BazBar's Avatar
BazBar BazBar is offline
Car: UK 140i-M Sport Auto
Smile New bigger turbo logs - 07-25-2013, 02:42 PM
Would like some comments/feed back on logs attached.
The new turbos are from Owen Developments (UK), must say they are a very high quality upgrade.Very pleased with them :-).
Logs attached for your comments
b1aze's Avatar
b1aze b1aze is offline
135i is in my sights...
Car: 2011 WRX STI
Default 07-25-2013, 03:25 PM
Need lots of info on this man. The logs look perfect! What sort of E85 blend are you running?
robc1976's Avatar
robc1976 robc1976 is offline
Default 07-25-2013, 04:21 PM
Need to see timing to see what is going on, post your setting also.....boost failsafe, ect. Might be more in them.
LuniZ74's Avatar
LuniZ74 LuniZ74 is offline
Car: 335i 2008 AT
Default 07-25-2013, 04:29 PM
+1
pic's, price, mods etc
BazBar's Avatar
Default 07-26-2013, 01:44 AM
Thanks for your comments. Firstly we do not have E85 in the uk, deffo not in London were i am :-( . So i only use Shell V power for street use.
The logs were on Map 3 running a 60/40 mix. I do use vp 109 on map 7 @ the pod, 20 psi boost fail safe.
When i get home later i will re-post a graph with timings on it, but you can always down load my logs and go through them, Do you think there might be anymore to get out of this setup ?
Car Spec: Owen Development complete re-manufactured Turbos with the waste gate totally re-worked, see below pic. machined internals, cut back blades with a 55mm hta wheel. You will need to speak to Owen Developments to get a price.
Link: http://www.owendevelopments.co.uk/
Terry's Cobb AP front end flash, Custom Exhaust & *********, no *****s, Cheap Chinese intercooler. Terry's Charge pipe & Water/Meth kit. That's about it for the Engine side. Do have a quaife LSD fitted which just transforms the cars traction.
I think the next step is to try and get the fuel system sorted.
Cant wait to get to Santa Pod and try to get in the 11sec ?
BazBar's Avatar
Default 07-26-2013, 02:45 AM
Could not find away to remove the log pictures in the firs post so have to post them again with more info shown.
chuckd05 chuckd05 is offline
Car: 08 135i , 06 325xi e90
Default 07-26-2013, 08:32 AM
looks good , youre car an auto? stock final drive?
e92
BazBar's Avatar
Default 07-26-2013, 08:47 AM
Auto with Quaife :-)
robc1976's Avatar
Default 07-26-2013, 09:09 AM
Great timing, I would get the 3.5 bar sensor, raise meth add top 80....I run it daily. Add you notice I have a slight boost spike at shift Wich I could fix by lowering boost reduction...you could possibly raise that to get s bit more boost at shift. I would let Terry have final say. These turbo s have a good curve!
bmsportzn135i's Avatar
bmsportzn135i bmsportzn135i is offline
Default 07-26-2013, 09:23 AM
If i may ask, what is this 3.5bar sensor everyone talks about?
537.75HP 540.63TQ
robc1976's Avatar
Default 07-26-2013, 09:44 AM
Stock map sensor is limited to 20 psi and a 75 add for meth, N20 3.5 allow 24 psi and a 100 add on meth.
BazBar's Avatar
Default 07-26-2013, 10:57 AM
Thanks for the input robc1976, notice your boost comes in earlier than my boost, mine is a little bit slow, can this be adjusted in anyway ?
BazBar's Avatar
Default 07-29-2013, 01:35 AM
Can anyone recommend a supplier & the N20 3.5 Sensor to use that works fine on the N54 ?
Cheers
Default 07-29-2013, 02:29 AM
BazBar...That is running pretty rich...did you load defaults to the G5 after you installed your backend flash? The "All Map AFR" setting should all be "0". Turbos look great, looks like they have a bit more in them but your "cheap chinese intercooler" may be holding them back a bit
Rob...that is looking damn good....NICE WORK!
BazBar's Avatar
Default 07-29-2013, 03:34 AM
Thanks steveAZ, cant remember what i done now when i loaded the flash and the G5, but later i will check and possibly reload/reset the G5, one thing i have noticed of late is the smell from the exhaust begin a stronger than normal (no cats, just a straight through exhaust). so possibly right about the over fueling, better of to much than not enough. I have got the AMS intercooler also but i had an accident with a rock, split the intercooler because i removed the front plastic mesh grill, lesson learnt
Hopefully i can get it repaired and get it back on the car again (behind the grill this time).
Cheers
Default 07-29-2013, 03:40 AM
Agreed, better rich than lean...but a little leaner will make more power and you're pretty rich
you can just select...
6) G5 ISO w/ BMS Flash, 1M, or 335is (which I'm assuming you already have)
and
File/Restore Defaults
robc1976's Avatar
Default 07-29-2013, 05:54 AM
Cheers
Here ya go!
http://bimmerboost.com/showthread.ph...ate-review-DIY
robc1976's Avatar
Oops forgot to post pic.
robc1976's Avatar
Default 07-29-2013, 05:56 AM
I would replace your boost selonoids and check all vacuum lines...especially these.
bnk bnk is offline
Default 07-29-2013, 06:06 AM
Cheers
That's for higher boost pressures. You are below 20psi, so you don't need one.
robc1976's Avatar
Default 07-29-2013, 06:11 AM
add of Notre he is but he may want to raise that, also he can run high meth additive with the N20.
robc1976's Avatar
Default 07-29-2013, 06:13 AM
Thanks man! Lot of tweaking to get it like this!
bnk bnk is offline
Default 07-29-2013, 06:24 AM
He has only the compressor wheel upgraded, the turbine wheel is only clipped. IMO the stock TMAP is enough for his turbos. No harm done though trying it out and letting us know for sure
robc1976's Avatar
Default 07-29-2013, 06:39 AM
Very good points!
M3YUK M3YUK is offline
Car: E46 M3
Default 07-29-2013, 08:05 AM
Nice work Fella
about time us UK owners start pushing some big power and fast qtr's
What sort of price did Owens Charge for these
UK 135i SGM
