Mr_JDM Mr_JDM is offline
Car: m235i
Default My first logs m235i - 01-14-2018, 04:16 PM
Can someone please look into my very first logs: I did 2 runs.
My mods: JB4 (map5), VRSF down pipe, BM Intake, VRSF Race FMIC, CP
Unleaded Premium 98
I followed the youtube instructions pull 3rd gear to 7-8000 RPM
Default 01-14-2018, 10:35 PM
1st gear boost limit is set to .4psi.
If you are going to run map 5, I'd recommend installing the EWG wires and lower your FF to the default value so you don't overboost on the first few runs.
Car: m235i
Default 01-15-2018, 06:17 PM
Sorry I am a Newbie. Can you please explain a bit more details. Thanks
Default 01-16-2018, 10:19 AM
You'll need to adjust your user adjustment settings and the defaults can be found here...
http://www.n54tech.com/forums/showthread.php?t=18588
EWG wires can be found under the JB4 upgrades.
http://www.burgertuning.com/JB4_upgrades.html
Car: m235i
Default 01-22-2018, 05:04 PM
Thanks for your help.
My EWG wire is coming this week. Do I need to reset the user adjustment settings same like this thread:
http://www.n54tech.com/forums/showpost.php?p=299688
What other setting do I need?
Can I run map 5 base on my mods? What is the best map for daily drive?
Thanks heaps.
Car: m235i
Default 01-26-2018, 04:16 AM
Originally Posted by cnm135i
You can run map5 and map1 with any kind of mods. If you find power being inconsistent in map5 then try map2.
Thank you.
Any idea about the EWG wire installation?
Default 01-26-2018, 10:00 AM
Yes, set the user adjustments to default after installing the EWG wires as your FF is currently set to 150.
Car: m235i
Default 01-29-2018, 02:57 PM
How do I know if I am on the right firmware ? Which one is the latest one?
Default 01-30-2018, 10:58 AM
Car: m235i
Default 02-01-2018, 12:26 AM
Thanks Steve.
I have installed the EWG Wire. The car feel smoother a little bit. I did not update the firmware because I am not sure which one is the right one. Anyway can you take a look on the new data logs attached see whether If my setting is correct?
Base on my mods what is the most power outcome expected?
Please advise me which need to be done to get the most power and of course safety.
Thanks a lot.
Default 02-01-2018, 12:31 PM
Please provide a proper 3rd or 4th gear log for review.
Car: m235i
Default 02-02-2018, 05:04 PM
Hi Steve! I have not done the new log yet. I tried to update the firmware by using file: N55_FSERIES_OBDII_EWG_13.hex
And end up with the DME code as attached. (102001 Air mass, plausibility - Tuner code, ignore). I found the Air intake was very hot.
Moreover I no longer control the JB4 by using the Steering Wheel. I can only use over the laptop USB.
The threads created by Terry doesn't explaint the different of the files so its very confuse me. I dont know which one is suite me.
Please assist me what to do now to get back the proper update firmware and be able to control the JB4 by Steering Wheel.
Default 02-05-2018, 12:55 PM
As indicated...you can "ignore".
Verify that you haven't mistakenly disabled the steering wheel controls.
Car: m235i
Default 02-08-2018, 05:46 AM
Thanks for confirm. Please take a look my new logs. Its seem like my car is under performance or something. I can see a little different between map 0 and map 5. Boost only 11-12psi. Whether I can see people run up to 18-20 psi.
Also I dont run wmi but the setting is on the photo attached. Is it correct ?
Very confusing whether if the the setting is correct?
zipphreak zipphreak is offline
Car: 2015 BMW m235xi
Default 02-08-2018, 06:05 AM
No WMI, meth, you can ignore.
Your timing sucks. It takes a nose dive in 3rd gear. Is this 98 US or RON?
Are you auto or manual trans? (auto do 4th to 5th, manual do 3rd to 4th)
Stay on map4, do a run starting at 2000rpm to 6500rpm WOT (pedal to the floor) and into next gear for a couple seconds, off throttle. This is your baseline, with all those mods you want to check logs before changing things with JB4!
Did you install both EWG and FlexFuel wires ? If you don't you really should, F-series needs EWG control for Jb4 to work properly especially on map5!
2015 BMW m235xi (F22/N55/EWG) | JB4 + BEF | Wagner Evo2 Performance IC | ER Chargepipe | K&N Dropin | Ground-Control v2 Camber Plates | Dinan Springs | HPA Adjustable Sway Bar Links
VMR V710's | Front 18x8.5 ET45 (235/40/18) | Rear 18x9.5 (265/35/18) | Hankook RS4
https://www.youtube.com/watch?v=dUvs...ature=youtu.be
Car: m235i
Default 02-08-2018, 03:19 PM
Thanks for your respond.
Mine one is Auto but I can switch to manual to use shift paddle from 3rd to 4th gear (is it work?)
I only insalled the EWG but not the FlexFuel. How do I get Flexfuel and installation?
I use 98 unleaded Australia.
I believe my car can perform much better but I dont know what's going on?
I double check the installation of **, FMIC, CP and everything seem are in order.
Please help
Default 02-08-2018, 09:31 PM
Zero everything out on your WMI page.
You have a correction in 3rd gear but it was all cylinders. Was traction control disabled?
Try setting FF to 70 to help boost hit target.
Looks pretty normal for pump gas.
Car: m235i
Default 04-08-2018, 04:13 AM
Hi Steve!
Sorry I was busy but finally done some data logs as attached.
I did 2 runs: 3rd to 4th and 4th to 5th (all in Map 5, traction OFF). Can you please take a look and let me know whats going on.
I ask few people and they say must be something not right. Maybe the some kinda boost leaking do you reckon ?
Sometimes I got Cut-off, some kind of delay (dont know how to explain) approx 0.5sec when pull 2nd or 3rd around 6K rpm. (very rare)
Really want to hear from you and anybody here.
Default 04-08-2018, 02:55 PM
I don't really see an issue in the logs. Looks pretty normal for pump gas. Map 5 probably won't learn up much more based on timing and your I avg.
Car: m235i
Default 04-08-2018, 04:53 PM
Thanks. So which map should i try to reach the target?
Any suggestion on settings change?
Default 04-09-2018, 10:33 AM
You appear to be octane limited. Boost is on target but map 5 target won't target more boost if octane/knock is an issue.
