akadic10 akadic10 is offline
Car: 2017 Honda Civic Type R
Default Sharing my type r map 1 so far - 07-08-2019, 05:29 PM
Hey, received my unit today but only had a few minutes to drive with perhaps one solid 3rd gear pull. I'll do some more this weekend.
Quick feedback, it is very easy to install and map1 is fairly noticable.
I live in north Florida, use 93 pump gas and always fill up at Shell. I also have a KN drop in filter but I can't imagine it will have an impact at all.
Let me know if this is enough for me to be promoted to map2
Default 07-08-2019, 07:12 PM
Short run but seems ok to me so far!
Default 07-11-2019, 05:19 PM
Another map1 with a solid 2nd and 3rd gear pull.
As promised I will upload some more this weekend.
Default 07-11-2019, 07:35 PM
Thanks, looks fine. No logs needed unless an issue comes up.
Default 07-12-2019, 07:15 AM
Does that mean I can go to map2?
Default 07-12-2019, 05:08 PM
For the typeR I normally suggest staying on map1 due to fuel pressure issues. You can try it but if you have any issues just drop back down to map1.
TypeRaw TypeRaw is offline
Car: Civic Type R
Default Can you check out my first log as well - 08-22-2019, 07:13 PM
Good evening @Terry, can you please check out my log I installed it today, running 93/with 3 gallons e85. 3rd gear pull. Uptop it felt a little jumpy.
File Type: csv Jb4 first log 2019-08-22 21_51_41_Map-1.csv (13.5 KB, 112 views)
