Hmm, are you sure it's from the oil pan? That's not too common on a newer car from what I know of, but I could be wrong. Usually more from the oil/valve cover gaskets.
Ya i know i haven't heard of it too much on the F32/33 but the tech took pictures and brought them into me. you could def see dried oil around some areas where the oil pan meets the engine and there was even a drip bead near where one of the metal coverings under the car was catching the oil. I jus tthought i was burning up oil cause of having such an aggressive tune for all these months but maybe not.
I never smell burned oil, see any in the engine bay or on the ground in my garage and its not severe a very minor leak idk if the crank case breather would help but like i said i rather spend 100 and try it then put in the wrench time if i have to.
