Ifreezebmx562 Ifreezebmx562 is offline
Car: N54 335i
Default N54 intercooler overkill?? - 05-12-2020, 07:53 PM
Hello guys and girls, so Iím currently almost FBO on stock turbos with JB4... I have a 5 inch FMIC but want a 7.5 stepped FMIC but was wondering if a 7.5 is kinda over kill for Stock turbos...
What do you guys think??
Rule77's Avatar
Rule77 Rule77 is offline
Car: 08 E90 335i
Default 05-13-2020, 06:42 AM
Itís not over kill. I run the VRSF 7.5Ē Race on stock turbos and itís amazing. Go with the BMS or VRSF 7.5Ē Race.
08 E90 335i - MONTEGO BLUE - JB4/MHD E85 BEF
ECS CARBON DCI - NRW CARBON COWL FILTERS
MMP CHARGEPIPE - TIAL BOV - VTT DUAL OCC -
VRSF 7.5Ē RACE FMIC - VRSF DPís - VRSF INLETS -
VRSF OUTLETS - BMS PEDAL TUNER - 3.5 BAR TMAP -
NGK 97506 @.022 - PFS STAGE 3 LPFP - PFS V2 PI -
SPOOL PERFORMANCE ETHANOL ANALYZER
MISHIMOTO 25 ROW OIL COOLER - H&R SPRINGS
BMS SPORT OIL COOLER VALVE - NRW V1 PADDLES
MISHIMOTO 15 ROW TRANSMISSION COOLER
19Ē 666m WHEELS - HANKOOK VENTUS V12 EVO 2ís
Default 05-13-2020, 08:25 AM
Not overkill, go with this one:
https://www.burgertuning.com/product...d9f2a47e&_ss=r
Geo335's Avatar
Geo335 Geo335 is offline
Car: 2007 335i
Default 05-13-2020, 08:54 AM
Hello guys and girls, so I’m currently almost FBO on stock turbos with JB4... I have a 5 inch FMIC but want a 7.5 stepped FMIC but was wondering if a 7.5 is kinda over kill for Stock turbos...
I was thinking the same thing and you also have to take into account the pressure drop since they are still stock and not upgraded turbos. I'm looking at the CSF Race 5"stepped. Will be doing a before and after comparison from stock.
2007 e90 335 - BMS DCI - JB4 - feline less - AFE scoops -VRSF CP - HKS BOV - VTT PCV - BMS Cowl Filters - Muffler Delete - PUMP BEF - e30
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 05-13-2020, 12:18 PM
I have a 5 inch stepped and IAT barely moves with stock turbos. Unless you live in a hot climate or track the car it is probably fine. That said if you didn't already have the 5 I would prob say the 7.5, as the step up doesn't cost that much more.
If you have a log we can see what your particular car looks like.
Car: N54 335i
Default 05-15-2020, 10:03 PM
Iíve been taking everything into consideration, even though Iím on stock turbos right now I plan on going to stage 2 turbos anyways. I feel as if the move for the future might be the 7.5.
Car: N54 335i
Default 05-15-2020, 10:06 PM
Hey thanks for the input, I already ordered the ARM 7.5, Iím taking the gamble Lmafo, I currently have their dpís and found them to be very well put together. If welds and fins are ugly then itís going to be returned and Iíll pick that one up. My only question is last time I tried to order something off BMS it said since Iím in CA they canít. 👎🏻
Car: N54 335i
Default 05-15-2020, 10:07 PM
Hey thanks for the reply, I currently live in CA so the weather isn’t that bad �� lol. During the summer the outside temps can get up there, but I was thinking the 7.5 maybe for the long run. I’m going to put these injectors in and throw my 5” FMIC back on and I’ll toss and log on here for you.
Rule77's Avatar
Car: 08 E90 335i
Default 05-18-2020, 04:24 AM
There is no noticeable pressure drop with the 7.5Ē Race on stock turbos.
Car: N54 335i
Default 05-25-2020, 02:26 AM
Hey what’s up guys, so after 3 days of dealing with the FMIC it’s finally in. I would never ever tell anybody to get the ARM 1k FMIC. The welds are “ok” the FMIC had some bad burs inside the FMIC, all the couplers I got were dirty as if they were sitting on a shelf outside... ARM also doesn’t have ANY intrustuctinos for the 1k only for the 5”... it’s pretty straight forward process but sometimes I’d like to double check things. My biggest problem is that they only sent me 5 hose clamps when I needed 6. I had a ARM charge pipe with a coupler and clamps that was provided when installed back then. But the problem is that the new coupler is thicker than the old one. So I had to wait till the next day and go to autozone and buy another clamp. To anybody that sees this post, stuck with CSF or VRSF.
Default 05-29-2020, 01:37 PM
Hey whatís up guys, so after 3 days of dealing with the FMIC itís finally in. I would never ever tell anybody to get the ARM 1k FMIC. The welds are ďokĒ the FMIC had some bad burs inside the FMIC, all the couplers I got were dirty as if they were sitting on a shelf outside... ARM also doesnít have ANY intrustuctinos for the 1k only for the 5Ē... itís pretty straight forward process but sometimes Iíd like to double check things. My biggest problem is that they only sent me 5 hose clamps when I needed 6. I had a ARM charge pipe with a coupler and clamps that was provided when installed back then. But the problem is that the new coupler is thicker than the old one. So I had to wait till the next day and go to autozone and buy another clamp. To anybody that sees this post, stuck with CSF or VRSF.
Stick with BMS actually
https://www.burgertuning.com/product...0a2e09bc&_ss=r
Car: 2008 E93
Default 05-29-2020, 05:27 PM
Cosigned
Default 05-30-2020, 07:35 AM
+ 1
Torgus Torgus is offline
Default 06-01-2020, 10:43 AM
+2
Got Boost?
