GB Cerato GB Cerato is offline
Car: 2019 Cerato GT
Default E85questions - 08-19-2021, 11:33 PM
Since I now have the fuel wire installed and I have found a station that sells E85 I would like to run some sort of blend.
From what I have read up to E30 is acceptable on Map 3? Is that correct?
To figure out how much E85 to add once needs to use a calculator like this one?
https://www.getmtuned.com/ethanol-fu...ure-calculator
Does the E85 display in the JB4 app measure the percentage accurately?
Should I be looking for anything in particular in the logs that I don't normally see or look for?
Thanks again everyone.
AWDGT2's Avatar
AWDGT2 AWDGT2 is offline
Car: 2019 AWDGT2
Default 08-20-2021, 09:37 AM
Run E27-30 in map1, take a log, then Map2, take a log, Map3, take a log....
You can but the Fuel it sensor from the BMS site as an add on and yes the App will then display the E content flowing through the HPFP. The install takes about 15 min and is worth it.
I opted to purchase the separate fuel it app and it has a few more things in it than the built-in one from JB. Like Fuel temperature, and a handy mixing calculator built right in.
This is the online calculator that I use Ethanol % Calculator - Brew City Boost
