(#6551)
blackshan blackshan is offline
Car: 335i coupe
Default 04-27-2013, 02:02 PM
Originally Posted by az335iat
I wish I had a Flat red line.
Haha that's funny!
jb4 G5 fbo w/ mmp inlets and 3.5 sensor
Axing Axing is offline
Car: 3dirty5
Default 04-28-2013, 04:01 PM
Originally Posted by GetSomeE92
My harness is a modified JB3 harness and it doesn't have any pins in the number 2 or 15 positions. I'm currently running the G4 board without any issues. Would I still be able to upgrade to the G5 board with this harness? What are those pins for?
Didn't see this question get answered.
I have the same harness, can I upgrade to G5 board with it?
Thanks!!
z4z4z4 z4z4z4 is offline
Car: 2011 Z4 35i, 2002 M3, her 08 M5
Default 04-29-2013, 12:25 AM
http://www.n54tech.com/forums/showthread.php?t=10400
This should help. I believe youre good to go for upgrade....but read read somemore.
Marv85 Marv85 is offline
Car: '07 335i MT
Default 05-03-2013, 04:04 PM
Terry, with ISO 19, is map0 back to being a real passthrough map?
my question is, can I run COBB natively while on map0? and more importantly can I still log?
Thank you!
SOLD --'07 E90 335i, PTF COBB E50, HFS4, ER CP, ETS 7", AA **, Exhaust, DCI, ACT, Nitto Nt555
SOLD -- '10 E92 335i M, 6MT COBB v3, ER IC, ER CP, VRSF **, Fuel-it st2, Mfactory LSD, powerflex subrframe bushings
Default 05-03-2013, 05:17 PM
Thank you!
With the JB4 in place even on map 0 you can't do anything via the OBDII port with the vehicle moving. You'd have to remove the JB4 all together to log via Cobb, for example.
skysurfer's Avatar
skysurfer skysurfer is offline
Car: 2008 535i
Default 05-04-2013, 01:15 PM
Terry responds faster to emails when it is debug you're after
+1
But maybe not today
He's at the No Fly Zone in Bakersfield having fun
2008 BMW 535i
JB4 G5, BMS Pump Flash, ( Updated FW ), DCI,
Eisenmann Race Exhaust
ER CP
E60 DP
450 HP / 480 TQ ( when running AEM 320, 50% E85 )
https://www.youtube.com/watch?v=51z_sELokzk
Default 05-04-2013, 08:25 PM
Removed a bunch of support posts without reading them. If you want public support use the support forum. If you need my assistance email me.
erwan35's Avatar
erwan35 erwan35 is offline
Car: bmw 335i e92
Default 05-05-2013, 07:54 AM
What does map 0 do on iso?
It does not block obdII right?
and is map 0 still stronger than oem performance?
Im confused with iso.
help me out please
_______________________________________\\\
BMW 335I E92 2007 RHD 6AT,FULL M3 BODYKIT,HYBRID TURBOS,BMS ADAPTER W/ 3.5BAR TMAP,VTT INLETS,JB4 G5ISO W/ MHD TREBILA FLASH,BMS ANTI-LAG,AEM METH KIT W/ FSB,BMS DCI,VRSF CHARGEPIPE & TIAL BOV,VRSF C@TLESS ***,FMIC,BMS OCC,BMS CABIN FILTER,MUFFLER CUSTOM BULLET,97RON PUMP GAS
SeaBee335 SeaBee335 is offline
Gettin' There!
Car: '07 335i E92
Default 05-05-2013, 08:44 AM
help me out please
Whether or not youre running iso shouldn't have any effect on map 0. its a pass through map meaning the obd ll port will NOT be blocked and the performance should be just about stock, maybe minus a small amount of boost. If you want true stock performance use map 4.
'07 335i E92 - FBO
///ADMAN ///ADMAN is offline
Car: 2013 BMW 335is
Default 05-05-2013, 11:38 AM
Um. I think you have that backwards.
2013 BMW 335is Convertible
Default 05-05-2013, 12:09 PM
With ISO there is no true pass through map. Map 0 allows OBDII communications while not under boost & when under boost targets factory boost targets. Map 4 is like map 0 only it keeps can going full time (on and off boost), and runs the in dash gauges, auto clear, and other user selected settings.
drstorm drstorm is offline
Just wondering which map we need to use with my G5 ISO on 1m with FMIC, N55 midpipe, DCI and bov on 94 octane only? Any setting to do in the interface? Do we continue with map 6 like G4 board ?
Thank!
b00st b00st is offline
Car: 09 135i 6MT
Default 05-05-2013, 01:09 PM
Having some frustrating trouble, but I believe it's something I'm doing wrong. I just installed my G5, so I needed to update my interface from an old version. I uninstalled the old version from my computer, and downloaded the new zip file. Now when I click the setup.exe file, I get this message:
The following error occurred attempting to install 'C:\DOCUME~1\Ian\LOCALS~1\Temp\jZip\jZip7CB\jZip31 261\JB4.application':
"The system cannot find the file specified. "
See the setup log file located at 'C:\DOCUME~1\Ian\LOCALS~1\Temp\VSD33.tmp\install.l og' for more information.
Does anyone have any clue on what I'm doing wrong here with installing the interface? Any help is appreciated.
2009 6MT 135i + JB4 + FBO + meth + E85 =
sirfredi's Avatar
sirfredi sirfredi is offline
Default 05-05-2013, 01:12 PM
Download again and try
By the way..... you extract the files, correct?
Car: 09 135i 6MT
Default 05-05-2013, 01:15 PM
Tried that 3 times already. I also went through and tried to find anything related to my old JB4 and deleted it.
Default 05-05-2013, 02:12 PM
If you didn't uninstall the old JB4 from the Control Panel/Programs, then there are hidden files in your computer that prevent you from reinstalling.
If that is the case you can try using Wise Care 365/ Program Uninstaller. It will find all the associated files and delete them. Then restart the computer and try loading again. Install Drivers first, then hit Set-up to load the rest.
Rob.K Rob.K is offline
Car: 08 135i 6MT
Default 05-05-2013, 08:13 PM
Based on the filepath it seems like you're trying to install from inside the zip archive. Try extracting everything first and then install.
Current - 2008 135i 6MT | XR9567
Sold - 2007 335xi AT | 12.1@117
goaljnky's Avatar
goaljnky goaljnky is offline
Car: M5, Z4 3.5 IS
Default 05-06-2013, 12:32 AM
yep
2011 S Drive 3.5 IS
2008 M5
2006 Mini Cooper S JCW
desty desty is offline
Car: 135i 08
Default 05-06-2013, 06:23 AM
Hey Terry can you help me? i have no idea what to set the LAG FIX at. Currently it's at 80% but i don't know if it's good or not.
Car: 09 135i 6MT
Default 05-06-2013, 10:17 AM
Thank you very much for the help! This was exactly what it was. It's been a while since I installed my last JB4 interface and I forgot that I had to do this.
Russell @ BMS's Avatar
Car: 2009 335i AT
Cool 05-06-2013, 01:45 PM
Do a log and look at your boost vs setpoint. If your not getting tip in boost overshoot....with throttle closure.... your good to go.
Lagfix values greater than about 65 do not do much anyway.
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 05-13-2013, 08:18 AM
With the G4 integrated, does setting Lagfix to 0 run the DME default wastegate settings?
I noticed in the G5 ISO thread that with the new default wastegate position option that replaces Lagfix, stock-like result would be setting of 10-15. Does the same apply to the old G4?
Just asking because I normally run Lagfix 0 for the smoothness in daily driving, but I noticed a slightly different feel when running Map 0 the other day that felt a little better.
Default 05-13-2013, 09:06 PM
Moved rattle posts to support section. Check over there if you need help with it. Have BETA firmware.
JonBi335i JonBi335i is offline
Car: 08 335i
Default Running Virtualbox with WinXP - 05-14-2013, 02:56 PM
I'm having trouble getting the COM1 working. how do i figure out the COM on my mac so i can set it on to use when im on VB WinXP?
Darkcyd335xi's Avatar
Darkcyd335xi Darkcyd335xi is offline
Car: e92 n54 xi
Default 05-14-2013, 06:19 PM
Figure I ask before trying it out and making a $400-500 mistake...anyone here running the interface on a windows 8 tablet yet without any issues? I was thinking of replacing my netbook.
