Car: 2013 BMW 335i xDrive MSport, JB4, BMS intake, ******* ********, Corsa Exaust
POWERTRAIN MALFUNCTION! -
06-06-2018, 10:24 AM
Originally Posted by Fmonteiro444
Did you ever figure out this issue? I'm having the exact same problem after a turbo install.
I Keep getting POWERTRAIN MALFUNCTION codes daily... It's been terrible to drive and never knowing when it will pop up... I am able to clear codes on my dash though while driving and it will go back to normal... but definitely something went wrong with the last firmware updates...
2013 BMW 355i xDrive M-SPORT/MPPK, JB4 Flex Fuel, BMS Intake, Corsa Pro Series, C* Less DP.
Car: 09 E92 SG
06-06-2018, 10:26 AM
I ordered a new EWG harness hoping that's the issue.
06-06-2018, 10:57 AM
When does is happen? Do you have a log you can post in the support section so we can look over?
06-06-2018, 11:03 AM
did a small log until my computer's battery went dead. Will post there. BTW, just sent you an email with it.
Car: 2014 M235i
06-16-2018, 04:48 PM
Posted something in the support forum, but I'm getting this too. I'm getting a wastegate flap sluggish code along with the drivetrain malfunction. Only happens in map 6. I've been trying to dial in fueling after a PS2 install on map 6 and it keeps happening around 3500 RPM. FF is at 0 constantly. Trims aren't responding super well to increases in duty bias. WGDC isn't looking like it's trying to build boost. I get it like clockwork around 3500 RPM at WOT when doing a log pull, but it also happens randomly under very mild acceleration while the diverter is doing its thing (GFB DV+ installed). Uploading a log of one of the runs where I was trying to dial it in and she died.
Zero issues on map 7. I'm on fw 15_T1
Edit:
Solved my FF issues by adjusting my boost targets. Doing so resolved my wastegate flap sluggish code as well.
'14 M235i FBO PS2 Fuel-It! PI w/ JB4 integration 100% E85, E85_PI JB4/MHD BEF
Reason: .
06-18-2018, 08:46 AM
Do you have a log of everything fixed?
Car: 2014 M235i
06-20-2018, 11:01 AM
I'm still tuning and adjusting my targets, but I can give you a log I've pulled in the process if it'd still be useful.
06-20-2018, 11:21 AM
Of course, post it up!
Car: 2014 335i
06-21-2018, 05:16 AM
Drive Train Malfunction.. Just installed new air intake and JB4 on 2014 F series 335i. I was running it in Map2 and heard a loud pop and got the above message. I found the vaccum line had popped off the intake pipe. I reconnected it but still have message and transmission runs in safety mode. Is there any way to clear it myself? Unfortunately I didn't buy the USB cable to see what codes are displayed. Thank you
06-21-2018, 09:08 AM
You will need data cable or bluetooth. Maybe if you go to a local autoshop they can clear the code for you.
http://www.burgertuning.com/bluetoot...nnect_kit.html
http://www.burgertuning.com/USB_Cable_Extension.html
06-21-2018, 09:24 AM
Pull the negative cable for a minute or so.
Car: 2014 M235i
06-27-2018, 09:01 AM
Sorry for the delay, I was out of the country. Like I said I'm still dialing her in and I just found slight damage to my EWG harness don't expect anything close to perfection haha. I haven't had that malfunction since I adjusted my boost targets though. Feel free to tune her for me
06-27-2018, 09:18 AM
Looks like you may have a boost leak somewhere. WGDC is maxed and FF is maxed.
06-27-2018, 09:19 AM
WGDC and FF are maxed, boost leak in system?
Car: 2014 M235i
06-27-2018, 09:36 AM
That was my first thought too. Still have troubleshooting to do. WGDC and FF were more normal before I made a prior adjustment, so either I did something crazy or I popped something once I finally found 26psi. Anyway, just wanted to give you a log since you asked for it haha
06-27-2018, 10:13 AM
Yea, I would definitely look around for something off or loose. That's a pretty big leak from what it looks like.
07-23-2018, 09:24 PM
Originally Posted by Nicoo70
Hello all . I have a M235i EWG wagner ***** and fmic and a forge charge pipe .
Why my target is so low ? Thx
Map2 runs 6psi over stock per map guide in first post. For personal support use support forum, not the general discussion forum.
Car: M135i
07-24-2018, 09:57 AM
Hi all  i have a M235i EWG wagner ***** and fmic , forge charge pipe and i go to put EWG add on connecteur this week .
ATM what do you think about this log ?
Thank you !
07-24-2018, 10:18 AM
Logs go to the support forum, not this general thread.
Car: M135i
07-25-2018, 06:52 AM
I instal the EWG add on connector and i dont know what value put at « défaut wastegate postition » , 80 or 0 ? Thx
07-25-2018, 08:11 AM
It's not used for EWG, 0 is fine.
Car: M135i
07-26-2018, 08:31 AM
Thx terry . I need new DSUB pin because I put the blue wire on the 14 and no in the 16..
This DSUB pin its good for the EWG add on connector ? https://fr.rs-online.com/mobile/p/co...sub-d/0481140/
Thx
07-26-2018, 08:34 AM
Looks OK to me
Car: 2015 BMW 535i x drive
07-29-2018, 01:29 PM
I was wondering if anyone knows the sequence to get into the in dash steering wheel menu to change maps and read codes. I am still waiting on my bluetooth but finally got the JB4 installed this morning. I believe I am running map 1 but could possibly be placebo. I have tried the BC and volume down for 2-5 secs with no response. I have tried researching and can not find enough information on the 2015 F10 N55 535xi model. I have emailed Mike and he told me that I could access the dash menu without first laptop hookup.
Car: 2015 M235i 6MT
07-29-2018, 11:35 PM
It's on the first page. Here's a direct link to a video:
https://youtu.be/6iLqHa2YFUM
