SPANKY's Avatar
SPANKY SPANKY is offline
Car: 2008 335i
Default Bms low temp question - 05-29-2020, 08:50 AM
I have the low temp stat but I have the 4 season's to deal with so I keep taking out and reinstalling the stock oil stat.is it possible to put the bms oil bypass in and use the stock spring together?or will it wont work that way.
E90 SEDAN '08
-SiNGLE TURBO AUTO TRANS*FSB G5 ISO*100%METH**FUEL iT!STAGE 2*ALPiNA FLASH-
-NGK PLUGS*BMS OCC*RB VALVE-
-E85 MHD FLASH-
Rule77's Avatar
Rule77 Rule77 is offline
Car: 08 E90 335i
Default 05-29-2020, 08:57 AM
Iím pretty sure you shouldnít use the stock spring with the BMS sport oil cooler valve.. I would email BMS if you donít get a clear answer on here.
08 E90 335i - MONTEGO BLUE - JB4/MHD E85 BEF
ECS CARBON DCI - NRW CARBON COWL FILTERS
MMP CHARGEPIPE - TIAL BOV - VTT DUAL OCC -
VRSF 7.5Ē RACE FMIC - VRSF DPís - VRSF INLETS -
VRSF OUTLETS - BMS PEDAL TUNER - 3.5 BAR TMAP -
NGK 97506 @.022 - PFS STAGE 3 LPFP - PFS V2 PI -
SPOOL PERFORMANCE ETHANOL ANALYZER
MISHIMOTO 25 ROW OIL COOLER - H&R SPRINGS
BMS SPORT OIL COOLER VALVE - NRW V1 PADDLES
MISHIMOTO 15 ROW TRANSMISSION COOLER
19Ē 666m WHEELS - HANKOOK VENTUS V12 EVO 2ís
Default 05-29-2020, 01:38 PM
I would just leave it in at all times.
dmckmc dmckmc is offline
Car: E60 535i
Default 05-29-2020, 02:18 PM
I live in the midwest and switched back and forth a few times and then changed to a lower oil temp thermostat. They are all over ebay for about $30. It consistently opens around 228 deg F. Very happy with it, allows quick warm up to turbo temp and then hot enough to boil off any condensation. The temps then stay very steady around 217 deg F.
I have a 535i which has a massive oil cooler. I don't know exactly how the lower temp oil thermostat would perform in a 335i or other.
N54
FBO
E40
JB4
MHD
XHP
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 05-29-2020, 07:45 PM
The screws to the cover will eventually get ruined and you either won't be able to open or close it. I removed mine during colder months but I eventually just left it out because you can't get new screws and I didn't want to get stuck. In the winter I couldn't reach operating temperature with it in so it stayed out.
