Originally Posted by KnifeEdge87
your logs are no good man, open them, most of the fields aren't populated
perhaps you have a hardware setup issue issue or something ?
thanks pal, most likely. it is just a shame that no support is responding only fellow members
yesterday measured map 0 and map 3. 0-62 8.2(?!) instead of 7.1 and map 3 6.8. so boost is there. now I am thinking I may have some errors in ECU or smth like that. I have BMS air intake too, maybe it needs to be cleaned and washed after 1 year use?
