(#4551)
Speedy164's Avatar
Speedy164 Speedy164 is offline
Default 08-25-2019, 10:52 AM
Most people use the JB4 mobile app which is different than a computer. Did you follow the Windows computer directions? There is a video posted in there too. What step specifically there are you going off the rails?
If you're using a MAC BMS does not support that. There is a 3rd party app posted that people use but you'd have to contact them for support on it.
N54Tech.com - International Turbo Racing Discussion - View Single Post - JB4 laptop connection directions
Hey Terry can you DM me I have a question about firmware for Map 6 adjustments
2019 Infiniti Q50 Silversport
JB4 with fuel wires, EWG wires,
HKS lower down P!pes
Burger tuning heat exchanger
sky777 sky777 is offline
Car: Infiniti Q50 RS AWD
Default 08-26-2019, 12:20 PM
You might find map1 or map2 a better fit for you... Definitely test those.
Hi Terry, so I put back 94 octane gas and it’s definitely better. Could you take a look at my logs? Map 6 is based on Stillen tuning on turbo efficiency. Which map should I run long term for turbo longevity or doesn’t matter? Which one you think give the best performance? Thanks!!
File Type: csv 2019-08-26 12_36_52_map-6, 20 psi, 94.csv (7.5 KB, 112 views)
2018 Q50 RS AWD - Electric Indigo
JB4 Map 6
Megan LDP
Helmholtz Axle-back
BMS Elite Heat Exchanger
K&N Air Filter
Konig Ultraform 19x9, 35 offset
vqmax03 vqmax03 is offline
Car: 2019 Q50 S
Default 08-27-2019, 02:36 PM
Would fuel open loop have any impact on our trims?
Car: q50
Default 08-27-2019, 04:11 PM
This motor is full time closed loop with wideband O2 correction. Yes it would affect trims but it doesn't happen unless there is a failure.
Q50 Premium RWD
BMS JB4 w/ FW, WMI, EWG
BMS HE
Low cost LSD
Car: 2018 Q60 3.0
Default 08-28-2019, 09:53 AM
Hey Terry can you take a look at this new log? Installed LDP's yesterday and did this 4th gear pull. Let me know if you think I should make any changes.
2019 Q50 Red Sport
Burger JB4
Burger Cold Air Intake
Burger Fuel Wires
Burger Elite Heat Exchanger
Megan LDP
Default 08-28-2019, 11:16 AM
No it's not relevant to this platform as we're not intercepting the fuel pressure signal.
Default 08-28-2019, 11:17 AM
Seems fine to me!
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 08-31-2019, 08:16 PM
Hello, changed my map 6 and it's somewhat aggressive, can someone check this log to make sure its ok?
12.64 @114mph
0-60 4.46
g0ldm4g3 g0ldm4g3 is offline
Car: 2017 Q60 Red Sport
Default 09-01-2019, 12:17 AM
Hey guys, long time lurker and finally pulled the trigger on a jb4.
Below are my logs for a 0-60 and 4th gear pull with my Map6.
Something that I noticed is that my launch isn't that good, it bogs then goes as opposed to just... Going? Lol I'm a 2017 Q60RS AWD. Lmk if it's safe to increase my boost or just let it be and add bolt ons to allow more boost
My boost profile is tapered, starting from 1 psi to 5 psi at 4.5K RPM, then after 5K it's down to 0psi at 7K
Car: q50
Default 09-01-2019, 05:46 AM
Hello, changed my map 8 and it's somewhat aggressive, can someone check this log to make sure its ok?
Map 8 is for water meth injection only, did you install a kit?
Q50 Premium RWD
BMS HE
Low cost LSD
Car: q50
Default 09-01-2019, 05:50 AM
Doesn't look bad, make sure you turn on both channels of boost, AFR,and trims so you can make sure both banks are behaving properly. I'd leave boost alone and add some Bolton's and relog. As far as launch, with the stock tune it's tough to hit a good launch because of some of the throttle nannies. Anything above like 2-2.5k will trigger a boost/throttle cut.
Q50 Premium RWD
BMS HE
Low cost LSD
Speedy164's Avatar
Default 09-01-2019, 07:03 AM
I am not sure if this information is also relevant to the silversport as well. What do you mean by turn on both channels of boost, AFR and trims?
Default 09-01-2019, 09:15 AM
If you are bogging off the line more boost may help. Might be better off with our map2 here.
Default 09-01-2019, 10:33 AM
Just enabled both banks of AFR, boost, and trims and they're both similar like the graph Terry just posted.
So what's the point of both boost bank parameters if ECU PSI is the actual PSI the car is outputitng?
Car: q50
Default 09-01-2019, 10:40 AM
Ecu psi is the boost the car THINKS it's outputting,before the JB4 adder. And you want to see both banks because it'll tell you if 1 bank is having turbo issues or a boost leak, etc.
Q50 Premium RWD
BMS HE
Low cost LSD
Car: q50
Default 09-01-2019, 10:41 AM
There are logged parameters for the left and right banks of the motor for AFR, boost,and fuel trims. It's important to read both channels to see if either side has a boost or fuel problem.
Q50 Premium RWD
BMS HE
Low cost LSD
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 09-01-2019, 05:22 PM
Epic typo fail, updated OP, reattached log for review
12.64 @114mph
0-60 4.46
Car: q50
Default 09-01-2019, 05:46 PM
Lol np. Your timing looks ok. Do you have fuel wires turned on? Your trims are maxxed big time and it looks like the AFR leans out in the lower range of each gear.
Q50 Premium RWD
BMS HE
Low cost LSD
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 09-01-2019, 06:17 PM
Yep fuel wires are on and enabled, I seem to always have maxed out fuel... I wonder if they are not functioning properly
12.64 @114mph
0-60 4.46
Car: q50
Default 09-01-2019, 07:00 PM
Try a run on lower boost. If they don't flatline the AFR then they're not active or making a good connection. If they are then you're really leaning out down low and should drop the boost down there....or time to consider a meth kit
Q50 Premium RWD
BMS HE
Low cost LSD
Default 09-02-2019, 09:13 AM
AFR is fine for the fuel but the target is rather high. Might be better off with a lower target. Use dragy to figure out what offers the best performance for the particular situation.
Q50Philly's Avatar
Q50Philly Q50Philly is offline
Car: 2018 Infiniti Q50 Red Sport
Default 24th Annual Haltech World Finals - Imports vs Domestic - 09-03-2019, 07:44 AM
Hi Folks - anyone else attending this World Cup Finals?
2018 Q50 Red Sport AWD
BMS JB4 w/Map 0 for WMI Control
BMS WMI Kit
Ecutek Tune by R/T
AMS Red Alpha Cold Air Intakes
HKS Resonated LDP (no drone)
Tanabe Y-Pipe
Mishimoto Oil Catch Can
Mishimoto Heat Exchanger
Car: q50
Default 09-05-2019, 09:23 AM
Anything new in the works for this platform???
Q50 Premium RWD
BMS HE
Low cost LSD
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 09-10-2019, 01:02 PM
I've been trying to log for days and can't find any open areas. City life stinks sometimes
12.64 @114mph
0-60 4.46
jrobohm's Avatar
jrobohm jrobohm is offline
Default 09-10-2019, 01:04 PM
Amen
2017 Q50 Premium RWD
  • BMS JB4 w/ Fuel Wires
  • BMS WMI w/ PM8s
  • Pure Stage 2 Turbos
  • Z1 PU Motor Mounts
  • AMS HPFP (RA338) & LPFP
  • AMS Flex Fuel Kit v2
  • AMS LDP
  • AMS CAI
  • Fast Intentions Res. Touring 2.5 CBE
  • Mishimoto Oil Catch Can
Terry @ BMS
