3er's Avatar
3er 3er is offline
Car: E90 335i xDrive
Default Maintenance while engine is out of car - 05-15-2020, 02:51 PM
Hello fellow enthusiasts,
I'm finally nearing my full return to the N54 community. I picked up an engine to replace my knocking engine today. It's got 68k, and the CARFAX makes it out to be a dealer-serviced engine with minimal issues.
It's sitting in the garage right now, awaiting a thorough cleaning and maintenance. In the meantime, I'm seeking a comprehensive list of what I should take care of while I have unrestricted access to the engine.
So far my list includes:
Valve Cover Gasket
Oil Pan Gasket
OFHG
Turbos (Stage 3s )
HPFP
That's all that comes to mind for me, so if anyone else here has suggestions, I'm all ears! TIA
E46 M52TUB28 - Gone but never forgotten
E90 N54 - Survivor of an engine transplant!
JuniorB JuniorB is offline
Car: 2007 e60 5 series
Default 05-15-2020, 09:06 PM
I done the same thing while mine was out so any leak would be the last issue. I done rod bearings and arp bolts while it was out. Every o ring was done, even the cooling hoses. Some tips along the way, prepare for anything! I used never seize on every bolt, the turbo oil and coolant hoses, plugs and of course Eldor coils. I removed all those pinch hose clamps, and replaced it with ss worm clamps. I added two 2g grounds, and ditched the factory one. All new pullies, and tensioner, and a aluminum ps pully. Don’t forget all new exhaust studs, and nuts.
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 05-16-2020, 01:57 PM
Rear main seal, water pump if that is an original at 68k, maybe belts.
SocalBMW SocalBMW is offline
Car: 2013 335is
Default 05-20-2020, 10:00 AM
Walnut blast it
Stevo585's Avatar
Stevo585 Stevo585 is offline
Car: 2007 335i Coupe MT
Default 05-20-2020, 11:14 AM
I'd recommend what JuniorB said and walnut blast it for sure!
2007 e92 335i 6MT MSPORT -- DAW Stage 4 Turbos -- AD Engineering Port Injection -- VRSF Down Ps -- BMS DCI -- VRSF Inlets -- VRSF Aluminum Outlets -- ARM Chargepipe -- Turbosmart DVs -- 7" ARM FMIC -- LSD -- 335is Clutch -- BMS Short Throw -- Stage 2 Bucketless -- n20 Tmap -- Custom 3.5" Single Exit Exhaust
