spammer's Avatar
spammer spammer is offline
Car: 435i
Default Is it time to get colder plugs? - 08-04-2019, 08:08 PM
So i bought my car @38k miles untuned off lease. bumped it up to stage 2 for about 13000k miles, it ran great & hard on E40 up to 21PSI and taper off. But now... ever since I went BEF + jb4 if i go over 15/16 PSI in 3rd or 4th gear, my #4 cylinder starts to misfire.
I even went down to E20 and 17PSI, seems like it doesn't even try to pull timing #4 just ****s the bed.
Is it time for the colder plugs?
Experiences?
Default 08-05-2019, 10:45 AM
Yes, sounds like spark plug symptoms.
You'll need a set of these:
https://burgertuning.com/products/ng...nt=32079075982
spammer's Avatar
Car: 435i
Default 08-05-2019, 01:57 PM
Thanks Payam! Just ordered the whole set with the gapper.
LeeOrl LeeOrl is offline
Car: 2013 BMW 335i E93 4/25/13
Default 08-17-2019, 07:48 AM
while you are doing the plugs try and swap the #4 coil with one of the others. if the plugs do not correct the misfire and it follows the coil you will be a step ahead on the troubleshooting
spammer's Avatar
Car: 435i
Default 08-17-2019, 07:53 AM
Good idea - thanks for the suggestion!
spammer's Avatar
Car: 435i
Default 08-17-2019, 10:33 AM
Bought the whole BMS set, and gaped them myself to .22 w/ the tool. just took it for a test drive. Kind of nervous my first time doing it and on a BMW. FREEDOOOMMM!!!
Man, loaded my kill map up to 21psi loaded up on E40 & floored it (of course after a leisurely drive then spirited drive monitoring all cylinders.) everything is beautiful again, hitting peak target w/no issues, banging through gears, foot to the floor the whole way. So relieved. The front end really lifting up like it did before when i first tuned it.
BMW F32 435i N55 Ignition Projects coil packs and spark plugs DIY - YouTube - good video for the 435i on how to do it.
Thanks BMS
Default 08-19-2019, 11:24 AM
Awesome!!!
