I’d go back in, resave & try again. Did this just start?
Thanks Dave. Ive had some other problems like switching to map 4 unless im on map 6. Therefore I use map 6 all the time. So no its not new, but I looked at it and thought it shouldn't overshoot like that too. But since i don't know anything really, i just was curious.
I actually notice when I decided id like to experiment with the boost curve a little bit but i knew if my targets met nothing.....
The targets entered should be what’s reflected or at least close! Keep me posted
Double check too that your wheel controls are still @ 4/2 if your using a BEF
JB4 and MHD in signature? hmmnnn -
02-22-2020, 09:59 AM
You state in your signature that you have JB4 and MHD. Are you using this with an Off The Shelf MHD tune or a free BEF from BMS that you loaded via the MHD software? I suspect your overboosting due to stacking and not set properly to do so.
Just my first hint at the problem anyways.
Brandon
Hayden, Idaho.
* 08' 535I. * JB4 W/ Bluetooth Connect & custom tune. * Billy Boat 535I 3.5" *****-back exhaust W/ resonator delete. * BMS DCI. * NGK 2 step colder plugs @ .020" (And I mean .020" on money!). * New Eldor coils. * BMS BOV adapter and BMS Vac side OCC. * BMS Chargepipe. * TIAL BOV W/ Hard 1/4" Vacuum line W/stock spring. * XHP Stage 2 * C-@-T TUBES.
