the BEF maps and works fine on our 2011 135i. There is some MHD bug though preventing it from working on all cars. MHD is working on it, last I heard.
Default 05-08-2017, 11:33 AM
PS. This week I'm working on migrating over the latest N54 flex fuel developments including the BETA virtual flex fuel sensor, PI scaling on ethanol content, and various physical sensor input options.
Car: 08' 335i
Default 05-08-2017, 11:40 AM
E90 LCI M Sport
