03-17-2018, 10:09 AM
Originally Posted by P.S
It was auto learning that changed some values from over 60 to 0 during one 2rd --> 5th gear pull. And car wasn't reaching boost target with original values.
Reset all to 50, update to T14, and try again. Perhaps a bug we already fixed.
Car: M135i PWG 2012
M135i PWG limp mode -
03-22-2018, 03:38 PM
-- i hope this is the right thread for this problem, if not, im sry, tell me where to post it instead :D --
03-22-2018, 03:44 PM
If you need help make a thread in the support area with all details.
03-23-2018, 05:34 PM
If any EWG cars want to test the trans temp firmware, drop me an email, so we can make sure it works before posting it.
Car: Bmw M135i F20 Auto 2015
03-24-2018, 08:16 AM
Hi Terry,
I have an Ewg N55 135i with Wagner sports *** and Jb4 and have just downloaded filmware 10/12/5 to my Jb4 from the mobile app.
Is this the latest download or is there something better? Also what is the trans temp filmware?
Regards
Matt
03-24-2018, 10:28 AM
Released firmware versions are posted in the first post.
03-24-2018, 03:09 PM
Hi Terry,
So which filmware is best for my car on the first post? Thanks
03-24-2018, 03:32 PM
Run the newest firmware for your board type, EWG or PWG.
03-24-2018, 08:03 PM
N55_FSERIES_OBDII_EWG_14:
1) Added back trans temp logging parameter
2) Adjusted startup sweep timing
3) WMI algorithm adjustments
03-25-2018, 12:08 AM
Thank you Terry I will try this.
Car: 2016 435I
03-26-2018, 06:59 PM
after i update EWG_14 i got a drive train malfunction and code 123412 (electric wastegate, stop learning: stop position (wastegate close) Not found..
03-26-2018, 10:26 PM
Hi
When I did my update to EWG_14 i had similar error codes because it took a few attempts to get all downloaded, but I just deleted them..
My car feels good, Time will tell but nothing has come back on yet, I’m just expecting the normal sports *** error.
Car: 2016 435I
03-27-2018, 11:48 AM
Originally Posted by N55Tech
Most recent FUD options:
bit0 - Disable in dash BC button controls;
bit1 - Alternative in dash BC F10 compatibility mode;
bit2 - Disable oil temp warmup protection - full boost target when oil temps < 70°C;
bit3 - Disable wastegate/FF adaption learning for diagnostic purposes;
bit4 - Disable needle sweep;
bit5 - Enable duty bias auto tuning;
bit6 - Vehicle equipped with back end flash;
bit7 - Slow down CANbus sample rate - required for some vehicles with older software.
im on the latest firmware and i dont have the disable needle sweep in the future use d
Vintage
Car: F10 N55 PWG
03-27-2018, 02:40 PM
That is because your app has not updated yet.
Car: BMW 340i X-drive
03-29-2018, 12:23 PM
i just swapped my 340i for a 2018 x5 with mppk.
i still have my jb4 from my 335i, can i stack it on top of the mppk?
and will my jb4 from my b58 work on a b48?
thanks in advance.
BMS Customer Service
Car: bmw 335i
03-29-2018, 01:38 PM
thanks in advance.
F series N55 EWG JB4 will work on X5 35i
B58 JB will work on the BMW B48 engine.
Car: 2016 F25 X4 M40i (N55)
03-29-2018, 04:22 PM
My friend just got this error too on his EWG X5 35i
123412 - electric wastgate, stop learning: stop position (wastegate closed) not found
120408- Reduced power mode
123401- Wastegate Learning Stop During *** Heating Cycle
F90 M5 Comp - @BM3Tuning 100-200 5.29s / 60-130 6.1s | @HCP.US
F97 X3M Comp - Tuning Soon!
F80 ZCP DCT Tune Only | @BM3Tuning Stg1+ E85 60-130mph 6.7s
Car: 2016 435I
03-29-2018, 04:29 PM
I went back to the older firmware.. I even set the duty bias to 50 on all of it and the code keep coming back.. I can't even delete it either
03-29-2018, 04:30 PM
What did Terry say? Which one you went back to ?
Car: 2016 435I
03-29-2018, 04:40 PM
Ewg_13-t14
03-29-2018, 06:28 PM
If using the correct EWG board and code won't clear its normally it's a physical issue like burnt wire on the EWG connector, loose connector, etc. If the code onyl comes up intermittently on absolute maps (not map1 or map2) that could be software related based on settings.
Car: 2016 435I
03-29-2018, 06:32 PM
The code only came on when I'm on the latest 14 firmware.. I can't clear it or anything but if I go back to 13 code went away.
03-29-2018, 06:34 PM
Same with my friend
Car: 09 E92 SG
03-30-2018, 11:13 AM
What is the FUD value to enable bit5 and bit6 together? My iOS app won't let me just click the toggles.
Car: 435i
03-31-2018, 02:55 AM
If I update my firmware will I lose my map 6 settings?
