Nyteryder's Avatar
Nyteryder Nyteryder is offline
Car: 2008 535i
Default Bms meth prime - 06-07-2017, 01:00 PM
I am using the jb4 app and the prime button under the meth tab does not do anything. Is there a new version or set up procedure i don't know about. Please advise...
E60 2008 535i/ mmp stage 3 turbos/ mmp inlets and outlet/ xhp stage 3 you flash/bms dual nozzle meth kit/vrsf 7" fmic/ vrsf d0wn pip3s/ bms dci/ er cp/ full custom exhaust/ fuel-it stage 2/ mhd flasher/ rb pvc/ bms occ/ bc coilovers/ niche Milan 134 8.5/10.5 / nitto 555g2 285/30/20f 245/35/20r mt et street radials 275/40/17
NorCalN55 NorCalN55 is offline
Car: '11 335xi M Sport
Default 06-07-2017, 01:09 PM
Are you in map 3 when trying to prime?
Nyteryder's Avatar
Car: 2008 535i
Default 06-07-2017, 01:11 PM
Yes
Default 06-07-2017, 02:09 PM
You need to provide more information. Does the pump turn on? Install pictures? Are you purging in to a bottle? With the nozzle, without the nozzle? It's best to provide as much information about your scenario as possible.
Default 06-07-2017, 02:17 PM
For N54 this button function was only added recently to the latest 32.8 firmware. Previous N54 versions require the gas pedal purge meth outlined in the WMI installation directions.
Nyteryder's Avatar
Car: 2008 535i
Default 06-07-2017, 02:24 PM
The car runs great and it flows fine and it logs ok. The purge method also worked fine. Only the prime button is what is not working. Purging the system before a run is a bit much rather than tapping the prime button to prep for a pull
Nyteryder's Avatar
Car: 2008 535i
Default 06-07-2017, 02:25 PM
I will check my latest firmware to make sure I am up to date
Nyteryder's Avatar
Car: 2008 535i
Default 06-07-2017, 04:51 PM
I updated to the latest firmware and It works great now. Thanks
tho's Avatar
tho tho is offline
Car: 2011 335i Convertible
Default 06-09-2017, 09:17 AM
Are you having to purge the lines prior to doing pulls? Your lines, once purged, should stay that way unless you're getting air introduced into them via a leak or running the tank dry.
The only section that may have some air would be the section between your nozzle and the solenoid. If you are getting air in your lines elsewhere, you may need to double check for leaks.
Nyteryder's Avatar
Car: 2008 535i
Default 06-09-2017, 11:01 AM
Everything is good now. Just a firmware issue.
