Lloredit's Avatar
Lloredit Lloredit is offline
Car: 2008 Bmw 135i
Default My Car is Undrivable HELP - 08-16-2020, 06:59 PM
Iím getting code 4f89 and under hard acceleration from third to fourth it will downshift ( on its own) hard enough to frighten the bejesus out of you. Happens every time now. Any ideas? Steve
2008, 135i, JB4,MHD, Dinan exhaust, oil cooler, fiber intake, koni, hi flow cp., stage 2 lpfp, upgraded turbo internals
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 08-16-2020, 08:39 PM
Does it happen on map 4?
Could be a trans slippage/lack of pressure issue, maybe old fluid/seals/etc, or could be legit trans issue. Did you up the torque recently?
Lloredit's Avatar
Car: 2008 Bmw 135i
Default 08-16-2020, 10:38 PM
I haven’t tried 4, should I try it. Yes, I got a good source of ethanol and am using xhp for Tran. Thank you.
Default 08-17-2020, 07:14 PM
How long has this been happening?
Any other symptoms?
