Alex91104's Avatar
Alex91104 Alex91104 is offline
Car: BMW E90 335i Sedan
Default RB Inlets - 05-17-2016, 05:18 PM
Does anyone know if adding RB turbo inlets will add any gains to hp and tq on stock turbos? VTT claims that theres 30 hp gains with just adding inlets on stock turbos with no other mods.
http://www.rbturbo.com/products/acce...ilicone-inlets
Default 05-17-2016, 08:17 PM
No, you don't gain 30 whp by adding inlets to a bone stock car.
Different story if the car has hardware mods and a tune. Then I can see 20-30 WHP, depending on what was done and octane mix etc.
Texsquirrel's Avatar
Texsquirrel Texsquirrel is offline
Car: 2009 BMW 135i
Default 05-17-2016, 08:30 PM
30 to 40 hp increase to FBO with factory turbos.
More with a tune.
2009 BMW 135i | Alpinweiß | 6AT | MHD/BMS JB4 G5 ISO32.8 | JB4 MHD 3/15/17 E85 Backend Flash | BMS Anti-Lag | Fuel-It Stage 2/ES-1/JB4 integration Kit | AD Engineering Port Injection | PR (Turbo-side) Inlets | PR Ignition System | VRSF DP | aFe Exhaust | Cobb FMIC | ER CP | Tial BOV | N20 TMAP | BMS Oil Cooler Valve | JB4 Mobile | 100% E85 | H&R Swaybars F&R | BA Diff Lock | StopTech D&S Rotors F&R | Cool Carbon Pads | Michelin PSS
Immoralus's Avatar
Immoralus Immoralus is offline
Car: 2008 335xi
Default 05-18-2016, 11:11 AM
Gains are there, car breathes so much better top side. I haven't dyno'ed but straight bench dyno numbers I feel like I am somewhere around 450whp.
08 335xi- JB4/Trebila,RB Inlets, VRSF CP ,FMIC, DP ,BMS DCI,e50 and Fuel-it Stage 2. 11.8 @ 118
Alex91104's Avatar
Default 05-18-2016, 11:20 AM
So what your saying it does gain with no other mods, and tune on stock turbos because it breathes better?
Immoralus's Avatar
Car: 2008 335xi
Default 05-18-2016, 11:24 AM
You will see some gains with no other mods, just not much. Infact, you probably wouldn't notice it, unless you put it on a dyno. Inlets should be closer to the last mods you purchase.
Default 05-18-2016, 12:42 PM
+1.
The more boost you push, the more they help. I am seeing 3-4 psi more boost with mine compared to before I added them. But I have RB turbos.
I have been tuning a 335 with just DCI, FMIC/CP and inlets on 93 octane and it's hitting 19.5 psi boost. They make a nice whooshing noise too.
unrealii unrealii is offline
Car: E93 335
Default 05-19-2016, 03:48 PM
I have a tune, fmic and a cp. Would these inlets benefit me? I have no intention of adding ***
2009 335i E93 6MT ///M-Sport
MHD Stage 1 | ER Chargepipe | VRSF 5" Stepped FMIC | 335is Clutch | KW V3
pysical pysical is offline
Car: 2009 335xi
Default 05-19-2016, 04:01 PM
Why don't you want to add ***? You can get some hi flow ones that still pass emissions. And if you do inlets, it would be the best time to do them since you will have all that torn apart.
Car: E93 335
Default 05-19-2016, 04:15 PM
I have an inner hippie which won't let me do it
Plus I recently had to replace the seal on my front oem inlet. If my seal on the rear inlet goes out then I may spring for the upgrade if its worth it.
