(#901)
Default 06-21-2020, 10:40 AM
Originally Posted by t-800
BTW I’m on setting 4
See if setting 8 makes any difference for you.
leadfoot leadfoot is offline
Car: 335d
Default 06-21-2020, 12:42 PM
Water temp was 200+
Car: 335d
Default 06-21-2020, 02:28 PM
Yeah.. 8 didn’t reduce my low boost issues either
Default 06-21-2020, 05:26 PM
What about 3 vs. 4?
cc61940542 cc61940542 is offline
Car: 2018 rs3
Default 06-21-2020, 06:32 PM
So,1-4only impact the manifold sensor while 5-8 impact only the pre-throttle sensor?
Default 06-21-2020, 06:51 PM
No
Car: 335d
Default 06-21-2020, 06:53 PM
4 seems to be a little better than 3. But i just got a low boost again today. Thinking of moving to 5 now. Or maybe I should disconnect the JB4 from the upper boost manifold sensor? I’ll likely only ever run on map 2.
Default 06-21-2020, 08:28 PM
5 will probably be worse but worth confirming.
Default 06-21-2020, 08:55 PM
Had an issue with the sensor yes.
Replaced it with a brand new one (faff of a job)
I’m merely reporting what difference I see with 1) no JB4 connected 2) JB4 connected with just bottom sensor after emailing George. 3) connecting everything back up and straight away having the low boost issue.
Tried 8 then 7 first. Made zero difference on mine.
Out of interest is the new one identical part number or has it superseded to a newer number?
Car: 2018 rs3
Default 06-22-2020, 01:53 AM
Sounds like only 3, 4 or 7, 8 worth trying
Default 06-22-2020, 08:44 AM
Seems like 4 has had the most "positive" feedback so far among the 2-3 guys posting here. I'll post another update shortly with some additional things to test based around setting 4.
A couple things I also need feedback on:
1) Are you guys also able to recreate the no boost condition in map8 VALET map which runs around 25% less boost than factory?
2) Most of you run additive maps, worth confirming if the issue comes up on absolute maps too. Using map6 you can make an "absolute target" map. For example setting map6 boost to the following profile.
Default 06-22-2020, 02:49 PM
Added v8 firmware to the BETA channel and revised the test algorithms a bit.
FUA = 1 is the previous #4 test that had the best results reported, with a minor change.
FUA = 2 is the same as 1 but a little stronger effect. Both of these settings impact the manifold sensor only so if you're testing without the MAP sensor attached won't have any effect.
Car: 2018 rs3
Default 06-22-2020, 05:08 PM
Use "absolute target" map,The same problem will occur, I have tested this very early
Car: 2018 rs3
Default Is my circuit board the latest? - 06-22-2020, 06:12 PM
Default 06-22-2020, 08:19 PM
Yes, see how v8 FUA = 1 does for you.
Car: 2018 rs3
Default 06-24-2020, 05:48 AM
V8 FUA=1,a new problem appears, the boost displayed in the log is not real, it is lower than the actual value
Car: 2018 rs3
Default 06-24-2020, 05:57 AM
I think new settings should impact the manifold sensor,eventually, the boost shown in jb4 log is lower than the real value,of course, this is just my guess
Car: 335d
Default 06-24-2020, 09:19 PM
Well.. 5 is definitely crap. So, uploaded the new firmware and running on #1. Feels much more responsive off the line and around town. More later as I put some highway miles on. Btw, i can’t seem to see/find where the JB4 app shows which version of the firmware I’m running..?
Car: 2018 rs3
Default 06-25-2020, 07:58 AM
You can try to log to see if boost is lower than your previous log
Default 06-25-2020, 08:48 AM
Right in the user adjustment tab, see firmware update video in first post.
Default 06-25-2020, 08:49 AM
Shouldn't be, let's see your log. Remember PSI is pre-throttle boost and PSI2 is manifold boost. ECU_PSI is boost sampled not from the sensors but from the ECU via CANbus and will match factory boost levels not JB4 tuned boost levels.
Car: 335d
Default 06-25-2020, 09:53 AM
Yeah..I can see where it shows a firmware version something like 77/8//7.... But that version doesn't seem to change after updating the firmware..? Or maybe it just me... :-]
Default 06-25-2020, 03:27 PM
77/is the RS3/TTRS platform, 8 is the firmware (v8), //7 is the board type (SENT)
Default 06-26-2020, 07:44 AM
Hmmm not getting error at start up.
JB4 says 8700?
I expect some of the test settings may trigger faults on some cars. If 2 isn't working try 3.
On 1 vs 0 is 1 any better?
Default 06-26-2020, 08:39 AM
That looks like a FUA related fault. Should be no change between firmwares with FUA = 0, only change was to FUA algorithms. As mentioned faults are possible on FUA > 0 settings depending on the vehicle, barometric pressure, ECU version, etc.
