spammer's Avatar
spammer spammer is offline
Car: 435i
Default Did i brick my tcu? XHP F series flash - 04-10-2019, 12:45 PM
So i connected it up followed all the instructions under chapter 3. I'm using the Burgers DCan Cable a nexus 7 android 6.02.
I started the process it brought up the 3 bars to flash then failed. Transmission is in limp mode.
I got it to reconnect and tried to reset the tcu, it said it worked, then i tried to clear codes, it said it can't read codes.
I tried to flash it with stage 1,2 and 3 and each time it says my car is not compitable even though it is. I tried all the troubleshooting in the FAQ and emailed XHP.
As it stands now the car starts but the transmission shifter LED is off and it won't select a gear.
I also tried to flash back to factory but its giving me the 'car is not supported' thing.
I hooked my JB4 back up to read the codes, and below is a screenshot of those codes.
Anyone have an experience like this? Any tips would help I emailed xhp but they haven't gotten back to me yet (it just happened) Thanks.
can you put full coverage on a rebuilt title
spammer's Avatar
Car: 435i
Default 04-10-2019, 01:58 PM
It must be this burgers cable it. It was finicky when I MHD flash (couldn't move the tablet at all or it would disc) now i its saying cable is not connected either MHD or XHP.
IF i really hold it in tight i can get a reading from XHP satin the TCU is in boot mode, but i can't read or clear codes.
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 04-10-2019, 03:25 PM
I had an issue with MHD when I first tried to flash it. It failed mid flash and I had to go into their recovery mode once I got a new cable. I would get a new cable first.
spammer's Avatar
Car: 435i
Default 04-10-2019, 04:19 PM
Indeed - this gives me hope. I don't see any results for 'bricked' xhp flash, i just ordered a bimmergeeks cable - now the waiting games begins.
spammer's Avatar
Car: 435i
Default 04-11-2019, 04:48 AM
So XHP hit me back said to execute the emergeancy flash under the MISC menu and start over : i hope it works. i may try with this B cable or just wait for the new cable to come ill report back later.
T_H_O_M_A_S T_H_O_M_A_S is offline
Car: M135ix
Default 04-11-2019, 08:22 AM
it will work , i knocked the cable out of its obd socket once while flashing , got the same messages as you , did the emergency flash , all is back to normal
spammer's Avatar
Car: 435i
Default 04-11-2019, 09:36 AM
Thanks for the reply THOMAS! Makes me feel alot better while i wait for a new cable. I hate just letting my car sit there all messed up. This helps lol.
M-terkait's Avatar
M-Terkait
Car: F30 335i
Default 04-11-2019, 01:12 PM
happened to me actually, cuz my car had 0 battery, anyway its related to some issue i have on my car too lazy to look for it. anyway the emergency flash under MISC which was hidden for some reason. should fix it.
N55 - Doc race 6266.
Car: 2011 e92 335i
Default 04-11-2019, 01:15 PM
Actually come to think about it this happened when I was flashing XHP not MHD. My cable worked for MHD so I didn't think it was bad. I borrowed another from a friend and was able to complete the emergency flash. I replaced the cable and haven't had any issues since.
spammer's Avatar
Car: 435i
Default 04-11-2019, 01:24 PM
Good to know i'm not the only one who did this.
Burgers are even sending me out a new cable w/o sending the old one back so thats nice of them and bimmergeeks just shipped theirs so ill have options. thanks again!
spammer's Avatar
Car: 435i
Default 04-17-2019, 08:20 AM
Thanks everyone for the piece of mind! Bimmergeeks cable fit snug as hell and it all worked like a charm. Emergency flash > xhp flash > Stage 3 flash! We're good!
Waazzzaar Waazzzaar is offline
Car: 335i e90
Default 07-26-2020, 01:25 AM
My car is now having the exact same problem but I don't have a misc menu what can I do
