(#2276)
Steveo's Avatar
Steveo Steveo is offline
Humid 535i
Car: 535i
Default 05-04-2011, 11:23 AM
Originally Posted by Steveo
Anyone have insight on routing the USB on the 535i? I don't recall seeing anywhere to push the cable thorugh under my box.
I just ran mine. Hopefully this will help out some 5ers so we don't have the cables hanging out the hood while logging.
Trickcruiser's Avatar
Default 05-04-2011, 12:27 PM
Originally Posted by manu135i
Terry is an email from me to you with CSV is urgent .... tonight I have a race ... thanks
I really hope that everyone (I think most do) knows how truly lucky we are to have a tuner that gives us this type of support...
Thanks and keep up the great work Terry!
SHATX's Avatar
SHATX SHATX is offline
Car: 07 E90 335i
Default 05-04-2011, 12:35 PM
No Doubt! Terry you are amazing! if you ever come to Austin let me know
themyst themyst is offline
Super Demigod
Default 05-04-2011, 01:13 PM
Question, will there ever be any plans to allow us to adjust the starting boost level of map 4?
E90 LCI N54 6AT
i2istudios's Avatar
i2istudios i2istudios is offline
Photog
Car: 335 Coupe 6MT
Default 05-04-2011, 01:33 PM
Originally Posted by just2sxy
when is the lean cruise / fuel economy map coming? i got a long road trip coming up soon
That will be one of the next things we add back in.
what kind of mph would we see on the hwy? I never get the rated 28mpg hwy, even stock, always around 26.8
2007 E92 335i / 6MT / Monaco Blue Metallic / Gray Dakota Leather / Comfort Assist / Premium / Sport / Heated Seats / Navi / Active Steering / Active Cruise Control / Park Distance Control / Rear Sunshade / Sirius MODS PicoTray / M3 Steering Wheel / Front OEM Aero Lip / Bimmian Aluminum Pedals / CDV / Ram Air Scoops / Painted Reflectors / HID 5000k / LED Angels / M Perf. Shifter / Euro Light Switch / 8500 x50 Hardwired / Center Armrest Pouch / JB4/ BT
Default 05-04-2011, 01:35 PM
The stock/economy map?
Default 05-04-2011, 01:36 PM
I saw around 1.5mpg in early testing, but also had the occasional sputter that is very unbecoming with a BMW. With a little more tuning hopefully we can keep that 1-1.5mpg improvement with 100% stock behavior.
Super Demigod
Default 05-04-2011, 01:43 PM
Oops, got my maps messed up. I meant the progressive meth map
E90 LCI N54 6AT
Default 05-04-2011, 01:47 PM
That's map 3. One of my to-do list items is to enable progressive meth mapping in conjunction with map 6 as well.
GtiGyver GtiGyver is offline
Default 05-04-2011, 02:46 PM
Hi Terry,
I was wondering if there would ever be an option to be able to drive an external A/F gauge with any free analog outputs the JB4 may still have.
Pin 2 on the DB25. The formula used internally is:
AFR = (misc_in + 980) / 10 where misc_in is 0-5v represented as a 0-1023 integer, and AFR is represented as a 98-200 byte representing 9.8:1 through 20.0:1.
You set FutureUseD=2 to enable.
Default 05-04-2011, 03:08 PM
No plans for that. We'll add in dash AFR if you want to monitor it though.
Default 05-04-2011, 06:10 PM
That would be pretty awesome.
mobilefitt's Avatar
mobilefitt mobilefitt is offline
M3 Eater (m3eater)
Car: 07 E90 Non Sport...Sleeper
Send a message via AIM to mobilefitt
Default 05-04-2011, 06:38 PM
Yeah....
JB4 15ohm w/ FSB & CM10, ETS-FMIC, Evolution Race Works charge pipe, Forge DVs, AR *********, Injen dual cones, DIY catch can-vent to atmosphere, Koni FSD,TSW Donnington 18's, Bridgestone Potenza 760 Sports.
moodi's Avatar
moodi moodi is offline
Car: 335I
Default 05-04-2011, 11:31 PM
Guys can some 1 tell me with simple words ,whats new in the latest Firmware version 21/4 ?
i read the release notes and its ALL shortcuts and meaningless abbreviations!
manu135i manu135i is offline
Car: bmw 135i
Default 05-05-2011, 12:38 AM
This map is a log in 5 ... I do not really like the drop in advance ....
saifsiddiqui saifsiddiqui is offline
Default 05-05-2011, 02:30 AM
I'm not trying to start a tuner war or anything but is it going to be possible to get over 400 whp with just tune/dci/meth with the progressive meth? (Like the Vishnu Progressive Meth is getting over on the "other" forums)
Elie335's Avatar
Elie335 Elie335 is offline
;o
Car: E92 335i/320i
Default 05-05-2011, 02:32 AM
yes, jb4/dci/meth would get you in the 400 hp zone, you just need DP and you're done
Default 05-05-2011, 02:34 AM
How about w/o ***? Don't mean to sound cheap but 1. I'm a college student, and 2. I don't want the car to sound too loud. The golf tee mod was enough for me.
Elie335's Avatar
;o
Car: E92 335i/320i
Default 05-05-2011, 02:35 AM
maybe you can, but your car turbos won't breath like they should
kang159 kang159 is offline
Car: 2010 335i Coupe
Default 05-05-2011, 03:00 AM
i have meowless ***, and i don't think its loud at all with the flapper closed..well, unless you're WOT..XD
Will Will is offline
Car: 08 135i
Default 05-05-2011, 09:37 AM
Alright quick question I just got the JB4 and for the setup I have right now I will probably be going back and forth from map 1 & 5. I have the BMS DCI also, and I'm about to get either a AMS FMIC or AR DP but didn't know which order to go, would you recommend FMIC first or DP first . I live in East Texas where it gets pretty hot in the summers although, I'm able to use 93 Oct.... Any thoughts?
Bowser330 Bowser330 is offline
N54TECH FTMFW
Default 05-05-2011, 09:39 AM
Default 05-05-2011, 09:51 AM
I have both and would say FMIC as the summer is coming up quick.
Heat soak really sucks...
N54TW's Avatar
N54TW N54TW is offline
Obsessed with his BMW
Car: E92 335i 6MT
Default 05-05-2011, 10:27 AM
For those of us that originally had the JB3 and had to install the new power wire, what did you have to do to go back to stock? I haven't taken the jb4 out yet but I'm guessing I would have to reverse what I did in the install. Can anyone confirm this?
2014 335i M Sport: bootmod3 Stg 2, AA CP, CSF FMIC, GFB DV+, VRSF down-pipe, aFe stage 2 intake, KW Clubsport Coilovers, xHP Stage 3.
Default 05-05-2011, 11:17 AM
You remove the power wire when removing the JB4.
Currently Active Users Viewing This Thread: 10 (1 members and 9 guests)
sherazkn
