(#576)
George @ BMS George @ BMS is online now
Default Today, 02:33 PM
Originally Posted by s3s3s3
I am experiencing what seems like a lot of misfiring/jerky acceleration on map 1, stock 2016 s3 with 98 octane. Can anyone help me out?
https://***********/u/s3s3s3/wtf?log...-9-11-14-18-19
I can see the issue. Your max boost 1st is set to 19 and with the new firmware its trying to cut 19psi from total on that gear. The way it works now is the value you punch in is the boost that will be cut. For stock first set it to 4 so you can cut 4psi in 1st.
Default Today, 02:38 PM
Originally Posted by ZuMBLe
What can the Fuel-IT with JB4 do on the VW platform? What are the possibilities?! It would be great if I could get the JB4 to add boost based of ethanol reading, or dial back boost etc.
We havent had much demand for something like this so havent really thought of what it would do based on boost. Assuming its something we would work on what psi add would you set per E10 of detected quantity?
i.e. If E20 is present add 1. If E30 is present add 1.5 etc.
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
George @ BMS
