favicon favicon is offline
Car: E92 335i 2010
Default User settings review - 10-07-2020, 02:38 AM
Hi Guys,
Yesterday I have uploaded new JB4 firmware "N55_ISO_5_17_T5.hex" (unfortunately, I don't know which version was there before). I did only one change, in the menu, position 10 Westgate position I've set it to 5000 rpm from 4000(not sure). When I started the car after that change the car started vibrating and strange sounds were coming from under the hood.
I would like to set everything to default and if this will not help with rattle sound what adjustment I can make?
TMAP and 6-cyl timing logging should be set to 0 right?
Attached my current user settings, please review them
Default 10-07-2020, 02:40 PM
Default settings can be found here:
E Chassis N55 JB4 - N54Tech.com - International Turbo Racing Discussion
Car: E92 335i 2010
Default 10-11-2020, 06:06 AM
One more thing, menu nr 11, the scale is from 0 to 5, setting it to default means 1000 RPMs which is 10 x click from 0 (100 rpm = 1 step), am I right?
